Partial flash erase and Softdevice possible?
Hello
I have a power constraint device.  Limit is not the total charge of a battery or so.  Limit is the peak current.
Available (peak) current is around 4mA (@1.8V), current peaks required e.g. for radio are buffered thru capacitors.
Everything is working except flash page erase.  This is because flash erase consumes around 6mA@3V and takes 85ms.  This is beyond the capacity of the Cs.  And this is limited due to Ex constraints.
Idea is to use partial flash erase to spread the consumption used for flash erasure so that the peak current is kept as small as possible.
Is there any Softdevice API to do this?  Any chance to bypass the Softdevice?  Any chance that this will be implemented in the next Softdevice version?
Thanks for help
Hardy
