Hi!
I have an issue with log-entrys disappearing seemingly at random. Not super frequent and possibly (but not confirmed) more often towards the beginning of a freshly started thread.
I'm using SDK 15.2.0 with soft-device s132 v6.0.0
A stripped down version of my code:
void vApplicationIdleHook( void )
vTaskResume(m_logger_task);
static void logger_task(void * arg)
UNUSED_PARAMETER(arg);
while (1)
NRF_LOG_FLUSH();
vTaskSuspend(NULL); // Suspend myself
static void some_task(void * arg)
NRF_LOG_INFO("some_task 1");
do_stuff();
NRF_LOG_INFO("some_task 2");
while(1)
do_more_task_stuff()
uint32_t err_code = NRF_LOG_INIT(NULL);
NRF_LOG_INFO("Main 1");
xTaskCreate(logger_task, "LOGGER", 1024, NULL, 1, &m_logger_task)
xTaskCreate(some_task, "SOME_TASK", 1024, NULL, 1, &m_some_task)
... //Multiple other tasks are also started and they also log
xTaskCreate(other_task, "OTHER_TASK", 1024, NULL, 1, &m_other_task)
vTaskStartScheduler();
for (;;)
APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
I would expect to get
"Main 1"
"some_task 1"
"some_task 2"
But sometimes I just get
"Main 1"
"some_task 2"
Just like the first prints from "some_tasks" get eaten. However the logs from "Main" never seem to get lost.
So I did some digging into the log-code. It seems as the NRF_LOG_DEBUG() macro trough a series of expansions ends up at
nrf_log_frontend.c:536 std_n() functionstatic inline void std_n(uint32_t severity_mid, char const * const p_str, uint32_t const * args, uint32_t nargs) { uint32_t mask = m_log_data.mask; uint32_t wr_idx; if (buf_prealloc(nargs, &wr_idx, true)) { // Proceed only if buffer was successfully preallocated. uint32_t data_idx = wr_idx + HEADER_SIZE; uint32_t i; for (i = 0; i < nargs; i++) { m_log_data.buffer[data_idx++ & mask] =args[i]; } std_header_set(severity_mid, p_str, nargs, wr_idx, mask); } if (m_log_data.autoflush) { NRF_LOG_FLUSH(); } }
That function seems to directly manipulate the global singleton m_log_data object and I cannot se any mutexes or other locking mechanisms.
Cannot se any locking in the
nrf_log_frontend_dequeue()
function either (seems to be where the logging threads macro expansion of "NRF_LOG_FLUSH()" ends up).
So my questions are:
1. Am I missing something or are the logging functions simply not thread safe? The documentation specifically says that non-defered mode is not thread-safe. But is says nothing about defered mode (which is what I'm using).
2. Could it be something else that I'm doing wrong? Am I the only one with this issue?
