Hello -
We are using SDK 15.3.0, FreeRTOS and the nRF52840-DK board with SES. We implemented wakeup from System Off sleep using the nrf_gpio_cfg_sense_input() API, which seems to work:
nrf_gpio_cfg_sense_input(pin, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
When we run our debug build and wakeup from System Off sleep by pressing the button, the debugger breaks at address 0x00000A80, the third line of assembly below:
BF20 wfe E7FD b 0x00000A7C 4B06 ldr r3, [pc, #24]
Pressing the continue button in SES also works as expected. The app restarts and the reset cause is correct.
But when I run the same basic flow using the SDK ram_retention app, which isn't running FreeRTOS, the app breaks at the Reset_Handler after pressing the button. Our .emProject file is configured for the Reset_Handler entry point:
gcc_entry_point="Reset_Handler"
Is there another configuration option to make a FreeRTOS app break in the Reset_Handler under these circumstances? It seems that the reset handler gets invoked before main().
Brian
