pstorage update problem-call back is not getting called
Hello Everyone , I am using ble stack S110 , BATTERY SERVICE , my CUSTOM SERVICE and pstorage module in my application and using SDK 7.0.0 and keil 5.12 IDE .whenever a server writes anything to a client characteristic data sent by a server shud be written to flash. I am not using device manager init in my application. Following is my main code.
    // Initialize.
    ble_stack_init();
    timers_init();
    APP_GPIOTE_INIT(1);
   uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, APP_TIMER_TICKS(100, APP_TIMER_PRESCALER), bsp_evt_handler);
		therapy_init();
    //device_manager_init();
    gap_params_init();
    advertising_init();
    services_init();
    sensor_sim_init();
    conn_params_init();
    // Start execution.
    application_timers_start();
    advertising_start();
   pstorage_initialization();
   pstorage_read_block();
   therapy_parameters_read();
    // Enter main loop.
    for (;;)
        power_manage();
I am initializing ble_stack_init() before pstorage_init as mentioned in some post. my pstorage_read,write and update works properly if called just after pstorage_initialization(). but when i call pstorage_write or pstorage_update in my event handler as given below
void  on_write_mode_handler(ble_thes_t * p_thes , uint8_t *data)
		therapy_parameters_write();
		pstorage_update_block();
it never return from pstorage_update_block and same case if i use write function below is a code snippet.
static void example_cb_handler(pstorage_handle_t  * handle,
															 uint8_t              op_code,
                               uint32_t             result,
                               uint8_t            * p_data,
                               uint32_t             data_len)
		switch(op_code)
			case PSTORAGE_LOAD_OP_CODE:
				 if (result == NRF_SUCCESS)
					if(handle->block_id == pstorage_wait_handle)
							pstorage_wait_flag = 0;
						}  //If we are waiting for this callback, clear the wait flag.
			case PSTORAGE_STORE_OP_CODE:
			case PSTORAGE_UPDATE_OP_CODE:
			case PSTORAGE_CLEAR_OP_CODE:
			case PSTORAGE_ERROR_OP_CODE:
void pstorage_initialization()
		retval = pstorage_init();
		if(retval != NRF_SUCCESS)
				nrf_gpio_pin_clear(LED_4);
		param.block_size  = 16;                   //Select block size of 16 bytes
		param.block_count = 1;                   //Select 10 blocks, total of 160 bytes
		param.cb          = example_cb_handler;   //Set the pstorage callback handler
		retval = pstorage_register(&param, &handle);
		if (retval != NRF_SUCCESS)
				nrf_gpio_pin_set(LED_4);
uint32_t pstorage_write_block(void)
	int i;
		//Get block identifier
	pstorage_block_identifier_get(&handle, 0, &block_0_handle);
		pstorage_clear(&block_0_handle, 16);                     //Clear 48 bytes
		pstorage_wait_handle = block_0_handle.block_id;            //Specify which pstorage handle to wait for
		pstorage_wait_flag = 1;                                    //Set the wait flag. Cleared in the example_cb_handler
		//Store data to block. Wait for the last store operation to finish before reading out the data.
		pstorage_store(&block_0_handle, source_data_0, 16, 0);     //Write to flash, only one block is allowed for each pstorage_store command
		//while(pstorage_wait_flag) { power_manage(); }              //Sleep until store operation is finished.
		for(i=0; i < 1000;i++)
void pstorage_read_block()
		//Get block identifiers
		pstorage_load(dest_data_0, &block_0_handle, 16, 0);				 //Read from flash, only one block is allowed for each pstorage_load command
void pstorage_update_block(void)
	int i;
		retval = pstorage_block_identifier_get(&handle, 0, &block_0_handle);
		retval = pstorage_update(&block_0_handle, source_data_0, 16, 0);    //update flash block 0
			}              //Sleep until update operation is finished.
what i observed after debugging it doesnt come to the callback handler. i am not getting the reason for it. can anyone please check if any mistake is there in my code or some other issue. as my mentioned in some other post that there is bug in pstorage.c file so i have change it to this :
if (m_cmd_queue.count > 0)
        retval = cmd_process();
        if (retval != NRF_ERROR_BUSY) {
     app_notify (retval);
} else  {
     // In case of busy next trigger will be a success or a failure event.
     retval = NRF_SUCCESS;
        // No flash access request pending.
from line no 370 to end of the function of file pstorage.c .
Please do have a look. Thanks & Regards.
  • Could you upload your complete project so I can test it here?
  • I'm not sure, but I think there's a chance you're seeing "starvation" of a shared resource. (Perhaps Petter can quickly confirm/deny).
    From a soft radio callback (on_write_mode_handler()) you're calling:
        while(pstorage_wait_flag) { power_manage();}               //Sleep until update operation is finished.
    Essentially it is stuck in the callback until pstorage_wait_flag is cleared. But the pstorage_wait_flag is cleared in another callback (example_cb_handler()). If the initial callback (on_write_mode_handler()) has a higher priority or even if they are resolved in first-come-first-serve order, the example_cb_handler() callback will never get a chance to run and never be able to update the flag that pstorage_update_block() is waiting on.
    I don't think there's any need to do the "while(pstorage_wait_flag) { power_manage();}" in pstorage_update_block(). I think the only reasons you would need to wait are:
    1. If you want to read data and there are pending operations on the same block.
    2. If the pstorage command queue is full.
    3. If you want to modify the data buffer that you passed to pstorage_update() or pstorage_store(), you should wait for the update or store to complete.
  • Thanks bill for your reply. according to your 3rd point i shud wait for update or store to complete. is there any other way to know if this operation is complete or not , one way i know is callback handler which is i am using , but its not working as i mentioned . is there any other way out.
    Thanks & Regards Asma
  • One approach:
    You could remove the delay loop from pstorage_update_block(). You could change on_write_mode_handler() so it starts a recurring timer with a short delay. When the timer is completed, it's callback checks to see that all pending writes are done. If so, it does therapy_parameters_write(), pstorage_update_block(), and cancels the timer. Otherwise it just delays and checks again.
    There are a lot of variations on this approach. I just tried to describe a technique that takes minimal code.
    On a related note, it might be worth looking into the time required for a flash update. You might be able to show that events will always be far enough apart that all writes will be completed before the next could possibly be requested.
  • I know this is a bit late; but you might experience the same problem as we do. We use SDK 7.1.0 since we use nRF51 V2.
    In pstorage_sys_event_handler it clears m_cmd_queue.flash_access = false regardless of what message it receives. This makes pstorage.c go kawonga and you don't receive your callback.
    We solved the problem by only invoking pstorage_sys_event_handler for flash events.
    Also, just a stupid thought... Did you remember to declare pstorage_wait_flag volatile?
    static void sys_evt_dispatch(uint32_t sys_evt)
        switch (sys_evt)
        case NRF_EVT_FLASH_OPERATION_SUCCESS:
        case NRF_EVT_FLASH_OPERATION_ERROR:
            pstorage_sys_event_handler(sys_evt);
            // No implementation needed.
