I would like to send TCP message with 50KB message size.
I saw that maximum size was limited by CONFIG_HEAP_MEM_POOL_SIZE which was 16kB.
Is there any way to send that message ?
Assuming you can build/hold your entire message in RAM ready to go, TCP doesn't explicitly distinguish packets at the application layer, so you can send it as a bunch of smaller chunks back-to-back. Something like this:
int socket_write(int sock, const u8_t *data, u32_t datalen)
u32_t offset = 0U;
int ret;
while (offset < datalen)
ret = send(sock, data + offset,
MIN(2048, (datalen - offset)), 0);
if (ret < 0)
return -errno;
offset += ret;
return 0;
