Hi, I'm making a device that will probably be encapsulated In silicone, which means it won't be possible to change the battery easily. It's got to connect to android and iOS phones/tablets. It only really needs to send a value to the phones once every 2 minutes, it's really a beacon but I had problems with android background scans (discussion here devzone.nordicsemi.com/.../long-running-android-scanning-in-background)
I was advised in that post to make a connection to the device
Hung Bui said:
For example you can configure a connection with 0.5 second interval and 1 minutes timeout. You can configure the slave latency so that you only need to wakeup and response to the central every 30 seconds.
I posted a supplementary question a few days ago to that original devzone question, but it wasn't noticed. I would like some help modifying an example to setup the necessary parameters since I can see that there are a lot of variables and a lot of ways to get this wrong. I think I could spend weeks experimenting with all the options so and help is greatly appreciated.
Kind Regards,
-Jason
