The 52840 timer doesn't seem to work
I started a timer on the nrf52840 and the SDK is nRF5_SDK_15.2.0_9412b96, but I haven't never receive the callback message after the time. What's the reason?The code is as follows:
void timer_clock_event_handler(nrf_timer_event_t event_type, void* p_context)
    switch(event_type)
    case NRF_TIMER_EVENT_COMPARE0:
            idle_show_time();
void timer_init(void)
uint32_t err_code = NRF_SUCCESS;
uint32_t time_ms = 1000;
uint32_t time_ticks;
nrfx_timer_config_t timer_cfg = NRFX_TIMER_DEFAULT_CONFIG;
err_code = nrfx_timer_init(&TIMER_CLOCK, &timer_cfg, timer_clock_event_handler);
time_ticks = nrfx_timer_ms_to_ticks(&TIMER_CLOCK, time_ms);
nrfx_timer_extended_compare(&TIMER_CLOCK, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    uint8_t t = 0;
    gpio_output_voltage_setup_3v3();
    nrf_gpio_cfg_input(BUTTON_1,NRF_GPIO_PIN_PULLUP);
    uart_config();
    LCD_Init();
    sys_date_time_init();
    nrf_gpio_cfg_output(LED_1);
    nrf_gpio_pin_set(LED_1);
    POINT_COLOR=RED;
    BACK_COLOR=GBLUE;
    idle_show_clock_background();
    idle_show_time();
    timer_init();
    nrfx_timer_enable(&TIMER_CLOCK);
