SPI example: MOD BLOCK Register Adress
Hey guys,
I'm working with a Laird BL652-DVK (nrF 52832 - Chip) and Nordic SDK v.14.2.0. Now I try the SPI example and I don't know which register is adressed in the last line? I can't find it in LIS3DH-Datasheet (accelerometer).
//MOD BLOCK FOR NEW REG
static uint8_t       m_config_buf1[] = {0x20,0x97};   //CTRL_REG1: 9 = normal power mode (1.344kHz), Low-power Mode (5.376kHz); 7 = Z-,Y-,X-axis enable
static uint8_t       m_config_buf2[] = {0x23,0x88};   //CTRL_REG4: 8 = output registers not updated until MSB and LSB reading; 8 = high-resolution output mode enabled
static uint8_t       m_config_buf3[] = {0x22,0x10};   //CTRL_REG3: 1 = ZYXDA interrupt on INT1 enable
static uint8_t       m_config_buf4[] = {0x1F,0x80};   //TEMP_CFG_REG: 8 = ADC enabled
static uint8_t       m_config_buf5[] = {0x23,0x88};   //CTRL_REG4: 8 = output registers not updated until MSB and LSB reading; 8 = high-resolution output mode enabled
static uint8_t       m_config_buf6[] = {0xA3,0x00};  //???
Thanks in advance,
Christoph
