NRF_BLE_FREERTOS_SDH_TASK_STACK not enough
I have faced a lot of issues that were causing hardfault on my device. I'm using FreeRTOS with nrf52. I was suspecting stack overflow but it wasn't so easy to identify. When i have introduced the bonding, the issue occured more often and by exploring the stack and going back into the upper address i think i found out what it is. Indeed, i think the soft device stack size is not enough. It has been set to 256 bytes in nrf_sdh_freertos.c file (NRF_BLE_FREERTOS_SDH_TASK_STACK)
I have tested by setting it at 512 bytes and all issues disappeared.
Am i right ? Is someone else facing the same issue ?
Aurélien
  • Yes, I had to do the same thing with my project.
    You can configure FreeRTOS to help catch stack overflows in your FreeRTOSConfig.h. For example, I use:
    #define configCHECK_FOR_STACK_OVERFLOW  ( DEBUG ? 2: 0 )
    You can also measure the stack high water mark. For example, in nrf_sdh_freertos.c's softdevice_task I have a snippet to measure:
    #if DEBUG
            UBaseType_t uxHighWaterMark;
            uxHighWaterMark = uxTaskGetStackHighWaterMark( m_softdevice_task );
            NRF_LOG_INFO("BLE HWM = %u", uxHighWaterMark);
    thank you very much for the reply. Since i have made the modification, my device has never been more stable than right now.
    Thank you for all tips you give for debug, it will help me for sure ;)
    Aurélien
