Hi there,
I'm trying to use serial library from SDK to interact with cellular modem (AT commands, not nRF9160). I've read documentation (library description, api). May be it is obvious, but I didn't have any experience with UART before at all, I don't understand scenario of using this library in asynchronous way. Examples show synchronous interaction.
I'd done some experiments, and implemented so (read from serial byte by byte and process it, it doesn't seem correct. I don't understand how should it work. How to use queues and buffers):
NRF_SERIAL_DRV_UART_CONFIG_DEF(uarte0_drv_config,
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
NRF_UART_HWFC_ENABLED,
NRF_UART_PARITY_EXCLUDED,
NRF_UART_BAUDRATE_115200,
UART_DEFAULT_CONFIG_IRQ_PRIORITY);
#define SERIAL_FIFO_TX_SIZE 256
#define SERIAL_FIFO_RX_SIZE 256
NRF_SERIAL_QUEUES_DEF(serial0_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
#define SERIAL_BUFF_TX_SIZE 1
#define SERIAL_BUFF_RX_SIZE 1
NRF_SERIAL_BUFFERS_DEF(serial0_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
static void serial_sleep_handler(void);
static void serial_event_handler(nrf_serial_t const *p_serial, nrf_serial_event_t event);
NRF_SERIAL_CONFIG_DEF(serial0_config, NRF_SERIAL_MODE_DMA,
&serial0_queues, &serial0_buffs, serial_event_handler, serial_sleep_handler);
NRF_SERIAL_UART_DEF(serial0_uarte, 0);
__WFE();
__SEV();
__WFE();
sstatic void serial_event_handler(nrf_serial_t const *p_serial, nrf_serial_event_t event)
static ret_code_t ret;
static uint8_t data, prev_data = NULL;
switch (event)
case NRF_SERIAL_EVENT_TX_DONE:
// count bytes of request and switch at parser module to recieving state at the end
case NRF_SERIAL_EVENT_RX_DATA:
ret = nrf_queue_generic_pop(p_serial->p_ctx->p_config->p_queues->p_rxq,
&data,
false);
APP_ERROR_CHECK(ret);
// process data byte by byte
case NRF_SERIAL_EVENT_DRV_ERR:
case NRF_SERIAL_EVENT_FIFO_ERR:
// reset at parser module
If I change ```SERIAL_BUFF_RX_SIZE``` to 2 or more, I will not receive rx_data event until buffer is not full.
Could somebody explain, how to implement it in right way? May be some tutorials or videos about it.
Thanks in advance.
