I'm writing a central application for the nRF9160 DK. The central connects to an nRF52832 peripheral and subscribes to a characteristic whose CCCD handle and value handle is known prior to connecting. It does not perform service discovery. In the connected callback, where the BLE examples normally perform service discovery, I perform a call to bt_gatt_subscribe
like this:
static struct bt_gatt_subscribe_params param = { .notify = on_notification_received, .value = BT_GATT_CCC_NOTIFY, .ccc_handle = 0x002E, .value_handle = 0x002D }; int err = bt_gatt_subscribe(conn, ¶m); if (err) { printk("Subscribe failed (err %d)\n", err); }
In the peripheral, I see the central connecting and subscribing without issues. Shortly after writing the CCCD, The nRF9160 fails an assert:
[00:00:06.259,887] <dbg> bt_att.bt_att_accept: conn 0x200209c0 handle 0 [00:00:06.267,120] <dbg> bt_att.bt_att_connected: chan 0x20020b14 cid 0x0004 [00:00:06.281,982] <dbg> bt_att.bt_att_req_send: conn 0x200209c0 req 0x20036fcc [00:00:07.457,641] <dbg> bt_att.att_send_req: req 0x20036fcc [00:00:07.471,984] <dbg> bt_att.bt_att_req_send: conn 0x200209c0 req 0x20036fcc [00:00:07.480,438] <dbg> bt_att.bt_att_recv: Received ATT code 0x02 len 2 [00:00:07.487,792] <dbg> bt_att.att_mtu_req: Client MTU 185 [00:00:07.493,927] <dbg> bt_att.att_mtu_req: Server MTU 23 [00:00:07.499,969] <dbg> bt_att.att_mtu_req: Negotiated MTU 23 [00:00:07.562,042] <dbg> bt_att.att_req_sent: conn 0x200209c0 att 0x20020b14 att->req 0x20036fcc [00:00:07.571,411] <dbg> bt_att.att_pdu_sent: conn 0x200209c0 att 0x20020b14 [00:00:07.611,907] <dbg> bt_att.att_rsp_sent: conn 0x200209c0 att 0x20020b14 [00:00:07.619,537] <dbg> bt_att.att_pdu_sent: conn 0x200209c0 att 0x20020b14 [00:00:07.627,319] <dbg> bt_att.bt_att_recv: Received ATT code 0x13 len 0 [00:00:07.634,674] <dbg> bt_att.att_handle_write_rsp: [00:00:07.640,350] <dbg> bt_att.att_handle_rsp: err 0x00 len 0: [00:00:07.646,942] <dbg> bt_att.att_req_destroy: req 0x20036fcc [00:00:07.653,411] <dbg> bt_att.att_process: ASSERTION FAIL [req->func] @ <zephyr sdk>/subsys/bluetooth/host/att.c:301 [00:00:06.108,734] <err> os: r0/a1: 0x00000004 r1/a2: 0x0000012d r2/a3: 0x00000001 [00:00:06.117,584] <err> os: r3/a4: 0x00011069 r12/ip: 0x000003e8 r14/lr: 0x00016991 [00:00:06.126,434] <err> os: xpsr: 0x61000000 [00:00:06.131,774] <err> os: s[0]: 0x00000000 s[1]: 0x00000000 s[2]: 0x00000000 s[3]: 0x00000000 [00:00:06.142,150] <err> os: s[4]: 0x00000000 s[5]: 0x00000000 s[6]: 0x00000000 s[7]: 0x00000000 [00:00:06.152,526] <err> os: s[8]: 0x00000000 s[9]: 0x00000000 s[10]: 0x00000000 s[11]: 0x00000000 [00:00:06.163,116] <err> os: s[12]: 0x00000000 s[13]: 0x00000000 s[14]: 0x00000000 s[15]: 0x00000000 [00:00:06.173,858] <err> os: fpscr: 0x00000000 [00:00:06.179,260] <err> os: Faulting instruction address (r15/pc): 0x0002ee10 [00:00:06.187,316] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic [00:00:06.194,396] <err> os: Current thread: 0x20026884 (unknown) [00:00:06.201,293] <err> os: Halting system
When stepping through the code, I see that att_send_req()
is called twice, and __ASSERT_NO_MSG(req->func)
fails the second time around. This is the call stack just before the assert fails:
att_send_req@0x00016974 (<zephyr sdk>/subsys/bluetooth/host/att.c:301)
att_process@0x00016b06 (<zephyr sdk>/subsys/bluetooth/host/att.c:335)
att_handle_rsp@0x00016b06 (<zephyr sdk>/subsys/bluetooth/host/att.c:379)
bt_att_recv@0x00017470 (<zephyr sdk>/subsys/bluetooth/host/att.c:1979)
l2cap_chan_recv@0x0002fc58 (<zephyr sdk>/subsys/bluetooth/host/l2cap.c:1664)
l2cap_rx_process@0x0002fc58 (<zephyr sdk>/subsys/bluetooth/host/l2cap.c:274)
z_work_q_main@0x0002ea94 (<zephyr sdk>/lib/os/work_q.c:32)
z_thread_entry@0x0002ea5c (<zephyr sdk>/lib/os/thread_entry.c:29)
??@0xe8040000 (Unknown Source:0)
This is my prj.conf for those interested:
CONFIG_NEWLIB_LIBC=y CONFIG_ASSERT=y CONFIG_REBOOT=y CONFIG_LOG=y CONFIG_LOG_IMMEDIATE=y CONFIG_HW_STACK_PROTECTION=y CONFIG_STACK_SENTINEL=y # Network CONFIG_NETWORKING=y CONFIG_NET_NATIVE=n CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_SOCKETS_POSIX_NAMES=y CONFIG_SNTP=y CONFIG_SNTP_LOG_LEVEL_DBG=n CONFIG_NET_LOG=n # LTE link control CONFIG_LTE_LINK_CONTROL=y CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG=n # LTE network configuration CONFIG_LTE_AUTO_INIT_AND_CONNECT=n CONFIG_LTE_NETWORK_USE_FALLBACK=y CONFIG_LTE_NETWORK_TIMEOUT=120 # AT stuff CONFIG_AT_HOST_LIBRARY=y CONFIG_AT_CMD=y CONFIG_AT_CMD_LOG_LEVEL_DBG=n # Modem info CONFIG_MODEM_INFO=n # BSD library CONFIG_BSD_LIBRARY=y # Disable Modem traces, since we need UART1 for HCI CONFIG_BSD_LIBRARY_TRACE_ENABLED=n # Enable Bluetooth stack, libraries and UART CONFIG_BT=y CONFIG_BT_H4=y CONFIG_BT_WAIT_NOP=y CONFIG_BT_CENTRAL=y CONFIG_BT_GATT_CLIENT=y CONFIG_BT_GATT_DM=y CONFIG_BT_SCAN=y CONFIG_BT_SCAN_FILTER_ENABLE=y CONFIG_BT_SCAN_UUID_CNT=1 CONFIG_UART_2_NRF_UARTE=y CONFIG_UART_2_NRF_FLOW_CONTROL=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_BT_RX_STACK_SIZE=16384 CONFIG_BT_HCI_TX_STACK_SIZE=16384 CONFIG_BT_DEBUG_LOG=y CONFIG_BT_DEBUG_ATT=y # Heap and stacks CONFIG_HEAP_MEM_POOL_SIZE=16384 CONFIG_MAIN_STACK_SIZE=16384
I posted this on the Zephyr slack channel and was suggested to post here as well, in case this is an issue that has been fixed in Zephyr master but not in Nordic's fork. I'm on NCS v2.0.99-ncs1. I know this is a strange use-case (subscribing without service discovery), but I don't see any reason it would not work. The same procedure works on the nRF SDK v15.0.0.
EDIT: If i perform service discovery after connecting and subscribe from the discovery_completed callback using the same hard-coded handles, the assert does not fail.
Any help is appreciated!
