nrf9160 DK serial send - recieve buffer
Hello guys,
I wan`t to make an project that send trough serial port a new image to flash my nrf9160.
By the moment I managed to send and recieve data but only on uart0.
So if someone could explain me a little more what is hapening and how can i fix next issues i`m stuck with:
1. When I send a buffer from my python script ( on COM port that coresponds to uart0) I recieve only byte by byte not the whole string at once.
2. When I send back and string to the same port my soft goes in a infinite loop that sends the same message.
3. When I try to use uart1 I see no activity on none of 3 COM ports that are assigned to the pc when I connect my board.
Here is the code I`m using for uart :
in main() :
uart = device_get_binding("UART_0");
if (!uart)
printk("Herror\r\n"); // error happens.
uart_irq_callback_set(uart, uart_cb);
uart_irq_rx_enable(uart);
printk("UART loopback start!\n");
callback() :
static void uart_cb(struct device *x)
uart_irq_update(x);
int data_length = 0;
if (uart_irq_rx_ready(x)) {
data_length = uart_fifo_read(x, uart_buf, sizeof(uart_buf));
uart_buf[data_length] = 0;
and function used to send over uart:
void uart_sendCOM(struct device *x, u8_t *Cont)
u16_t len = strlen(Cont);
uart_fifo_fill(x, Cont,len );
uart_irq_tx_enable(x);
Thank you for help.
  • I tried another, more simple aproach :
    void uart_sendCOM(struct device *x)
       k_sleep(1000);
       uart_fifo_fill(x, "test\r", strlen("test\r"));
         uart_irq_update(x);
           data_length = uart_fifo_read(x, &uart_buf[uart_buff_len], sizeof(uart_buf));
           uart_buff_len += data_length;
     if (uart_buff_len == UART_BUFF_MAX_SIZE || uart_buf[uart_buff_len - 1] == '\n' || uart_buf[uart_buff_len - 1] == '\r')
        uart_buff_len = 0;
    In main() I have :
    if (!uart)
    The problem is that recieve works good, but send part is not working...
  • Hi! Could you send me your prj.conf file, thanks!
    Heidi
  • Hi, thank you for help, i managed to make it work now :) the problem was in my python script i was using for serial communication.
    Cojocari Adrian
