Hi Nordic Forum!
I'm currently developing a CLI controlled BLE scanner using the nRF52840 Dongle.
Essentially I brought over the CLI example and adapted it to the a central/scanner code, I did this mostly to have logs on the Dongle (since it doesn't have a debugger), but also to add the possibility to control the application over the command line.
Thing work for the most part, but when I log things to the terminal, the formatting is a big off, as seen here:
When I press tab the available commands are shown like in the picture, and every NRF_LOG call adds that header before.
Initially I thought was the CLI colour option but I disable it, similar with the logger timestamp. When I run the CLI commands, the text is show without any header.
Any idea how to remove this?
I'm using SDK Version 16, using make/GCC as toolchain and using the CoolTerm terminal on macOS 10.14.6
Thanks in advance.
