Hi, I am working with the adxl362 sensor and the nrf9160 SPI example (https://github.com/Rallare/fw-nrfconnect-nrf/blob/nrf9160_samples/samples/nrf9160/spi/src/main.c) and I am already able to read the register with this code:
void spi_read_reg(void)
u8_t cmd = 0x0B;
u8_t reg_addr = 0x20;
u8_t value = 0x00;
void *data = &value;
int length = 1;
u8_t access[2] = { cmd, reg_addr };
gpio_pin_write(cs_gpio, cd_pin, 0);
const struct spi_buf buf[2] = {
.buf = access,
.len = 2
.buf = data,
.len = length
struct spi_buf_set tx = {
.buffers = buf,
const struct spi_buf_set rx = {
.buffers = buf,
.count = 2
tx.count = 1;
int spi_result = spi_transceive(spi_dev, &spi_cfg, &tx, &rx);
// printk("SPI result: %d\n",spi_result);
printk("Value: 0x%02X\n", value);
gpio_pin_write(cs_gpio, cd_pin, 1);
Now I wanted to try to write the 0x20 (Lower Threshold) with the value 0x0F with the code below.
void spi_test_send(void)
int err;
static u8_t tx_buffer[1] = {0x0F};
static u8_t rx_buffer[2]= {0x0A, 0x20};
const struct spi_buf tx_buf = {
.buf = tx_buffer,
.len = sizeof(tx_buffer)
const struct spi_buf_set tx = {
.buffers = &tx_buf,
.count = 1
struct spi_buf rx_buf = {
.buf = rx_buffer,
.len = sizeof(rx_buffer),
.buffers = &rx_buf,
.count = 1
err = spi_transceive(spi_dev, &spi_cfg, &tx, &rx);
if (err) {
printk("SPI error: %d\n", err);
} else {
/* Connect MISO to MOSI for loopback */
printk("TX sent: %x\n", tx_buffer[0]);
printk("RX recv: %x\n", rx_buffer[0]);
When I read the register after writing, I get a different value than 0x0F.
I think that these two lines are not correct:
But I don't know how to fix them.
Do you have any idea what could be the problem or do you have an example code?
Thanks for your help and your answers!
