switching beacon mode to pairing/connectable mode without module reset nRF52832
I am a newbie and need some help deciding the path to perform the following requirement. Any help is appreciated.
 Requirement:
I have Rigado BMD-350 module currently advertising in beacon mode.
I would like to switch from beacon mode to connectable BLE mode (pairing mode) when a cell phone comes close to it and would like to connect.
Once connection is established, I would like to receive data from the cell phone and store it. and then close the connection and move back to beacon mode.
BMD-350 comes with BMDware which is out of date and is no longer supported. Instead, I would like to write open source code for nrf52832 (nrf module in BMD-350) to achieve the above requirement.
What is the best path to go about this requirement. Also which soft device is recommended?
Thank you
  • "micro-ecc not found! Let's pull it from HEAD."
    Cloning into 'micro-ecc'...
    remote: Enumerating objects: 1086, done.
    remote: Total 1086 (delta 0), reused 0 (delta 0), pack-reused 1086
    Receiving objects: 100% (1086/1086), 647.94 KiB | 2.85 MiB/s, done.
    Resolving deltas: 100% (637/637), done.
    'make' is not recognized as an internal or external command,
    operable program or batch file.
    Please run the script from a command line instead of double-clicking. When you double click it will close like this when there is an error, not giving you time to read it.
    It is not the Makefile that should be in your path, it is the make utility. You should get make from somewhere, and put it in your windows path. For instance using Gow, or some other distribution og GNU tools.
