I want to use two UARTS ie uart0 and uart1. I read that nrf51822 gpio pins can be set as rx & tx but i couldnt find any example.
I am using SDK12.3
Please attach some links for same.
I am using SDK12.3
two uarts in ble_peripheral -> ble_app_uart example.
The nRF51x22 only has one UART peripheral, as per the product specification. RXD and TXD can be assigned to any unused GPIO of your choice.
If you need a second UART, you have to implement a bit banged UART (a software implemented uart using GPIOs). Unfortunately, we do not have any implementations of this available, but it is however been discussed on the forum before. Try searching for "bit bang uart" and you should find some threads on this.
Note that nRF52840 has two hardware UARTE peripherals, so you could move to that device if your application require this.
Håkon
Can you attach a example of how to assign RXD and TXD pins to GPIO pins.
Please see the example \nRF5_SDK_12.3.0_d7731ad\examples\peripheral\uart.
In main.c, there's a uart init function call:
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
APP_UART_FLOW_CONTROL_ENABLED,
false,
UART_BAUDRATE_BAUDRATE_Baud115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_error_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
You can change the define (in pca10028.h directly, or by adding your own board: https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v12.3.0/sdk_for_custom_boards.html?cp=7_5_8_1_5) or give the function a pin-number of choice.
Håkon
