DTM Command
I would like to ask two questions.
1)
I understand that the nrf52832 does not support the feature "Transmitter has a Stable Modulation Index".
But the component "ble_dtm.c" in the nRF52 SDK(version 15.3)  returns the value "0x0006" in the LE_Test_Status event.
According to "Direct Test Mode" in the Bluetooth specification(BLUETOOTH CORE SPECIFICATION Version 5.1 ),
bit2 and bit3 indicates these meanings. The component "ble_dtm.c" is correct?
bit2:LE 2M PHY supported
bit3:Transmitter has a Stable Modulation Index
-- ble_dtm.c --
else if (freq == LE_TEST_SETUP_READ_SUPPORTED)
       if (length != 0x00)
             m_event = LE_TEST_STATUS_EVENT_ERROR;
             return DTM_ERROR_ILLEGAL_CONFIGURATION;
       // 0XXXXXXXXXXX0110 indicate that 2Mbit and DLE is supported and stable modulation is not supported (No nRF5 device supports this).
       m_event = 0x0006;
2)
Also, I understand that nrf52832 supports the LE Data Packet Length Extension and does not support LE Coded PHY.
According to "Link Layer Specification" in the Bluetooth specification, if the device supports "LE Data Packet Length Extension feature" and does not support "LE Coded PHY feature",
Parameters with names ending in "Octets" need to have the range "27 - 251", Parameters with names ending in "Time" needs to have the range "328 - 2120".
But the component "ble_dtm.c" in the nRF52 SDK(version 15.3)  returns the value "0x01FE(decimal:510)" for Parameters with names ending in "Octets" and
returns "0x4290(decimal:17040)" for Parameters with names ending in "Time".
-- ble_dtm.c --
else if (freq == LE_TEST_SETUP_READ_MAX)
      // Read max supported value.
      switch (length)
             case 0x00:
                      // Read supportedMaxTxOctets
                      m_event = 0x01FE;
            case 0x01:
                     // Read supportedMaxTxTime
                    m_event = 0x4290;
            case 0x02:
                   // Read supportedMaxRxOctets
                  m_event = 0x01FE;
            case 0x03:
                  // Read supportedMaxRxTime
                 m_event = 0x4290;
Best Regards,
Manabu
