Continue problems with Sogger SDK on MacOs
Hello
I try to open a nRF project on a MacOs with the correct installation of all the toolchain and zephir. However during the configure I have always problems one solved new one appears.
My last output is
Loading solution mqtt_simple.emProject
Executing load commands
/usr/local/bin/cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=/Users/fred/Nordic/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/Users/fred/Nordic -B/Users/fred/Nordic/ncs/nrf/samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns -H/Users/fred/Nordic/ncs/nrf/samples/nrf9160/mqtt_simple -DPYTHON_EXECUTABLE=/usr/local/bin/python3 -DCMAKE_MAKE_PROGRAM=/usr/local/bin/ninja -DDTC=/usr/local/bin/dtc -D WEST=~/Library/Python/3.7/bin/west -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=/Users/fred/Nordic/arm_segger_embedded_studio/html/configure_nordic_project_menuconfig.py
Zephyr version: 2.1.0
-- Selectfreded BOARD nrf9160_pca10090ns
-- Found west: /Users/fred/Library/Python/3.7/bin/west (found suitable version "0.6.3", minimum required is "0.6.0")
-- Loading /Users/fred/Nordic/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
nrf9160_pca10090ns.dts.pre.tmp:89.42-101.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000)
nrf9160_pca10090ns.dts.pre.tmp:338.19-344.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
Devicetree configuration written to /Users/fred/Nordic/ncs/nrf/samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns/zephyr/include/generated/generated_dts_board.conf
/Users/fred/Nordic/ncs/nrf/samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns/zephyr/.config:213: warning: attempt to assign the value 'n' to the undefined symbol NRFXLIB_NFC
/Users/fred/Nordic/ncs/nrf/samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns/zephyr/.config:316: warning: attempt to assign the value 'n' to the undefined symbol NRFX_SWI
/Users/fred/Nordic/ncs/nrf/samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns/zephyr/.config:541: warning: attempt to assign the value 'y' to the undefined symbol DATA_ENDIANNESS_LITTLE
/Users/fred/Nordic/ncs/nrf/samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns/zephyr/.config:581: warning: attempt to assign the value 'y' to the undefined symbol LDREX_STREX_AVAILABLE
/Users/fred/Nordic/ncs/nrf/samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns/zephyr/.config:607: warning: attempt to assign the value 'n' to the undefined symbol X86_64
Parsing Kconfig tree in /Users/fred/Nordic/ncs/nrf/samples/nrf9160/mqtt_simple/Kconfig
/Users/fred/Nordic/ncs/mcuboot/zephyr/Kconfig:37: WARNING: dt_int_val is deprecated.
Loaded configuration '/Users/fred/Nordic/ncs/nrf/samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns/zephyr/.config'
/Users/fred/Nordic/ncs/nrf/samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns/zephyr/.config:1140: warning: attempt to assign the value 'y' to the undefined symbol HAS_CMSIS
/Users/fred/Nordic/ncs/nrf/samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns/zephyr/.config:1169: warning: attempt to assign the value 'n' to the undefined symbol LINK_WHOLE_ARCHIVE
Error: Aborting due to non-whitelisted Kconfig warning '/Users/fred/Nordic/ncs/nrf/samples/nrf916
to the undefined symbol NRFXLIB_NFC'. Note: If this warning doesn't point to an actual problem, you
can add it to the whitelist at the top of
/Users/fred/Nordic/ncs/zephyr/scripts/kconfig/kconfig.py.
CMake Error at /Users/fred/Nordic/ncs/zephyr/cmake/kconfig.cmake:210 (message):
  command failed with return code: 1
  /Users/fred/Nordic/ncs/zephyr/cmake/app/boilerplate.cmake:461 (include)
  CMakeLists.txt:10 (include)
Project load failed
Reported error: solution load command failed (1)
Zephyr 2.11
nrf 1.1.0
Segger 4.30C
Macos High Sierra
Thanks
Federico
