BLE_HCI_CONNECTION_TIMEOUT after LL_PHY_UPDATE_IND received
We did stumble upon an issue with our BLE peripheral running on an nRF52832 with Softdevice S132 5.0.0 . The central side is implemented on top of the UWP (Universal Windows Platform) Bluetooth LE API.
The MO we observe using the nRF Sniffer is that our peripheral issues a LL_PHY_REQ (through a call to sd_ble_gap_phy_update()). After the peer responds with LL_PHY_UPDATE_IND, there is no further BLE communication until the Softdevice issues a BLE_GAP_EVT_DISCONNECTED with reason set to BLE_HCI_CONNECTION_TIMEOUT.
See for example the following excerpt from a sniffer log:
3238	61.073	Master_0xa24eb1c1	LE 1M	ATT	    11	59617	1	1	False	13	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x0001..0x0009
3239	61.074	Slave_0xa24eb1c1	LE 1M	LE LL	0	151	    1	0	False	13	Empty PDU
3240	61.075	Master_0xa24eb1c1	LE 1M	LE LL	0	59601	0	0	False	14	Empty PDU
3241	61.077	Slave_0xa24eb1c1	LE 1M	LE LL	3	150	    0	1	True	14	Control Opcode: LL_PHY_REQ
3242	61.078	Master_0xa24eb1c1	LE 1M	LE LL	0	150	    1	1	False	14	Empty PDU
3243	61.180	Master_0xa24eb1c1	LE 1M	LE LL	0	59436	1	1	True	15	Empty PDU
3244	61.181	Slave_0xa24eb1c1	LE 1M	ATT	    34	150	    1	0	False	15	Rcvd Read By Type Response, Attribute List Length: 4, Device Name, Appearance, Peripheral Preferred Connection Parameters, Central Address Resolution
3245	61.182	Master_0xa24eb1c1	LE 1M	LE LL	5	150	    0	0	False	15	Control Opcode: LL_PHY_UPDATE_IND
3246	70.839	c9:1b:a0:99:b9:f6	LE 1M	LE LL	36	9667815				0	ADV_NONCONN_IND
The issue does not always occur, but what I observed when looking at the sniffer traces is:
  • In those instances where the timeout occurs, the LL_PHY_REQ is issued while another request during service discovery is pending, e.g. a "Read by Type Request" or a "Read Information Request". I.e. the central issued this request and before the Nordic responds, our peripheral firmware triggers the LL_PHY_REQ.
  • The LL_PHY_UPDATED_IND seems to be issued in the same connection event in which the response to the pending request is issued.
  • Those instances where the procedure works flawlessly, there are no other coinciding requests requiring responses, the LL_PHY_UPDATE_IND comes in its own Connection event.
The following sniffer excerpt shows an instance where no connection timeout occurs.
2044	29.951	Master_0xaf9aba17	LE 1M	ATT	    65	89587	1	0	False	61	Sent Write Command, Handle: 0x0017 (Unknown: Unknown)
2045	29.951	Slave_0xaf9aba17	LE 1M	LE LL	3	150	0	0	    False	61	Control Opcode: LL_PHY_REQ
2046	30.052	Master_0xaf9aba17	LE 1M	LE LL	5	44145	0	1	False	62	Control Opcode: LL_PHY_UPDATE_IND
2047	30.054	Slave_0xaf9aba17	LE 1M	LE LL	0	151	1	1	    False	62	Empty PDU
2048	30.055	Master_0xaf9aba17	LE 1M	LE LL	0	44648	1	0	False	63	Empty PDU
As a workaround we will for now try to either delay the LL_PHY_REQ for a few seconds so it will not coincide with service discovery or even disable it altogether.
Do you have an idea what the cause of this problem may be?
-mike
