NRF52832 Firmware Upgrade using Esp8266
Hi Team
I am trying to implement the firmware upgrade for master controller nrf52832 on chip using esp8266 over uart and I am very new with this boot-loader part.
I had gone through many examples and trying to understand the flow from where to start. Code had already implementation of DFU using nrf connect application and working, but now I need to do this using esp8266.
My flow is I will download the hex file from the server and then upgrade the hex file form esp8266 over uart.
I had seen the examples - secure_bootloader_dfu and iot example but still not able to understand the example.
Any help or suggestion in this.
Parents Reply
  • I am trying with secure dfu serial example on nordic DK SDk 14.2., will get back to you with results.
    and my SDK version is 14.2, will this example work for 14.2 as well?
    SDK 14.2 example secure_dfu_serial is not working it is throwing error
    SEGGER/SEGGER Embedded Studio for ARM 4.18/gcc/arm-none-eabi/bin/ld: cannot find ../../../../../external/micro-ecc/nrf52hf_armgcc/armgcc/micro_ecc_lib_nrf52.a: no such file or directory.
    I am bit confused even if SDK 14.2 support serial DFU or not.
