Im developing NRF52 DK.
I'm building library C SPI mfrc522 for NRF52.
I'm implement PCD_Read and write PCD_register look OK, But i call function PICC_IsNewCardPresent() in main loop not detected NFC tag, nothing happened!!! ????
Help me. I worked for more than 2 weeks but couldn't ~.~
void PCD_WriteRegister(PCD_Register reg, byte value);
void PCD_WriteRegister_long(PCD_Register reg, byte count, byte *values);
byte PCD_ReadRegister(PCD_Register reg);
void PCD_ReadRegister_long(PCD_Register reg, byte count, byte *values, byte rxAlign); //TODO rxAlign = 0
static uint8_t m_tx_buf[2]; /**< TX buffer. */ static uint8_t m_rx_buf[1]; /**< RX buffer. */ static uint8_t m_write_buf[1]; /**< RX buffer. */ static const uint8_t m_length = 1; /**< Transfer length. */ static const uint8_t m_tx_length = 2; /**< Transfer length. */ void spi_event_handler(nrf_drv_spi_evt_t const * p_event, void * p_context) { spi_xfer_done = true; // NRF_LOG_INFO("Transfer completed."); // if (m_rx_buf[0] != 0) // { // NRF_LOG_INFO(" Received:"); // NRF_LOG_HEXDUMP_INFO(m_rx_buf,1); // } } void PCD_WriteRegister(PCD_Register reg, byte value){ nrf_gpio_pin_write(SPI_SS_PIN,0); m_tx_buf[0] = reg &0x7E; m_tx_buf[1] = value; memset(m_rx_buf, 0, m_length); spi_xfer_done = false; nrf_drv_spi_transfer(&spi,&m_tx_buf[0], m_length, NULL, 0); while (!spi_xfer_done) { __WFE(); } nrf_gpio_pin_write(SPI_SS_PIN,1); } void PCD_WriteRegister_long(PCD_Register reg, byte count, byte *values){ nrf_gpio_pin_write(SPI_SS_PIN,0); m_tx_buf[0] = reg & 0x7E; memset(m_rx_buf, 0, m_length); spi_xfer_done = false; nrf_drv_spi_transfer(&spi,&m_tx_buf[0], m_length, NULL, 0); while (!spi_xfer_done) { __WFE(); } NRF_LOG_FLUSH(); for (byte index = 0; index < count; index++) { memset(m_rx_buf, 0, m_length); spi_xfer_done = false; debug_info("long value[%d]:%x",index,values[index]); nrf_drv_spi_transfer(&spi, &values[index], m_length, NULL, 0); while (!spi_xfer_done) { __WFE(); } NRF_LOG_FLUSH(); } nrf_gpio_pin_write(SPI_SS_PIN,1); } byte PCD_ReadRegister(PCD_Register reg){ nrf_gpio_pin_write(SPI_SS_PIN,0); m_tx_buf[0] = (0x80 | (reg & 0x7E)); memset(m_rx_buf, 0, m_length); spi_xfer_done = false; nrf_drv_spi_transfer(&spi,&m_tx_buf[0], m_length, m_rx_buf, m_length); while (!spi_xfer_done) { __WFE(); } memset(m_rx_buf, 0, m_length); spi_xfer_done = false; _reg = 0x00; nrf_drv_spi_transfer(&spi,&_reg, m_length, m_rx_buf, m_length); while (!spi_xfer_done) { __WFE(); } NRF_LOG_FLUSH(); nrf_gpio_pin_write(SPI_SS_PIN,1); return m_rx_buf[0]; } void PCD_ReadRegister_long(PCD_Register reg, byte count, byte *values, byte rxAlign){ nrf_gpio_pin_write(SPI_SS_PIN,0); if (count == 0) { return; } byte address = 0x80 | (reg& 0x7E); // MSB == 1 is for reading. LSB is not used in address. Datasheet section 8.1.2.3. byte index = 0; count--; memset(m_rx_buf, 0, m_length); spi_xfer_done = false; nrf_drv_spi_transfer(&spi,&address, m_length, m_rx_buf, m_length); while (!spi_xfer_done) { __WFE(); } NRF_LOG_FLUSH(); if (rxAlign) { // Only update bit positions rxAlign..7 in values[0] // Create bit mask for bit positions rxAlign..7 byte mask = (0xFF << rxAlign) & 0xFF; // Read value and tell that we want to read the same address again. memset(m_rx_buf, 0, m_length); spi_xfer_done = false; nrf_drv_spi_transfer(&spi,&address, m_length, m_rx_buf, m_length); while (!spi_xfer_done) { __WFE(); } byte value = m_rx_buf[0]; // Apply mask to both current value of values[0] and the new data in value. values[0] = (values[0] & ~mask) | (value & mask); index++; } while (index < count) { memset(m_rx_buf, 0, m_length); spi_xfer_done = false; nrf_drv_spi_transfer(&spi,&address, m_length, m_rx_buf, m_length); while (!spi_xfer_done) { __WFE(); } values[index] = m_rx_buf[0]; index++; } memset(m_rx_buf, 0, m_length); spi_xfer_done = false; uint8_t _reg = 0x00; nrf_drv_spi_transfer(&spi,&_reg, m_length, m_rx_buf, m_length); while (!spi_xfer_done) { __WFE(); } values[index] = m_rx_buf[0]; nrf_gpio_pin_write(SPI_SS_PIN,1); }
Im include mfrc522.c mfrc522.h.
#include "mfrc522.h" #define debug_info(...) NRF_LOG_INFO(__VA_ARGS__) #define SPI_INSTANCE 0 /**< SPI instance index. */ static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE); /**< SPI instance. */ static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */ static uint8_t m_tx_buf[2];// = TEST_STRING; /**< TX buffer. */ static uint8_t m_rx_buf[1]; /**< RX buffer. */ static uint8_t m_write_buf[1]; /**< RX buffer. */ static const uint8_t m_length = 1; /**< Transfer length. */ static const uint8_t m_tx_length = 2; /**< Transfer length. */ /** * @brief SPI user event handler. * @param event */ void spi_event_handler(nrf_drv_spi_evt_t const * p_event, void * p_context) { spi_xfer_done = true; // NRF_LOG_INFO("Transfer completed."); // if (m_rx_buf[0] != 0) // { // NRF_LOG_INFO(" Received:"); // NRF_LOG_HEXDUMP_INFO(m_rx_buf,1); // } } void PCD_WriteRegister(PCD_Register reg, byte value){ nrf_gpio_pin_write(SPI_SS_PIN,0); m_tx_buf[0] = reg &0x7E; m_tx_buf[1] = value; memset(m_rx_buf, 0, m_length); spi_xfer_done = false; nrf_drv_spi_transfer(&spi,&m_tx_buf[0], m_length, NULL, 0); while (!spi_xfer_done) { __WFE(); } NRF_LOG_FLUSH(); // m_tx_buf[1] = value; // memset(m_rx_buf, 0, m_length); // spi_xfer_done = false; // // nrf_drv_spi_transfer(&spi, &m_tx_buf[1], m_length, NULL, 0); // // while (!spi_xfer_done) // { // __WFE(); // } // NRF_LOG_FLUSH(); // byte cpm = PCD_ReadRegister(reg); // if(cpm!=value) debug_info("WTF %x: %x - %x",reg>>1,cpm,value); nrf_gpio_pin_write(SPI_SS_PIN,1); } void PCD_WriteRegister_long(PCD_Register reg, byte count, byte *values){ nrf_gpio_pin_write(SPI_SS_PIN,0); m_tx_buf[0] = reg & 0x7E; memset(m_rx_buf, 0, m_length); spi_xfer_done = false; nrf_drv_spi_transfer(&spi,&m_tx_buf[0], m_length, NULL, 0); while (!spi_xfer_done) { __WFE(); } NRF_LOG_FLUSH(); for (byte index = 0; index < count; index++) { memset(m_rx_buf, 0, m_length); spi_xfer_done = false; nrf_drv_spi_transfer(&spi, &values[index], m_length, NULL, 0); while (!spi_xfer_done) { __WFE(); } NRF_LOG_FLUSH(); } nrf_gpio_pin_write(SPI_SS_PIN,1); } byte PCD_ReadRegister(PCD_Register reg){ nrf_gpio_pin_write(SPI_SS_PIN,0); m_tx_buf[0] = (0x80 | (reg & 0x7E)); memset(m_rx_buf, 0, m_length); spi_xfer_done = false; nrf_drv_spi_transfer(&spi,&m_tx_buf[0], m_length, m_rx_buf, m_length); while (!spi_xfer_done) { __WFE(); } memset(m_rx_buf, 0, m_length); spi_xfer_done = false; uint8_t _reg; _reg = 0x00; nrf_drv_spi_transfer(&spi,&_reg, m_length, m_rx_buf, m_length); while (!spi_xfer_done) { __WFE(); } NRF_LOG_FLUSH(); nrf_gpio_pin_write(SPI_SS_PIN,1); return m_rx_buf[0]; } void PCD_ReadRegister_long(PCD_Register reg, byte count, byte *values, byte rxAlign){ nrf_gpio_pin_write(SPI_SS_PIN,0); if (count == 0) { return; } byte address = 0x80 | (reg& 0x7E); // MSB == 1 is for reading. LSB is not used in address. Datasheet section 8.1.2.3. byte index = 0; count--; memset(m_rx_buf, 0, m_length); spi_xfer_done = false; nrf_drv_spi_transfer(&spi,&address, m_length, m_rx_buf, m_length); while (!spi_xfer_done) { __WFE(); } NRF_LOG_FLUSH(); if (rxAlign) { // Only update bit positions rxAlign..7 in values[0] // Create bit mask for bit positions rxAlign..7 byte mask = (0xFF << rxAlign) & 0xFF; // Read value and tell that we want to read the same address again. memset(m_rx_buf, 0, m_length); spi_xfer_done = false; nrf_drv_spi_transfer(&spi,&address, m_length, m_rx_buf, m_length); while (!spi_xfer_done) { __WFE(); } byte value = m_rx_buf[0]; // Apply mask to both current value of values[0] and the new data in value. values[0] = (values[0] & ~mask) | (value & mask); index++; } while (index < count) { memset(m_rx_buf, 0, m_length); spi_xfer_done = false; nrf_drv_spi_transfer(&spi,&address, m_length, m_rx_buf, m_length); while (!spi_xfer_done) { __WFE(); } values[index] = m_rx_buf[0]; index++; } memset(m_rx_buf, 0, m_length); spi_xfer_done = false; uint8_t _reg = 0x00; nrf_drv_spi_transfer(&spi,&_reg, m_length, m_rx_buf, m_length); while (!spi_xfer_done) { __WFE(); } values[index] = m_rx_buf[0]; nrf_gpio_pin_write(SPI_SS_PIN,1); } void PCD_ClearRegisterBitMask( PCD_Register reg, ///< The register to update. One of the PCD_Register enums. byte mask ///< The bits to clear. ) { byte tmp; tmp = PCD_ReadRegister(reg); PCD_WriteRegister(reg, tmp & (~mask)); // clear bit mask } // End PCD_ClearRegisterBitMask() void PCD_SetRegisterBitMask( PCD_Register reg, ///< The register to update. One of the PCD_Register enums. byte mask ///< The bits to set. ) { byte tmp; tmp = PCD_ReadRegister(reg); PCD_WriteRegister(reg, tmp | mask); // set bit mask } // End PCD_SetRegisterBitMask() StatusCode PCD_CalculateCRC( byte *data, ///< In: Pointer to the data to transfer to the FIFO for CRC calculation. byte length, ///< In: The number of bytes to transfer. byte *result ///< Out: Pointer to result buffer. Result is written to result[0..1], low byte first. ) { PCD_WriteRegister(CommandReg, PCD_Idle); // Stop any active command. PCD_WriteRegister(DivIrqReg, 0x04); // Clear the CRCIRq interrupt request bit PCD_WriteRegister(FIFOLevelReg, 0x80); // FlushBuffer = 1, FIFO initialization PCD_WriteRegister_long(FIFODataReg, length, data); // Write data to the FIFO PCD_WriteRegister(CommandReg, PCD_CalcCRC); // Start the calculation // Wait for the CRC calculation to complete. Each iteration of the while-loop takes 17.73μs. // TODO check/modify for other architectures than Arduino Uno 16bit // Wait for the CRC calculation to complete. Each iteration of the while-loop takes 17.73us. for (uint16_t i = 5000; i > 0; i--) { // DivIrqReg[7..0] bits are: Set2 reserved reserved MfinActIRq reserved CRCIRq reserved reserved byte n = PCD_ReadRegister(DivIrqReg); if (n & 0x04) { // CRCIRq bit set - calculation done PCD_WriteRegister(CommandReg, PCD_Idle); // Stop calculating CRC for new content in the FIFO. // Transfer the result from the registers to the result buffer result[0] = PCD_ReadRegister(CRCResultRegL); result[1] = PCD_ReadRegister(CRCResultRegH); return STATUS_OK; } } // 89ms passed and nothing happend. Communication with the MFRC522 might be down. return STATUS_TIMEOUT; } // End PCD_CalculateCRC() void PCD_AntennaOn() { uint8_t value = PCD_ReadRegister(TxControlReg); if ((value & 0x03) != 0x03) { PCD_WriteRegister(TxControlReg, value | 0x03); value = PCD_ReadRegister(TxControlReg); } } // End PCD_AntennaOn() StatusCode PICC_RequestA(byte *bufferATQA, ///< The buffer to store the ATQA (Answer to request) in byte *bufferSize ///< Buffer size, at least two bytes. Also number of bytes returned if STATUS_OK. ) { return PICC_REQA_or_WUPA(PICC_CMD_REQA, bufferATQA, bufferSize); } // End PICC_RequestA() void printf_value(uint8_t count, uint8_t *values){ for (uint8_t index = 0; index < count; index++) { debug_info("%p - %x\n",&values[index],values[index]); } } StatusCode PCD_CommunicateWithPICC( byte command, ///< The command to execute. One of the PCD_Command enums. byte waitIRq, ///< The bits in the ComIrqReg register that signals successful completion of the command. byte *sendData, ///< Pointer to the data to transfer to the FIFO. byte sendLen, ///< Number of bytes to transfer to the FIFO. byte *backData, ///< nullptr or pointer to buffer if data should be read back after executing the command. byte *backLen, ///< In: Max number of bytes to write to *backData. Out: The number of bytes returned. byte *validBits, ///< In/Out: The number of valid bits in the last byte. 0 for 8 valid bits. byte rxAlign, ///< In: Defines the bit position in backData[0] for the first bit received. Default 0. bool checkCRC ///< In: True => The last two bytes of the response is assumed to be a CRC_A that must be validated. ) { // Prepare values for BitFramingReg byte txLastBits = validBits ? *validBits : 0; byte bitFraming = (rxAlign << 4) + txLastBits; // RxAlign = BitFramingReg[6..4]. TxLastBits = BitFramingReg[2..0] PCD_WriteRegister(CommandReg, PCD_Idle); // Stop any active command. byte mcmd = PCD_ReadRegister(CommandReg); PCD_WriteRegister(ComIrqReg, 0x7F); // Clear all seven interrupt request bits PCD_WriteRegister(FIFOLevelReg, 0x80); // FlushBuffer = 1, FIFO initialization PCD_WriteRegister_long(FIFODataReg, sendLen, sendData); // Write sendData to the FIFO PCD_WriteRegister(BitFramingReg, bitFraming); // Bit adjustments PCD_WriteRegister(CommandReg, command); // Execute the command if (command == PCD_Transceive) { PCD_SetRegisterBitMask(BitFramingReg, 0x80); // StartSend=1, transmission of data starts } // Wait for the command to complete. // In PCD_Init() we set the TAuto flag in TModeReg. This means the timer automatically starts when the PCD stops transmitting. // Each iteration of the do-while-loop takes 17.86μs. // TODO check/modify for other architectures than Arduino Uno 16bit uint16_t i; for (i = 2000; i > 0; i--) { byte n = PCD_ReadRegister(ComIrqReg); // ComIrqReg[7..0] bits are: Set1 TxIRq RxIRq IdleIRq HiAlertIRq LoAlertIRq ErrIRq TimerIRq // debug_info("n:%x",n); if (n & waitIRq) { // One of the interrupts that signal success has been set. break; } if (n & 0x01) { // Timer interrupt - nothing received in 25ms return STATUS_TIMEOUT; } } // 35.7ms and nothing happend. Communication with the MFRC522 might be down. if (i == 0) { debug_info("STATUS_TIMEOUT2"); return STATUS_TIMEOUT; } // Stop now if any errors except collisions were detected. byte errorRegValue = PCD_ReadRegister(ErrorReg); // ErrorReg[7..0] bits are: WrErr TempErr reserved BufferOvfl CollErr CRCErr ParityErr ProtocolErr if (errorRegValue & 0x13) { // BufferOvfl ParityErr ProtocolErr return STATUS_ERROR; } byte _validBits = 0; // If the caller wants data back, get it from the MFRC522. if (backData && backLen) { byte n = PCD_ReadRegister(FIFOLevelReg); // Number of bytes in the FIFO if (n > *backLen) { return STATUS_NO_ROOM; } *backLen = n; // Number of bytes returned PCD_ReadRegister_long(FIFODataReg, n, backData, rxAlign); // Get received data from FIFO _validBits = PCD_ReadRegister(ControlReg) & 0x07; // RxLastBits[2:0] indicates the number of valid bits in the last received byte. If this value is 000b, the whole byte is valid. if (validBits) { *validBits = _validBits; } } // Tell about collisions if (errorRegValue & 0x08) { // CollErr return STATUS_COLLISION; } // Perform CRC_A validation if requested. if (backData && backLen && checkCRC) { // In this case a MIFARE Classic NAK is not OK. if (*backLen == 1 && _validBits == 4) { return STATUS_MIFARE_NACK; } // We need at least the CRC_A value and all 8 bits of the last byte must be received. if (*backLen < 2 || _validBits != 0) { return STATUS_CRC_WRONG; } // Verify CRC_A - do our own calculation and store the control in controlBuffer. byte controlBuffer[2]; StatusCode status = PCD_CalculateCRC(&backData[0], *backLen - 2, &controlBuffer[0]); if (status != STATUS_OK) { return status; } if ((backData[*backLen - 2] != controlBuffer[0]) || (backData[*backLen - 1] != controlBuffer[1])) { return STATUS_CRC_WRONG; } } return STATUS_OK; } // End PCD_CommunicateWithPICC() StatusCode PCD_TransceiveData( byte *sendData, ///< Pointer to the data to transfer to the FIFO. byte sendLen, ///< Number of bytes to transfer to the FIFO. byte *backData, ///< nullptr or pointer to buffer if data should be read back after executing the command. byte *backLen, ///< In: Max number of bytes to write to *backData. Out: The number of bytes returned. byte *validBits, ///< In/Out: The number of valid bits in the last byte. 0 for 8 valid bits. Default nullptr. byte rxAlign, ///< In: Defines the bit position in backData[0] for the first bit received. Default 0. bool checkCRC ///< In: True => The last two bytes of the response is assumed to be a CRC_A that must be validated. ) { byte waitIRq = 0x30; // RxIRq and IdleIRq return PCD_CommunicateWithPICC(PCD_Transceive, waitIRq, sendData, sendLen, backData, backLen, validBits, rxAlign, checkCRC); } // End PCD_TransceiveData() StatusCode PICC_REQA_or_WUPA( byte command, ///< The command to send - PICC_CMD_REQA or PICC_CMD_WUPA byte *bufferATQA, ///< The buffer to store the ATQA (Answer to request) in byte *bufferSize ///< Buffer size, at least two bytes. Also number of bytes returned if STATUS_OK. ) { byte validBits; StatusCode status; if (bufferATQA == NULL || *bufferSize < 2) { // The ATQA response is 2 bytes long. return STATUS_NO_ROOM; } PCD_ClearRegisterBitMask(CollReg, 0x80); // ValuesAfterColl=1 => Bits received after collision are cleared. validBits = 7; // For REQA and WUPA we need the short frame format - transmit only 7 bits of the last (and only) byte. TxLastBits = BitFramingReg[2..0] status = PCD_TransceiveData(&command, 1, bufferATQA, bufferSize, &validBits,0,false); if (status != STATUS_OK) { return status; } if (*bufferSize != 2 || validBits != 0) { // ATQA must be exactly 16 bits. return STATUS_ERROR; } return STATUS_OK; } // End PICC_REQA_or_WUPA() bool PICC_IsNewCardPresent() { byte bufferATQA[2]; byte bufferSize = sizeof(bufferATQA); // Reset baud rates PCD_WriteRegister(TxModeReg, 0x00); PCD_WriteRegister(RxModeReg, 0x00); // Reset ModWidthReg PCD_WriteRegister(ModWidthReg, 0x26); StatusCode result = PICC_RequestA(bufferATQA, &bufferSize); debug_info("result:%x",result); return (result == STATUS_OK || result == STATUS_COLLISION); } // End PICC_IsNewCardPresent() void PCD_Reset() { PCD_WriteRegister(CommandReg, PCD_SoftReset); // Issue the SoftReset command. // The datasheet does not mention how long the SoftRest command takes to complete. // But the MFRC522 might have been in soft power-down mode (triggered by bit 4 of CommandReg) // Section 8.8.2 in the datasheet says the oscillator start-up time is the start up time of the crystal + 37,74μs. Let us be generous: 50ms. uint8_t count = 0; do { // Wait for the PowerDown bit in CommandReg to be cleared (max 3x50ms) nrf_delay_ms(50); } while ((PCD_ReadRegister(CommandReg) & (1 << 4)) && (++count) < 3); } // End PCD_Reset() #define pgm_read_byte(addr) (*(const unsigned char *)(addr)) bool PCD_PerformSelfTest() { // This follows directly the steps outlined in 16.1.1 // 1. Perform a soft reset. PCD_Reset(); // 2. Clear the internal buffer by writing 25 bytes of 00h byte ZEROES[25] = {0x00}; PCD_WriteRegister(FIFOLevelReg, 0x80); // flush the FIFO buffer PCD_WriteRegister_long(FIFODataReg, 25, ZEROES); // write 25 bytes of 00h to FIFO PCD_WriteRegister(CommandReg, PCD_Mem); // transfer to internal buffer // 3. Enable self-test PCD_WriteRegister(AutoTestReg, 0x09); // 4. Write 00h to FIFO buffer PCD_WriteRegister(FIFODataReg, 0x00); // 5. Start self-test by issuing the CalcCRC command PCD_WriteRegister(CommandReg, PCD_CalcCRC); // 6. Wait for self-test to complete byte n; for (uint8_t i = 0; i < 0xFF; i++) { // The datasheet does not specify exact completion condition except // that FIFO buffer should contain 64 bytes. // While selftest is initiated by CalcCRC command // it behaves differently from normal CRC computation, // so one can't reliably use DivIrqReg to check for completion. // It is reported that some devices does not trigger CRCIRq flag // during selftest. n = PCD_ReadRegister(FIFOLevelReg); if (n >= 64) { debug_info("nnn:%x",n); NRF_LOG_FLUSH(); break; } } PCD_WriteRegister(CommandReg, PCD_Idle); // Stop calculating CRC for new content in the FIFO. // 7. Read out resulting 64 bytes from the FIFO buffer. byte result[64]; PCD_ReadRegister_long(FIFODataReg, 64, result, 0); // Auto self-test done // Reset AutoTestReg register to be 0 again. Required for normal operation. PCD_WriteRegister(AutoTestReg, 0x00); // Determine firmware version (see section 9.3.4.8 in spec) byte version = PCD_ReadRegister(VersionReg); // Pick the appropriate reference values const byte *reference; debug_info("version:%x",version); // Verify that the results match up to our expectations for (uint8_t i = 0; i < 64; i++) { debug_info("result[%d]:%x",i,result[i]); NRF_LOG_FLUSH(); // if (result[i] != pgm_read_byte(&(reference[i]))) { // return false; // } } debug_info("Test passed; all is good"); // Test passed; all is good. return true; } // End PCD_PerformSelfTest() void mfrc522_init() { nrf_gpio_cfg_output(SPI_SS_PIN); nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG; spi_config.ss_pin = SPI_SS_PIN; spi_config.miso_pin = SPI_MISO_PIN; spi_config.mosi_pin = SPI_MOSI_PIN; spi_config.sck_pin = SPI_SCK_PIN; APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL)); PCD_Reset(); uint8_t v = PCD_ReadRegister(VersionReg); NRF_LOG_INFO("version:%x",v); // Reset baud rates PCD_WriteRegister(TxModeReg, 0x00); PCD_WriteRegister(RxModeReg, 0x00); // Reset ModWidthReg PCD_WriteRegister(ModWidthReg, 0x26); // When communicating with a PICC we need a timeout if something goes wrong. // f_timer = 13.56 MHz / (2*TPreScaler+1) where TPreScaler = [TPrescaler_Hi:TPrescaler_Lo]. // TPrescaler_Hi are the four low bits in TModeReg. TPrescaler_Lo is TPrescalerReg. PCD_WriteRegister(TModeReg, 0x80); // TAuto=1; timer starts automatically at the end of the transmission in all communication modes at all speeds v=PCD_ReadRegister(TModeReg); NRF_LOG_INFO("TModeReg:%x",v); PCD_WriteRegister(TPrescalerReg, 0xA9); // TPreScaler = TModeReg[3..0]:TPrescalerReg, ie 0x0A9 = 169 => f_timer=40kHz, ie a timer period of 25μs. v=PCD_ReadRegister(TPrescalerReg); NRF_LOG_INFO("TPrescalerReg:%x",v); PCD_WriteRegister(TPrescalerReg, 0xA9); // TPreScaler = TModeReg[3..0]:TPrescalerReg, ie 0x0A9 = 169 => f_timer=40kHz, ie a timer period of 25μs. v=PCD_ReadRegister(TPrescalerReg); NRF_LOG_INFO("TPrescalerReg:%x",v); PCD_WriteRegister(TReloadRegH, 0x04); // Reload timer with 0x3E8 = 1000, ie 25ms before timeout. PCD_WriteRegister(TReloadRegL, 0xE8); PCD_WriteRegister(TxASKReg, 0x40); // Default 0x00. Force a 100 % ASK modulation independent of the register setting PCD_WriteRegister(ModeReg, 0x3D); // Default 0x3F. Set the preset value for the CRC coprocessor for the CalcCRC command to 0x6363 (ISO 14443-3 part 6.2.4) PCD_AntennaOn(); NRF_LOG_FLUSH(); }
