Need MFRC522 C library for NRF52833 ???
Im  developing NRF52 DK.
I'm building library C SPI mfrc522 for NRF52.
I'm implement PCD_Read and write PCD_register look OK, But i call function PICC_IsNewCardPresent()  in main loop not detected NFC tag, nothing happened!!! ????
Help me. I worked for more than 2 weeks but couldn't ~.~
void PCD_WriteRegister(PCD_Register reg, byte value);
void PCD_WriteRegister_long(PCD_Register reg, byte count, byte *values);
byte PCD_ReadRegister(PCD_Register reg);
void PCD_ReadRegister_long(PCD_Register reg, byte count, byte *values, byte rxAlign); //TODO rxAlign = 0
static uint8_t       m_tx_buf[2];           /**< TX buffer. */
static uint8_t       m_rx_buf[1];    /**< RX buffer. */
static uint8_t       m_write_buf[1];    /**< RX buffer. */
static const uint8_t m_length = 1;        /**< Transfer length. */
static const uint8_t m_tx_length = 2;        /**< Transfer length. */
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
//    NRF_LOG_INFO("Transfer completed.");
//    if (m_rx_buf[0] != 0)
//        NRF_LOG_INFO(" Received:");
//        NRF_LOG_HEXDUMP_INFO(m_rx_buf,1);
void PCD_WriteRegister(PCD_Register reg, byte value){
        nrf_gpio_pin_write(SPI_SS_PIN,0);
        m_tx_buf[0] = reg &0x7E;
        m_tx_buf[1] = value;
        memset(m_rx_buf, 0, m_length);
        spi_xfer_done = false;
        nrf_drv_spi_transfer(&spi,&m_tx_buf[0], m_length, NULL, 0);
        while (!spi_xfer_done)
            __WFE();
        nrf_gpio_pin_write(SPI_SS_PIN,1);
void PCD_WriteRegister_long(PCD_Register reg, byte count, byte *values){
        m_tx_buf[0] = reg & 0x7E;
            __WFE();
        NRF_LOG_FLUSH();
	for (byte index = 0; index < count; index++) {
          debug_info("long value[%d]:%x",index,values[index]);
          nrf_drv_spi_transfer(&spi, &values[index], m_length, NULL, 0);
              __WFE();
          NRF_LOG_FLUSH();
byte PCD_ReadRegister(PCD_Register reg){
        m_tx_buf[0] = (0x80 | (reg & 0x7E));
        nrf_drv_spi_transfer(&spi,&m_tx_buf[0], m_length, m_rx_buf, m_length);
            __WFE();
        _reg = 0x00;
        nrf_drv_spi_transfer(&spi,&_reg, m_length, m_rx_buf, m_length);
            __WFE();
        NRF_LOG_FLUSH();
        return m_rx_buf[0];
void PCD_ReadRegister_long(PCD_Register reg, byte count, byte *values, byte rxAlign){
	if (count == 0) {
		return;
        byte address = 0x80 | (reg& 0x7E);				// MSB == 1 is for reading. LSB is not used in address. Datasheet section 8.1.2.3.
	    byte index = 0;
        count--;
        nrf_drv_spi_transfer(&spi,&address, m_length, m_rx_buf, m_length);
            __WFE();
        NRF_LOG_FLUSH();
        if (rxAlign) {		// Only update bit positions rxAlign..7 in values[0]
		// Create bit mask for bit positions rxAlign..7
		byte mask = (0xFF << rxAlign) & 0xFF;
		// Read value and tell that we want to read the same address again.
                  __WFE();
                byte value = m_rx_buf[0];
		// Apply mask to both current value of values[0] and the new data in value.
		values[0] = (values[0] & ~mask) | (value & mask);
		index++;
        while (index < count) {
          __WFE();
        values[index] = m_rx_buf[0];
        index++;
        uint8_t _reg = 0x00;
          __WFE();
Im include mfrc522.c mfrc522.h.
#include "mfrc522.h"
#define debug_info(...) NRF_LOG_INFO(__VA_ARGS__)
#define SPI_INSTANCE  0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
static uint8_t       m_tx_buf[2];// = TEST_STRING;           /**< TX buffer. */
 * @brief SPI user event handler.
 * @param event
                       void *                    p_context)
            __WFE();
        NRF_LOG_FLUSH();
//        m_tx_buf[1] = value;
//	memset(m_rx_buf, 0, m_length);
//        spi_xfer_done = false;
//        nrf_drv_spi_transfer(&spi, &m_tx_buf[1], m_length, NULL, 0);
//        while (!spi_xfer_done)
//            __WFE();
//        NRF_LOG_FLUSH();
//          byte cpm =  PCD_ReadRegister(reg);
//          if(cpm!=value) debug_info("WTF %x: %x - %x",reg>>1,cpm,value);
            __WFE();
        NRF_LOG_FLUSH();
              __WFE();
          NRF_LOG_FLUSH();
            __WFE();
        uint8_t _reg;
        _reg = 0x00;
            __WFE();
        NRF_LOG_FLUSH();
        return m_rx_buf[0];
	if (count == 0) {
		return;
		byte index = 0;
        count--;
            __WFE();
        NRF_LOG_FLUSH();
          __WFE();
		index++;
          __WFE();
        index++;
          __WFE();
void PCD_ClearRegisterBitMask(	PCD_Register reg,	///< The register to update. One of the PCD_Register enums.
				byte mask			///< The bits to clear.
	byte tmp;
	tmp = PCD_ReadRegister(reg);
	PCD_WriteRegister(reg, tmp & (~mask));		// clear bit mask
} // End PCD_ClearRegisterBitMask()
void PCD_SetRegisterBitMask(	PCD_Register reg,	///< The register to update. One of the PCD_Register enums.
				byte mask			///< The bits to set.
	byte tmp;
	PCD_WriteRegister(reg, tmp | mask);			// set bit mask
} // End PCD_SetRegisterBitMask()
StatusCode PCD_CalculateCRC(	byte *data,		///< In: Pointer to the data to transfer to the FIFO for CRC calculation.
                                byte length,	///< In: The number of bytes to transfer.
                                byte *result	///< Out: Pointer to result buffer. Result is written to result[0..1], low byte first.
	PCD_WriteRegister(CommandReg, PCD_Idle);		// Stop any active command.
	PCD_WriteRegister(DivIrqReg, 0x04);				// Clear the CRCIRq interrupt request bit
	PCD_WriteRegister(FIFOLevelReg, 0x80);			// FlushBuffer = 1, FIFO initialization
	PCD_WriteRegister_long(FIFODataReg, length, data);	// Write data to the FIFO
	PCD_WriteRegister(CommandReg, PCD_CalcCRC);		// Start the calculation
	// Wait for the CRC calculation to complete. Each iteration of the while-loop takes 17.73μs.
	// TODO check/modify for other architectures than Arduino Uno 16bit
	// Wait for the CRC calculation to complete. Each iteration of the while-loop takes 17.73us.
	for (uint16_t i = 5000; i > 0; i--) {
		// DivIrqReg[7..0] bits are: Set2 reserved reserved MfinActIRq reserved CRCIRq reserved reserved
		byte n = PCD_ReadRegister(DivIrqReg);
		if (n & 0x04) {									// CRCIRq bit set - calculation done
			PCD_WriteRegister(CommandReg, PCD_Idle);	// Stop calculating CRC for new content in the FIFO.
			// Transfer the result from the registers to the result buffer
			result[0] = PCD_ReadRegister(CRCResultRegL);
			result[1] = PCD_ReadRegister(CRCResultRegH);
			return STATUS_OK;
	// 89ms passed and nothing happend. Communication with the MFRC522 might be down.
	return STATUS_TIMEOUT;
} // End PCD_CalculateCRC()
void PCD_AntennaOn() {
	uint8_t value = PCD_ReadRegister(TxControlReg);
	if ((value & 0x03) != 0x03) {
		PCD_WriteRegister(TxControlReg, value | 0x03);
} // End PCD_AntennaOn()
StatusCode PICC_RequestA(byte *bufferATQA,	///< The buffer to store the ATQA (Answer to request) in
                         byte *bufferSize	///< Buffer size, at least two bytes. Also number of bytes returned if STATUS_OK.
	return PICC_REQA_or_WUPA(PICC_CMD_REQA, bufferATQA, bufferSize);
} // End PICC_RequestA()
void printf_value(uint8_t count, uint8_t *values){
    for (uint8_t index = 0; index < count; index++) {
        debug_info("%p - %x\n",&values[index],values[index]);
StatusCode PCD_CommunicateWithPICC(	byte command,		///< The command to execute. One of the PCD_Command enums.
                                        byte waitIRq,		///< The bits in the ComIrqReg register that signals successful completion of the command.
                                        byte *sendData,		///< Pointer to the data to transfer to the FIFO.
                                        byte sendLen,		///< Number of bytes to transfer to the FIFO.
                                        byte *backData,		///< nullptr or pointer to buffer if data should be read back after executing the command.
                                        byte *backLen,		///< In: Max number of bytes to write to *backData. Out: The number of bytes returned.
                                        byte *validBits,	///< In/Out: The number of valid bits in the last byte. 0 for 8 valid bits.
                                        byte rxAlign,		///< In: Defines the bit position in backData[0] for the first bit received. Default 0.
                                        bool checkCRC		///< In: True => The last two bytes of the response is assumed to be a CRC_A that must be validated.
	// Prepare values for BitFramingReg
	byte txLastBits = validBits ? *validBits : 0;
	byte bitFraming = (rxAlign << 4) + txLastBits;		// RxAlign = BitFramingReg[6..4]. TxLastBits = BitFramingReg[2..0]
	byte mcmd = PCD_ReadRegister(CommandReg);
        PCD_WriteRegister(ComIrqReg, 0x7F);					// Clear all seven interrupt request bits
        PCD_WriteRegister_long(FIFODataReg, sendLen, sendData);	// Write sendData to the FIFO
        PCD_WriteRegister(BitFramingReg, bitFraming);		// Bit adjustments
        PCD_WriteRegister(CommandReg, command);				// Execute the command
        if (command == PCD_Transceive) {
		PCD_SetRegisterBitMask(BitFramingReg, 0x80);	// StartSend=1, transmission of data starts
	// Wait for the command to complete.
	// In PCD_Init() we set the TAuto flag in TModeReg. This means the timer automatically starts when the PCD stops transmitting.
	// Each iteration of the do-while-loop takes 17.86μs.
	uint16_t i;
	for (i = 2000; i > 0; i--) {
		byte n = PCD_ReadRegister(ComIrqReg);	// ComIrqReg[7..0] bits are: Set1 TxIRq RxIRq IdleIRq HiAlertIRq LoAlertIRq ErrIRq TimerIRq
//		debug_info("n:%x",n);
                if (n & waitIRq) {					// One of the interrupts that signal success has been set.
		if (n & 0x01) {						// Timer interrupt - nothing received in 25ms
	// 35.7ms and nothing happend. Communication with the MFRC522 might be down.
	if (i == 0) {
        debug_info("STATUS_TIMEOUT2");
	// Stop now if any errors except collisions were detected.
	byte errorRegValue = PCD_ReadRegister(ErrorReg); // ErrorReg[7..0] bits are: WrErr TempErr reserved BufferOvfl CollErr CRCErr ParityErr ProtocolErr
	if (errorRegValue & 0x13) {	 // BufferOvfl ParityErr ProtocolErr
		return STATUS_ERROR;
	byte _validBits = 0;
	// If the caller wants data back, get it from the MFRC522.
	if (backData && backLen) {
		byte n = PCD_ReadRegister(FIFOLevelReg);	// Number of bytes in the FIFO
		if (n > *backLen) {
			return STATUS_NO_ROOM;
		*backLen = n;											// Number of bytes returned
		PCD_ReadRegister_long(FIFODataReg, n, backData, rxAlign);	// Get received data from FIFO
		_validBits = PCD_ReadRegister(ControlReg) & 0x07;		// RxLastBits[2:0] indicates the number of valid bits in the last received byte. If this value is 000b, the whole byte is valid.
		if (validBits) {
			*validBits = _validBits;
	// Tell about collisions
	if (errorRegValue & 0x08) {		// CollErr
		return STATUS_COLLISION;
	// Perform CRC_A validation if requested.
	if (backData && backLen && checkCRC) {
		// In this case a MIFARE Classic NAK is not OK.
		if (*backLen == 1 && _validBits == 4) {
			return STATUS_MIFARE_NACK;
		// We need at least the CRC_A value and all 8 bits of the last byte must be received.
		if (*backLen < 2 || _validBits != 0) {
			return STATUS_CRC_WRONG;
		// Verify CRC_A - do our own calculation and store the control in controlBuffer.
		byte controlBuffer[2];
		StatusCode status = PCD_CalculateCRC(&backData[0], *backLen - 2, &controlBuffer[0]);
		if (status != STATUS_OK) {
			return status;
		if ((backData[*backLen - 2] != controlBuffer[0]) || (backData[*backLen - 1] != controlBuffer[1])) {
	return STATUS_OK;
} // End PCD_CommunicateWithPICC()
StatusCode PCD_TransceiveData(	byte *sendData,		///< Pointer to the data to transfer to the FIFO.
                                        byte *validBits,	///< In/Out: The number of valid bits in the last byte. 0 for 8 valid bits. Default nullptr.
	byte waitIRq = 0x30;		// RxIRq and IdleIRq
	return PCD_CommunicateWithPICC(PCD_Transceive, waitIRq, sendData, sendLen, backData, backLen, validBits, rxAlign, checkCRC);
} // End PCD_TransceiveData()
StatusCode PICC_REQA_or_WUPA(	byte command, 		///< The command to send - PICC_CMD_REQA or PICC_CMD_WUPA
	byte validBits;
	StatusCode status;
	if (bufferATQA == NULL || *bufferSize < 2) {	// The ATQA response is 2 bytes long.
	PCD_ClearRegisterBitMask(CollReg, 0x80);		// ValuesAfterColl=1 => Bits received after collision are cleared.
	validBits = 7;									// For REQA and WUPA we need the short frame format - transmit only 7 bits of the last (and only) byte. TxLastBits = BitFramingReg[2..0]
	status = PCD_TransceiveData(&command, 1, bufferATQA, bufferSize, &validBits,0,false);
		return status;
	if (*bufferSize != 2 || validBits != 0) {		// ATQA must be exactly 16 bits.
	return STATUS_OK;
} // End PICC_REQA_or_WUPA()
bool PICC_IsNewCardPresent() {
	byte bufferATQA[2];
	byte bufferSize = sizeof(bufferATQA);
	// Reset baud rates
	PCD_WriteRegister(TxModeReg, 0x00);
	PCD_WriteRegister(RxModeReg, 0x00);
	// Reset ModWidthReg
	PCD_WriteRegister(ModWidthReg, 0x26);
	StatusCode result = PICC_RequestA(bufferATQA, &bufferSize);
    debug_info("result:%x",result);
	return (result == STATUS_OK || result == STATUS_COLLISION);
} // End PICC_IsNewCardPresent()
void PCD_Reset() {
	PCD_WriteRegister(CommandReg, PCD_SoftReset);	// Issue the SoftReset command.
	// The datasheet does not mention how long the SoftRest command takes to complete.
	// But the MFRC522 might have been in soft power-down mode (triggered by bit 4 of CommandReg)
	// Section 8.8.2 in the datasheet says the oscillator start-up time is the start up time of the crystal + 37,74μs. Let us be generous: 50ms.
	uint8_t count = 0;
	do {
		// Wait for the PowerDown bit in CommandReg to be cleared (max 3x50ms)
		nrf_delay_ms(50);
	} while ((PCD_ReadRegister(CommandReg) & (1 << 4)) && (++count) < 3);
} // End PCD_Reset()
#define pgm_read_byte(addr)   (*(const unsigned char *)(addr))
bool PCD_PerformSelfTest() {
	// This follows directly the steps outlined in 16.1.1
	// 1. Perform a soft reset.
	PCD_Reset();
	// 2. Clear the internal buffer by writing 25 bytes of 00h
	byte ZEROES[25] = {0x00};
	PCD_WriteRegister(FIFOLevelReg, 0x80);		// flush the FIFO buffer
	PCD_WriteRegister_long(FIFODataReg, 25, ZEROES);	// write 25 bytes of 00h to FIFO
	PCD_WriteRegister(CommandReg, PCD_Mem);		// transfer to internal buffer
	// 3. Enable self-test
	PCD_WriteRegister(AutoTestReg, 0x09);
	// 4. Write 00h to FIFO buffer
	PCD_WriteRegister(FIFODataReg, 0x00);
	// 5. Start self-test by issuing the CalcCRC command
	// 6. Wait for self-test to complete
	byte n;
	for (uint8_t i = 0; i < 0xFF; i++) {
		// The datasheet does not specify exact completion condition except
		// that FIFO buffer should contain 64 bytes.
		// While selftest is initiated by CalcCRC command
		// it behaves differently from normal CRC computation,
		// so one can't reliably use DivIrqReg to check for completion.
		// It is reported that some devices does not trigger CRCIRq flag
		// during selftest.
		if (n >= 64) {
                debug_info("nnn:%x",n);
                NRF_LOG_FLUSH();
	// 7. Read out resulting 64 bytes from the FIFO buffer.
	byte result[64];
	PCD_ReadRegister_long(FIFODataReg, 64, result, 0);
	// Auto self-test done
	// Reset AutoTestReg register to be 0 again. Required for normal operation.
	PCD_WriteRegister(AutoTestReg, 0x00);
	// Determine firmware version (see section 9.3.4.8 in spec)
	byte version = PCD_ReadRegister(VersionReg);
	// Pick the appropriate reference values
	const byte *reference;
	debug_info("version:%x",version);
	// Verify that the results match up to our expectations
	for (uint8_t i = 0; i < 64; i++) {
debug_info("result[%d]:%x",i,result[i]);
NRF_LOG_FLUSH();
//		if (result[i] != pgm_read_byte(&(reference[i]))) {
//			return false;
	debug_info("Test passed; all is good");
	// Test passed; all is good.
	return true;
} // End PCD_PerformSelfTest()
void mfrc522_init()
      nrf_gpio_cfg_output(SPI_SS_PIN);
      nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
      spi_config.ss_pin   = SPI_SS_PIN;
      spi_config.miso_pin = SPI_MISO_PIN;
      spi_config.mosi_pin = SPI_MOSI_PIN;
      spi_config.sck_pin  = SPI_SCK_PIN;
      APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
        PCD_Reset();
      uint8_t v = PCD_ReadRegister(VersionReg);
      NRF_LOG_INFO("version:%x",v);
	// Reset baud rates
	// When communicating with a PICC we need a timeout if something goes wrong.
	// f_timer = 13.56 MHz / (2*TPreScaler+1) where TPreScaler = [TPrescaler_Hi:TPrescaler_Lo].
	// TPrescaler_Hi are the four low bits in TModeReg. TPrescaler_Lo is TPrescalerReg.
	PCD_WriteRegister(TModeReg, 0x80);			// TAuto=1; timer starts automatically at the end of the transmission in all communication modes at all speeds
	v=PCD_ReadRegister(TModeReg);
    NRF_LOG_INFO("TModeReg:%x",v);
    PCD_WriteRegister(TPrescalerReg, 0xA9);		// TPreScaler = TModeReg[3..0]:TPrescalerReg, ie 0x0A9 = 169 => f_timer=40kHz, ie a timer period of 25μs.
	v=PCD_ReadRegister(TPrescalerReg);
    NRF_LOG_INFO("TPrescalerReg:%x",v);
    PCD_WriteRegister(TReloadRegH, 0x04);		// Reload timer with 0x3E8 = 1000, ie 25ms before timeout.
	PCD_WriteRegister(TReloadRegL, 0xE8);
	PCD_WriteRegister(TxASKReg, 0x40);		// Default 0x00. Force a 100 % ASK modulation independent of the  register setting
	PCD_WriteRegister(ModeReg, 0x3D);		// Default 0x3F. Set the preset value for the CRC coprocessor for the CalcCRC command to 0x6363 (ISO 14443-3 part 6.2.4)
	PCD_AntennaOn();
    NRF_LOG_FLUSH();
mfrc522.h
    I am also facing same issue i am able to read the version register
    I am using 17.1.0nRF5 SDK
    #include "nrf_drv_spi.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "boards.h"
    #include "app_error.h"
    #include <string.h>
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define TEST_STRING "Nordic"
    static uint8_t       m_tx_buf[2];//   /**< TX buffer. */
     * @param event
                           void *                    p_context)
     #if 0
            NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
    #if 0
        NRF_LOG_INFO("SPI example started.");
        mfrc522_init();
        //PCD_PerformSelfTest();
        //PCD_Reset();
        while (1)
            // Reset rx buffer and transfer done flag
            APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
            PICC_IsNewCardPresent();
        #if  0
                __WFE();
            NRF_LOG_FLUSH();
            bsp_board_led_invert(BSP_BOARD_LED_0);
            nrf_delay_ms(200);
    my output :---(error)
    <info> app: SPI example started.
    <info> app: version:F
    <info> app: TModeReg:80
    <info> app: TPrescalerReg:A9
    <info> app: STATUS_TIMEOUT2
    <info> app: result:3
    I have used the same libarary attached in the above case
    • Case ID: 241550
    •  I am getting "Timeoout in communication" error even though i have placed the rfid id card continously on the scanner        #define STATUS_OK (0x00)// Success
      #define STATUS_ERROR (0x01)// Error in communication
      #define STATUS_COLLISION (0x02)// Collission detected
      #define STATUS_TIMEOUT (0x03)// Timeout in communication.                                                        As per the data sheet and library
    My write function:
    void WriteRegister(uint8_t addr, uint8_t val) {
    m_tx_buf[0] = (addr << 1) & 0x7E;
    m_tx_buf[1] = val;
    nrf_drv_spi_transfer(&spi,&m_tx_buf[0], 2, NULL, 0);
    __WFE();
    NRF_LOG_FLUSH();
    static void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
    void * p_context)
    And in maid loop you wating spi_xfer_done .
    rue.a
    PLEASE anyone help me out i  have been working on the same from past two weeks i have checked the hardware functionalities of the MFRC522 it is in working condition and i am having 2 rfid scanners in both also same issue please help me out..
    If possible share the complete code
  • Hi Sharath,
    I am facing the same issue, have you been able to find a solution
  • Hi Imad,
    I had the same issue and it gets fixed by changing the value of the ORC from 0xFF to 0x00.
    spi_config.orc      = 0x00;
    spi_config.frequency = NRF_DRV_SPI_FREQ_8M;
    spi_config.mode      = NRF_DRV_SPI_MODE_0;
    spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
    Which timeout error did you get?
    There is 2 timeout errors in PCD_CommunicateWithPICC function.
    		uint8_t n = PCD_ReadRegister(ComIrqReg);	// ComIrqReg[7..0] bits are: Set1 TxIRq RxIRq IdleIRq HiAlertIRq LoAlertIRq ErrIRq TimerIRq
                    if (n & waitIRq)
                    //printf("%02x",n);
    		if (n & 0x01)
    if (i == 0)
    I didn't get a timeout error except the one in the loop , which is normal because there's nothing received in that period.
