Casting zero (0) double variable to integer is incorrect
Hi there,
I found very interesting behavior on casting double variables to integer.
The following code gives me strange result:
double dval = 0.;
int ival = (int)dval;   // < ival = 2 - unexpected result
double dval1 = 0.0000001;
int ival2 = (int)dval2; // < ival = 0 - expected
In short words, if the double variable is '0.', then it is casted to integer as 2, does not matter int/long/char. If the variable differs the '0.' to any smallest values, it is casted correctly. Looks very strange for me. Casting from the float variables works as expected.
Environment:
SEGGER Embedded Studio v4.30
Development board PCA10040
Compiler GCC
FPU is enabled (ARM FP ABI Type: hard; ARM FPU Type FPv4-SP-D16)
To handle this I perform casting to float type before, and then to integer type.
What can I do wrong that the cast of the double variables with 0 value to the integer performed incorrectly?
Thank you.
  • I am not able to reproduce your behavior. In both cases, I got '0' as a result in both of the cases. I copied your code into the twi_scanner nRF5 SDK example (logging enabled).
    Could you share your code? I can make the ticket private if you would like to.
    Simon
  • Hi Simon,
    Here the link to the test project, where I am able to reproduce the issue.
    https://drive.google.com/file/d/1lulj2b3rdxqP_AFQBdMHFg2-38J9euSa/view?usp=sharing
    Also, here is the screenshot of debugging process.
    Regards, Aleksey.
  • I tested your example with an nRF52832 DK, and it worked fine:
    Does your compiler options look like this:
    Simon
  • Hi Simon,
    Yes, compiler type and standard are set as at the picture. The problem reproduces on nRF52832DK board and on our specific device based on nRF52832 MCU.
    Aleksey.
  • It seems like the issue is related to Segger Embedded Studio. If you look at your assembly code, you can see that __aeabi_d2iz is used for casting. In my generated assembly code, __fixdfsi is used. I am using SES 3.40. I tried to upgrade to SES v4.30c and encounter the same issue as you.
    Some solutions:
    • You could downgrade SES
    • You could create a support ticket on the SES technical support site and ask about this
    • I can look into it and try to find a quick fix
    Simon
1 2
