Hi there,
I'm working on nrf82382, try to use COMP function to monitor the voltage of AIN0(p0.02), but seems not working, no example for the COMP. and then I found the LDCOMP example in the SDK, and copy the some codes from that, and the LDCOMP is work fines.
here is my COMP codes:
void comp_event_handler(nrf_comp_event_t evt)
if (evt == NRF_COMP_EVENT_READY) {
LED1_Toggle();
} else if (evt == NRF_COMP_EVENT_DOWN) {
LED2_Toggle();
} else if (evt == NRF_COMP_EVENT_UP) {
LED3_Toggle();
} else if (evt == NRF_COMP_EVENT_CROSS) {
LED4_Toggle();
static void lpcomp_event_handler(nrf_lpcomp_event_t event)
if (event == NRF_LPCOMP_EVENT_CROSS) {
LED2_Toggle();
static void lpcomp_init(void)
uint32_t err_code;
nrf_drv_lpcomp_config_t config = NRF_DRV_LPCOMP_DEFAULT_CONFIG;
config.input = NRF_LPCOMP_INPUT_0;
// initialize LPCOMP driver, from this point LPCOMP will be active and provided
// event handler will be executed when defined action is detected
err_code = nrf_drv_lpcomp_init(&config, lpcomp_event_handler);
nrf_drv_lpcomp_enable();
LED_Init();
KEY_Init();
nrf_drv_comp_config_t comp_config = NRF_DRV_COMP_DEFAULT_CONFIG(NRF_COMP_INPUT_0);
comp_config.isource = NRF_COMP_ISOURCE_Ien5uA;
uint32_t err_code = nrf_drv_comp_init(&comp_config, comp_event_handler);
if (err_code != NRFX_SUCCESS) {
LED3_Close();
nrf_drv_comp_start(NRF_DRV_COMP_EVT_EN_CROSS_MASK, NRF_DRV_COMP_SHORT_STOP_AFTER_UP_EVT);
while (1){
nrf_drv_comp_sample(); // try to sample manually, but still not work.
nrf_delay_ms(50);
if (KEY1_Down() == 0){ // use that logic to make sure MCU was not hung.
LED1_Toggle();
please help, or is there any example for the COMP in nrf52832?
