Need to change Tx & Rx pins on Custom board for Secure Serial bootloader DFU code
I am using nRF52840, SDK_16.0.0, S140 SoftDevice and Segger 4.16 for flashing the image.
1)  For Secure Serial bootloader in below path, I want to change Tx & Rx for my custom board.
\examples\dfu\secure_bootloader\pca10056_uart\
Do I need to change below macros in pca10056.h file
#define RX_PIN_NUMBER 8
#define TX_PIN_NUMBER 6
2) Are there any other changes to be done.
Thanks & Regards
Vishnu Beema
  • Hi Vishnu,
    Yes, these are the pins definitions used by the function that initializes the UART transport layer
    static uint32_t uart_dfu_transport_init(nrf_dfu_observer_t observer)
        uint32_t err_code = NRF_SUCCESS;
        if (m_active)
            return err_code;
        NRF_LOG_DEBUG("serial_dfu_transport_init()");
        m_observer = observer;
        err_code = nrf_balloc_init(&m_payload_pool);
        if (err_code != NRF_SUCCESS)
            return err_code;
        uint8_t * p_rx_buf = nrf_balloc_alloc(&m_payload_pool);
        m_slip.p_buffer      =  &p_rx_buf[OPCODE_OFFSET];
        m_slip.current_index = 0;
        m_slip.buffer_len    = UART_SLIP_MTU;
        m_slip.state         = SLIP_STATE_DECODING;
        m_serial.rsp_func           = rsp_send;
        m_serial.payload_free_func  = payload_free;
        m_serial.mtu                = UART_SLIP_MTU;
        m_serial.p_rsp_buf          = &m_rsp_buf[NRF_UART_MAX_RESPONSE_SIZE_SLIP -
                                                NRF_SERIAL_MAX_RESPONSE_SIZE];
        m_serial.p_low_level_transport = &uart_dfu_transport;
        nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
        uart_config.pseltxd   = TX_PIN_NUMBER;
        uart_config.pselrxd   = RX_PIN_NUMBER;
        uart_config.pselcts   = CTS_PIN_NUMBER;
        uart_config.pselrts   = RTS_PIN_NUMBER;
        uart_config.hwfc      = NRF_DFU_SERIAL_UART_USES_HWFC ?
                                    NRF_UART_HWFC_ENABLED : NRF_UART_HWFC_DISABLED;
        uart_config.p_context = &m_serial;
        err_code =  nrf_drv_uart_init(&m_uart, &uart_config, uart_event_handler);
            NRF_LOG_ERROR("Failed initializing uart");
            return err_code;
        err_code = nrf_drv_uart_rx(&m_uart, &m_rx_byte, 1);
            NRF_LOG_ERROR("Failed initializing rx");
        NRF_LOG_DEBUG("serial_dfu_transport_init() completed");
        m_active = true;
        if (m_observer)
            m_observer(NRF_DFU_EVT_TRANSPORT_ACTIVATED);
        return err_code;
     No, if you just want to change the pins then the definitions in pca10056.h is all you need to modify. Note, that hardware flow control is enabled, i.e. NRF_DFU_SERIAL_UART_USES_HWFC = 1, so if you only use the tx and RX pins and not any CTS or RTS pins, then you should disable the HWFC.
    Best regards
    Bjørn
    I am planning to disable Flow control by disabling macro NRF_UART_HWFC_ENABLED. But about HWFC, do I need to set it to false. No where I am seeing HWFC macro being used.
    #define HWFC           true
    Thanks & Regards
    Vishnu Beema
  • You just have to set NRF_UART_HWFC_ENABLED to false. No need to define HWFC.
