I am using NRF51822 SDK12; S130 and trying to qualify Batter level service, So far encountred a problem with Test Case: BAS/SR/DES/BV-02-C, the Verdict is INCONCE all other test cases were OK.
I also tried to qualify the nordic GLS example to compare and to find whether the problem is with my implementation, I removed the security protection from the GLS and started a preforming qualification process using the SIG PTS BLE Dongle and the Launch studio, I saw the exact same result, all Items were ok except from BAS/SR/DES/BV-02-C, to my understanding this is the notification support for the BAS:
This is the relevant part BAS (battery level) test plan I created in the Launch studio
to my understanding since we are enabling notification I should mark support for item 2a/1; but this seems to be the problematic item
this is the log from the PTS software
+37109 ms Verdict Description: GATTValue::AssignData, Cannot be parsed from the specified buffer. Field Name = Properties. +37109 ms Error: GATTValue::CreateFields, Failed to assign data to the Field named 'Properties'. +37109 ms Verdict Description: GATTValue::CreateFields, Failed to assign data to the Field named 'Properties'. +37109 ms Inconclusive: The data received for 'Client Characteristic Configuration' did not conform to the schema. An invalid number of bytes were received. +37109 ms Verdict Description: The data received for 'Client Characteristic Configuration' did not conform to the schema. An invalid number of bytes were received.
I would appreciate any input on that issue
Thanks!
