MacOS SDK 1.1 linking problems
All was working on SDK 1.0. Now I have SDK 1.1 and new Segger and new nRF Connect and gnuarmbemb (I had a new computer, so did set up everything from scratch)
2> Compiling ‘isr_tables.c’
1> Remove /Users/slava/work/nordic/ncs/nrf/samples/nrf9160/gps/build_nrf9160_pca10090ns/spm/zephyr/zephyr.elf
1> Linking ‘zephyr.elf’
1> Post-link command
Build failed
However, using west directly is working fine:
➜  gps git:(d3130d77) ✗ west build --board=nrf9160_pca10090ns -d build_nrf9160_pca10090ns
-- west build: build configuration:
       source directory: /Users/slava/work/nordic/ncs/nrf/samples/nrf9160/gps
       build directory: /Users/slava/work/nordic/ncs/nrf/samples/nrf9160/gps/build_nrf9160_pca10090ns
       BOARD: nrf9160_pca10090ns (origin: CMakeCache.txt)
[0/1] Re-running CMake...
-- Using application from '/Users/slava/work/nordic/ncs/nrf/samples/nrf9160/gps'
Zephyr version: 2.0.99
-- Build files have been written to: /Users/slava/work/nordic/ncs/nrf/samples/nrf9160/gps/build_nrf9160_pca10090ns
[167/295] Linking C executable spm/zephyr/spm_zephyr_prebuilt.elf
           FLASH:         32 KB        48 KB     66.67%
            SRAM:        5424 B        64 KB      8.28%
        IDT_LIST:          40 B         2 KB      1.95%
[289/295] Linking C executable zephyr/zephyr_prebuilt.elf
           FLASH:      113980 B       976 KB     11.40%
            SRAM:       19644 B       128 KB     14.99%
        IDT_LIST:         120 B         2 KB      5.86%
[295/295] Generating zephyr/merged.hex
Merged /Users/slava/work/nordic/ncs/nrf/samples/nrf9160/gps/build_nrf9160_pca10090ns/spm/zephyr/zephyr.hex
Merged /Users/slava/work/nordic/ncs/nrf/samples/nrf9160/gps/build_nrf9160_pca10090ns/zephyr/zephyr.hex
Not sure where to look anymore or how to get more precise and details error mesage...
  • Okay, thanks for trying. I am out of ideas but this seems to be an issue a couple macOS users are seeing so the NCS team is looking into it. I'll update you when I know more.
  • Have you made sure to update the toolchain to version 8-2019-q3-update? If not, please do that.
  • Yes, the toolchain is of exactly this version. I mentioned this before. Thanks for your help. I'll wait for a reply from NCS team...
  • Ok I found what's wrong.
    First I had to enable "Echo Build Command lines" in "Tools -> Options -> Building"
    Then you can see in the log:
    2> /opt/gnuarmemb/bin/arm-none-eabi-gcc -DABI_INFO_MAGIC=0x281ee6de,0xb845acea,23297 -DBUILD_VERSION=v2.0.99-ncs1 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,23297 -DKERNEL -DMBEDTLS_CONFIG_FILE="nrf-config.h" -DNRF9160_XXAA -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -I/Users/slava/work/nordic/ncs/zephyr/kernel/include -I/Users/slava/work/nordic/ncs/zephyr/arch/arm/include -I/Users/slava/work/nordic/ncs/zephyr/include -I/Users/slava/work/nordic/ncs/zephyr/include/drivers -Ispm/zephyr/include/generated -I/Users/slava/work/nordic/ncs/zephyr/soc/arm/nordic_nrf/nrf91 -I/Users/slava/work/nordic/ncs/zephyr/ext/hal/cmsis/Include -I/Users/slava/work/nordic/ncs/nrf/include -I/Users/slava/work/nordic/ncs/nrfxlib/crypto/nrf_cc310_mbedcrypto/include/mbedtls -I/Users/slava/work/nordic/ncs/nrfxlib/crypto/nrf_cc310_mbedcrypto/include -Ispm/zephyr/modules/nrfxlib/nrf_security/include -Ispm/zephyr/modules/nrfxlib/nrf_security/include/mbedtls_generated -I/Users/slava/work/nordic/ncs/mbedtls/include -I/Users/slava/work/nordic/ncs/mbedtls/include/mbedtls -I/Users/slava/work/nordic/ncs/modules/hal/nordic/nrfx -I/Users/slava/work/nordic/ncs/modules/hal/nordic/nrfx/drivers/include -I/Users/slava/work/nordic/ncs/modules/hal/nordic/nrfx/mdk -I/Users/slava/work/nordic/ncs/modules/hal/nordic/. -isystem /Users/slava/work/nordic/ncs/zephyr/lib/libc/minimal/include -isystem /opt/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/include -isystem /opt/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/include-fixed -isystem /Users/slava/work/nordic/ncs/nrfxlib/crypto/nrf_cc310_platform/include -Os -imacros/Users/slava/work/ozark-iot/ozark-mesh-gateway/build_nrf9160_pca10090ns/spm/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mthumb -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -imacros/Users/slava/work/nordic/ncs/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/Users/slava/work/ozark-iot/ozark-mesh-gateway=CMAKE_SOURCE_DIR -fmacro-prefix-map=/Users/slava/work/nordic/ncs/zephyr=ZEPHYR_BASE -ffunction-sections -fdata-sections -mabi=aapcs -march=armv8-m.main+dsp -mcmse -std=c99 -nostdinc -MD -MF /Users/slava/work/ozark-iot/ozark-mesh-gateway/build_nrf9160_pca10090ns/spm/zephyr/CMakeFiles/spm_zephyr_final.dir/isr_tables.c.obj.d -fno-diagnostics-show-caret -o spm/zephyr/CMakeFiles/spm_zephyr_final.dir/isr_tables.c.obj -c spm/zephyr/isr_tables.c
    1> spm/zephyr/zephyr.elf does not exist.
    Building ‘libspmsecureentries.a’ from solution ‘build’ in configuration ‘Common’
    1> /opt/gnuarmemb/bin/arm-none-eabi-gcc spm/zephyr/CMakeFiles/spm_zephyr_final.dir/misc/empty_file.c.obj spm/zephyr/CMakeFiles/spm_zephyr_final.dir/isr_tables.c.obj -Wl,-T spm/zephyr/linker_pass_final.cmd -Wl,-Map=/Users/slava/work/ozark-iot/ozark-mesh-gateway/build_nrf9160_pca10090ns/spm/zephyr/spm_zephyr_final.map -Wl,--whole-archive spm/spm_app/libspm_app.a spm/zephyr/libspm_zephyr.a spm/zephyr/arch/arch/arm/core/libspm_arch__arm__core.a spm/zephyr/arch/arch/arm/core/cortex_m/libspm_arch__arm__core__cortex_m.a spm/zephyr/arch/arch/arm/core/cortex_m/mpu/libspm_arch__arm__core__cortex_m__mpu.a spm/zephyr/lib/libc/minimal/libspm_lib__libc__minimal.a spm/zephyr/lib/posix/libspm_lib__posix.a spm/zephyr/drivers/serial/libspm_drivers__serial.a spm/zephyr/modules/nrf/subsys/fw_info/libspm_..__nrf__subsys__fw_info.a spm/zephyr/modules/nrf/drivers/hw_cc310/libspm_..__nrf__drivers__hw_cc310.a spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/libspm_mbedtls_base_vanilla.a spm/zephyr/modules/nordic/libspm_..__modules__hal__nordic.a -Wl,--no-whole-archive spm/zephyr/kernel/libspm_kernel.a spm/zephyr/CMakeFiles/spm_offsets.dir/arch/arm/core/offsets/offsets.c.obj -L/opt/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/thumb/v8-m.main+fp/hard -L/Users/slava/work/ozark-iot/ozark-mesh-gateway/build_nrf9160_pca10090ns/spm/zephyr -lgcc /Users/slava/work/nordic/ncs/nrfxlib/crypto/nrf_cc310_mbedcrypto/lib/cortex-m33/hard-float/no-interrupts/libnrf_cc310_mbedcrypto_0.9.1.a /Users/slava/work/nordic/ncs/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m33/hard-float/no-interrupts/libnrf_cc310_platform_0.9.1.a -mthumb -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -u_OffsetAbsSyms -u_ConfigAbsSyms -nostdlib -static -no-pie -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -mabi=aapcs -march=armv8-m.main+dsp -Wl,--out-implib=/Users/slava/work/ozark-iot/ozark-mesh-gateway/build_nrf9160_pca10090ns/libspmsecureentries.a -Wl,--cmse-implib -o spm/zephyr/zephyr.elf
    1> cmake -E rename spm_zephyr_final.map zephyr.map
    Build failed
    I believe the working directory for all build commands is the "build_nrf9160_pca10090ns" directory for the project, so running the command in it from console gives me this:
    ➜  build_nrf9160_pca10090ns git:(master) ✗ cmake -E rename spm_zephyr_final.map zephyr.map
    Error renaming from "spm_zephyr_final.map" to "zephyr.map": No such file or directory
    Looking for a file:
    ➜  build_nrf9160_pca10090ns git:(master) ✗ find . -name "spm_zephyr_final.map"
    ./spm/zephyr/spm_zephyr_final.map
    I believe that the correct command should be:
    cmake -E rename spm/zephyr/spm_zephyr_final.map spm/zephyr/zephyr.map
  • I'm glad you found a solution! I have forwarded this to the developers so they can investigate if it's a general problem.
    Otso Jousimaa, can you try the same solution and confirm that it fixes it for you as well?
    Heidi
