nrf51-ble-driver_win_0.3.0 question
Hi!
I realize that the paint on this is still drying, but I'm wondering if anyone is seeing the following behavior?
I can run an program based on this API once. When I try to run it again, sd_ble_gap_scan_start() never returns. If I control-c the program, unplug the device and plug it back in, then the program runs -- once.
I've tried this with both a program that I have written and the S120 Multi-Link example. I've also tried a nRF51822 dongle (PCA10000) and a nRF51422 dongle (PCA10031).
The firmware I have loaded is
 s120_nrf51822_1.0.1_softdevice.hex
and
 connectivity_1M.hex
I have also tried connectivity_115k2.hex and changed the program code to match.
When using s120_nrf51_2.0.0_softdevice.hex I can't load either connectivity app since the newer software device appears to be bigger.
Any ideas?
Thanks!
  • First of all, thank you for the feedback. I have handed this over to our developers so and they are aware of the issue you are reporting with regard to only be able to run the application once.
    For now, the recommendation would be to ensure that sd_rpc_close() runs at closing and that you might also be able to reset the application by using nrfjprog->pinreset.
    We suspect that the issue you are seeing is due to data left in the Segger chips buffers. This should be possible to handle by using sd_rpc_close().
  • We really appreciate the feedback. The developers are looking at the threads related to the development of the drivers and the early feedback is really good to get. There's been a few comments on the stability and resetting needed so it's something that will be taken into consideration for the development.
