Can the MDBT42Q BT/RF module be used as a single master to multi slave
Hi There,
I am curious to find out if the MDBT42Q module(s) can be used as a single master to multi slave setup? Essentially I want to have one module setup as a master (with 7 channels) and up to 3 modules set up as slaves and out puting on specific GPIO ports based on the channel assignment.
I noticed that the GPIO ports can only be configured as output ports on the MDBT42Q. Do I need to use a different module (different model) so I can configure some of the GPIO as inputs (master) and then map those to the GPIO out puts (slave) of the MDBT42Q?
Please let me know if this is the correct area for raising this type of query
Regards
George
