I am trying to compile the nrf9160 lte_ble_gateway project as an nrf9160ns project and I get the following error:
Hi Heidi,
Here is the output at the command line as requested
Okay, so it's just a problem with SES.
If you haven't already updated to 4.30c, you can do this by going to the Getting Started Assistant in nRF Connect. Make sure you have nRF Connect v3.3.0 and Getting Started Assistant v1.0.5. Then select step 3 Download SEGGER Embedded Studio and select the download link based on your OS (Windows x64 or x86).
Make sure these paths are correct in Tools -> Options -> nRF Connect:
Then delete the build folder from the lte_ble_gateway directory and try opening up the project again like this:
Heidi
