I tried to configure Ozone for aws_fota sample without any success. I loaded elf files but one is debuging mcu boot and the other never access to the main. Do someone have an idea please ?
Have you commented the AfterTargetReset() and AfterTargetDownload() implementation in your Ozone project? Those will by default make the program jump directly to the start of the executable you are currently debugging. i.e., cause the MCUBOOT/SPM part of the boot sequence to be skipped if you are attempting to debug the main app.
Ozone *.jdebug project file I used to debug the aws fota sample:
* (c) SEGGER Microcontroller GmbH *
* The Embedded Experts *
* www.segger.com *
File :
Created : 03 Jan 2020 9:10
Ozone Version : V2.70e
* OnProjectLoad
* Function description
* Project load routine. Required.
void OnProjectLoad (void) {
// Dialog-generated settings
Project.AddPathSubstitute ("C:/Users/vibe/Desktop", "$(ProjectDir)");
Project.AddPathSubstitute ("c:/users/vibe/desktop", "$(ProjectDir)");
Project.SetDevice ("nRF9160");
Project.SetHostIF ("USB", "");
Project.SetTargetIF ("SWD");
Project.SetTIFSpeed ("1 MHz");
Project.AddSvdFile ("$(InstallDir)/Config/CPU/Cortex-M33F.svd");
Project.AddSvdFile ("$(InstallDir)/Config/Peripherals/ARMv7M.svd");
// User settings
File.Open ("C:/vidar/workspace/ncs/nrf/samples/nrf9160/aws_fota/build_nrf9160_pca10090ns/zephyr/zephyr.elf");
* OnSnapshotLoad
* Optional event handler, called upon loading a snapshot.
* Additional information
* This function is used to restore the target state in cases
* where values cannot simply be written to the target.
* Typical use: GPIO clock needs to be enabled, before
* GPIO is configured.
//void OnSnapshotLoad (void) {
* OnSnapshotSave
* Optional event handler, called upon saving a snapshot.
* This function is usually used to save values of the target
* state which can either not be trivially read,
* or need to be restored in a specific way or order.
* Typically use: Memory Mapped Registers,
* such as PLL and GPIO configuration.
//void OnSnapshotSave (void) {
* TargetReset
* Replaces the default target device reset routine. Optional.
* Notes
* This example demonstrates the usage when
* debugging a RAM program on a Cortex-M target device
//void TargetReset (void) {
// unsigned int SP;
// unsigned int PC;
// unsigned int VectorTableAddr;
// VectorTableAddr = Program.GetBaseAddr();
// if (VectorTableAddr != 0xFFFFFFFF) {
// SP = Target.ReadU32(VectorTableAddr);
// Target.SetReg("SP", SP);
// } else {
// Util.Log("Project file error: failed to get program base");
// PC = Elf.GetEntryPointPC();
// if (PC != 0xFFFFFFFF) {
// Target.SetReg("PC", PC);
// } else if (VectorTableAddr != 0xFFFFFFFF) {
// PC = Target.ReadU32(VectorTableAddr + 4);
* BeforeTargetReset
* Event handler routine. Optional.
//void BeforeTargetReset (void) {
* AfterTargetReset
* - Sets the PC register to program reset value.
* - Sets the SP register to program reset value on Cortex-M.
/* void AfterTargetReset (void) {
unsigned int SP;
unsigned int PC;
VectorTableAddr = Elf.GetBaseAddr();
} else {
* DebugStart
* Replaces the default debug session startup routine. Optional.
//void DebugStart (void) {
* TargetConnect
* Replaces the default target IF connection routine. Optional.
//void TargetConnect (void) {
* BeforeTargetConnect
//void BeforeTargetConnect (void) {
* AfterTargetConnect
//void AfterTargetConnect (void) {
* TargetDownload
* Replaces the default program download routine. Optional.
//void TargetDownload (void) {
* BeforeTargetDownload
//void BeforeTargetDownload (void) {
* AfterTargetDownload
/* void AfterTargetDownload (void) {
unsigned int SP;
unsigned int PC;
} else {
* BeforeTargetDisconnect
//void BeforeTargetDisconnect (void) {
* AfterTargetDisconnect
//void AfterTargetDisconnect (void) {
* AfterTargetHalt
//void AfterTargetHalt (void) {
It does'nt work for me.
My configuration is Windows 10 x64, Ozone 3.10a, J Link 6.54c
Hello Vidar,
Do you have any another idea about that ?
I can try again with Ozone 3.10 to see if I can replicate it. Do you mind sharing your Ozone project?
My Ozone project is just your configuration file that target an aws_fota sample built with SES.
