How can use Gpiote Interrupt with s110?
If the softdevice is not used, As follows:
static void gpio_init(void) {
  	  nrf_gpio_cfg_input(Record, NRF_GPIO_PIN_PULLUP);
      nrf_gpio_cfg_input(Play, NRF_GPIO_PIN_PULLUP);
      nrf_gpio_cfg_input(Menu_Dw, NRF_GPIO_PIN_PULLUP);
      NVIC_DisableIRQ(GPIOTE_IRQn);
	  NVIC_ClearPendingIRQ(GPIOTE_IRQn);
       NRF_GPIOTE->CONFIG[0] =  (GPIOTE_CONFIG_POLARITY_HiToLo << GPIOTE_CONFIG_POLARITY_Pos)
                   | (0x1E << GPIOTE_CONFIG_PSEL_Pos)
                   | (GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos);
                     NRF_GPIOTE->INTENSET  = GPIOTE_INTENSET_IN0_Set << GPIOTE_INTENSET_IN0_Pos;
       NRF_GPIOTE->CONFIG[1] =  (GPIOTE_CONFIG_POLARITY_HiToLo << GPIOTE_CONFIG_POLARITY_Pos)
                   | (0x1C << GPIOTE_CONFIG_PSEL_Pos)
                     NRF_GPIOTE->INTENSET  = GPIOTE_INTENSET_IN1_Set << GPIOTE_INTENSET_IN1_Pos;
  	  __NOP();
      __NOP();
      __NOP();
				/* Clear the event that appears in some cases */
				NRF_GPIOTE->EVENTS_IN[0] = 0;
				NRF_GPIOTE->EVENTS_IN[1] = 0;
      NRF_GPIOTE->INTENSET = GPIOTE_INTENSET_IN0_Enabled << GPIOTE_INTENSET_IN0_Pos;
	  NRF_GPIOTE->INTENSET = GPIOTE_INTENSET_IN1_Enabled << GPIOTE_INTENSET_IN1_Pos;
      NVIC_EnableIRQ(GPIOTE_IRQn);
void GPIOTE_IRQHandler(void) {
   if ((NRF_GPIOTE->EVENTS_IN[0] != 0))
	 menu_count++;
   if ((NRF_GPIOTE->EVENTS_IN[1] != 0))
     Record_Start = (!Record_Start) ;
In this case operates.
But not getting the behavior when I try to put a pin input for use with S110.
I would like to run when the button receives the input of the ad or when the Bluetooth connection to each other.
If I read a few comments, Recommend the use of app_gpiote library and app_button library together.
And the ble_app_bps example of the examples were recommended.
The following sources are part of the sample.
static void button_event_handler(uint8_t pin_no, uint8_t button_action) {
  if (button_action == APP_BUTTON_PUSH)
    switch (pin_no)
        case SEND_MEAS_BUTTON_PIN_NO:
            blood_pressure_measurement_send();
            APP_ERROR_HANDLER(pin_no);
static void gpiote_init(void) {
    APP_GPIOTE_INIT(APP_GPIOTE_MAX_USERS);
static void buttons_init(void) {
    static app_button_cfg_t buttons[] =
       {SEND_MEAS_BUTTON_PIN_NO,   false, BUTTON_PULL, button_event_handler},
       {BOND_DELETE_ALL_BUTTON_ID, false, BUTTON_PULL, NULL}
    APP_BUTTON_INIT(buttons, sizeof(buttons) / sizeof(buttons[0]), BUTTON_DETECTION_DELAY, false);
If the SEND_MEAS_BUTTON_PIN_NO button is pressed, the operation will be button_event_handler.
However, if you press the BOND_DELETE_ALL_BUTTON_ID button, I don't know what to work.
And I don't know how the interrupt occurs.
I don't understand function: APP_GPIOTE_INIT(APP_GPIOTE_MAX_USERS);
Not find an association between button and interrupt.
I will wait for the reply.
Help please~
  • Hi, GunMin!
    When we call APP_GPIOTE_INIT(APP_GPIOTE_MAX_USERS), the SDK call function: app_gpiote_init in app_gpiote.c and in this function the SDK initialise interrupt for GPIOTE_IRQn.
    The interrupt handler "GPIOTE_IRQHandler", defined in same src file (app_gpiote.c), where there is a call the callback-function, defined in struct app_button_cfg_t.
    if in app_button_cfg_t you do not define callback (4 parameter for each button), interrupt will not occur.
    In example "ble_app_bps" calback is null for button BOND_DELETE_ALL_BUTTON_ID because pressing for this button checked "manualy", through func. "nrf_gpio_pin_read" like this:
    nrf_gpio_pin_read(BOND_DELETE_ALL_BUTTON_ID) == 0.
    Best regards.
  • Thank you for your advice. I used the "app_button_enable ()" function. Um.. If the setting two buttons, Works well. But When the set of four buttons, Does not operate. I need four button.
