So I am using nRF52811 and I have noticed the battery voltage going at a constant rate and suddenly for a time of 2 mins the Voltage value (ADC) dips and it comes back to normal after approx 2 mins (sometimes very exact).
What could be the potential cause of it?
The code for the event is:
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event) { if (p_event->type == NRF_DRV_SAADC_EVT_DONE) { nrf_saadc_value_t adc_result; uint8_t percentage_batt_lvl; uint32_t err_code; adc_result = p_event->data.done.p_buffer[0]; err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result); // + DIODE_FWD_VOLT_DROP_MILLIVOLTS; // percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts); // err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl, BLE_CONN_HANDLE_ALL); NRF_LOG_INFO("-------Battery Voltage in mV: %d----------", batt_lvl_in_milli_volts); if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_RESOURCES) && (err_code != NRF_ERROR_BUSY) && (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING) ) { APP_ERROR_HANDLER(err_code); } } }
And initialization is:
static void adc_configure(void) { ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler); APP_ERROR_CHECK(err_code); nrf_saadc_channel_config_t config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD); // nrf_saadc_channel_config_t config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0); err_code = nrf_drv_saadc_channel_init(0, &config); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], SAADC_SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], SAADC_SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); }
Let me know if more information is needed.
