SAADC read on VDD giving a dip in value every 1 to 1.5 hours for approx 2 mins
So I am using nRF52811 and I have noticed the battery voltage going at a constant rate and suddenly for a time of 2 mins the Voltage value (ADC) dips and it comes back to normal after approx 2 mins (sometimes very exact).
What could be the potential cause of it?
The code for the event is:
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
        nrf_saadc_value_t adc_result;
        uint8_t           percentage_batt_lvl;
        uint32_t          err_code;
        adc_result = p_event->data.done.p_buffer[0];
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
        batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result);  // + DIODE_FWD_VOLT_DROP_MILLIVOLTS;
//        percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
//        err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl, BLE_CONN_HANDLE_ALL);
        NRF_LOG_INFO("-------Battery Voltage in mV: %d----------", batt_lvl_in_milli_volts);
        if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != NRF_ERROR_BUSY) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
And initialization is:
static void adc_configure(void)
    ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
    nrf_saadc_channel_config_t config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
//    nrf_saadc_channel_config_t config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    err_code = nrf_drv_saadc_channel_init(0, &config);
    err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], SAADC_SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], SAADC_SAMPLES_IN_BUFFER);
Let me know if more information is needed.
