nrf sniffer v3.0.0 on Mac OS does not work
    I tried to install the latest sniffer v3.0.0 and Wireshark v3.2.0 on my computer. I could not see PCA10056 listed. If I start my wireshark from command line, with "open -n /Application/Wireshark.app", I can see the device listed. But, when I start a capture, it crashed immediately.
    I checked the new python script, it seems it requires python3. Mac OS X uses python2 as default. I guess this is why I can see PCA10056 listed when I lunch my wireshark from command line, which has python 3 as default. I can not figure out what causes the crash. Here is my crash log FYI.
Min-Ching Ho
Process: Wireshark [25037]
Path: /Applications/Wireshark.app/Contents/MacOS/Wireshark
Identifier: org.wireshark.Wireshark
Version: 3.2.0 (3.2.0)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Wireshark [25037]
User ID: 501
Date/Time: 2020-01-02 16:26:03.435 -0800
OS Version: Mac OS X 10.15.2 (19C57)
Report Version: 12
Bridge OS Version: 4.2 (17P2551)
Anonymous UUID: E981E1E1-6616-0C99-A7BD-16BC5EDD4A6F
Time Awake Since Boot: 2600 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: EXC_I386_GPFLT
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [25037]
Application Specific Information:
Wireshark 3.2.0 (v3.2.0-0-ge0ed4cfa3d72)
Compiled (64-bit) with Qt 5.12.6, with libpcap, without POSIX capabilities, with
GLib 2.37.6, with zlib 1.2.11, with SMI 0.4.8, with c-ares 1.15.0, with Lua
5.2.4, with GnuTLS 3.4.17, with Gcrypt 1.7.7, with MIT Kerberos, with MaxMind DB
resolver, with nghttp2 1.39.2, with brotli, with LZ4, with Zstandard, with
Snappy, with libxml2 2.9.9, with QtMultimedia, with SpeexDSP (using bundled
resampler), with SBC, with SpanDSP, with bcg729.
Running on Mac OS X 10.15.2, build 19C57 (Darwin 19.2.0), with Intel(R) Core(TM)
i7-9750H CPU @ 2.60GHz (with SSE4.2), with 32768 MB of physical memory, with
locale en_US.UTF-8, with libpcap version 1.9.1, with GnuTLS 3.4.17, with Gcrypt
1.7.7, with brotli 1.0.7, with zlib 1.2.11, binary plugins supported (0 loaded).
Built using clang 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.16).
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libglib-2.0.0.dylib 0x000000010adb5819 g_list_find_custom + 73 (glist.c:787)
1 org.wireshark.Wireshark 0x0000000109a503b6 extcap_init_interfaces + 150
2 org.wireshark.Wireshark 0x0000000109a7d319 sync_pipe_start + 137
3 org.wireshark.Wireshark 0x0000000109a5bb0f capture_start + 127
4 org.wireshark.Wireshark 0x00000001097e74c5 MainWindow::startCapture() + 149
5 org.qt-project.QtCore 0x000000010b7bb8cc QMetaObject::activate(QObject*, int, int, void**) + 3132
6 org.wireshark.Wireshark 0x0000000109a2fb4e WelcomePage::qt_metacall(QMetaObject::Call, int, void**) + 62
7 org.qt-project.QtCore 0x000000010b7bb37d QMetaObject::activate(QObject*, int, int, void**) + 1773
8 org.wireshark.Wireshark 0x00000001097546d3 InterfaceFrame::on_interfaceTree_doubleClicked(QModelIndex const&) + 339
9 org.wireshark.Wireshark 0x0000000109a1bbbe InterfaceFrame::qt_metacall(QMetaObject::Call, int, void**) + 62
10 org.qt-project.QtCore 0x000000010b7bb37d QMetaObject::activate(QObject*, int, int, void**) + 1773
11 org.qt-project.QtWidgets 0x000000010a5d6927 QAbstractItemView::doubleClicked(QModelIndex const&) + 55
12 org.qt-project.QtWidgets 0x000000010a645753 QTreeView::mouseDoubleClickEvent(QMouseEvent*) + 803
13 org.qt-project.QtWidgets 0x000000010a3a94c2 QWidget::event(QEvent*) + 466
14 org.qt-project.QtWidgets 0x000000010a45122d QFrame::event(QEvent*) + 45
15 org.qt-project.QtWidgets 0x000000010a5d4eb9 QAbstractItemView::viewportEvent(QEvent*) + 1417
16 org.qt-project.QtWidgets 0x000000010a642155 QTreeView::viewportEvent(QEvent*) + 517
17 org.qt-project.QtCore 0x000000010b78a824 QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) + 148
18 org.qt-project.QtWidgets 0x000000010a36d768 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 248
19 org.qt-project.QtWidgets 0x000000010a3705d8 QApplication::notify(QObject*, QEvent*) + 7336
20 org.qt-project.QtCore 0x000000010b78a574 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 212
21 org.qt-project.QtWidgets 0x000000010a36e0a0 QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) + 896
22 org.qt-project.QtWidgets 0x000000010a3c891e 0x10a35d000 + 440606
23 org.qt-project.QtWidgets 0x000000010a3c7605 0x10a35d000 + 435717
24 org.qt-project.QtWidgets 0x000000010a36d77d QApplicationPrivate::notify_helper(QObject*, QEvent*) + 269
25 org.qt-project.QtWidgets 0x000000010a36eb82 QApplication::notify(QObject*, QEvent*) + 594
26 org.qt-project.QtCore 0x000000010b78a574 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 212
27 org.qt-project.QtGui 0x000000010b075bed QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 5293
28 org.qt-project.QtGui 0x000000010b05c41b QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 219
29 libqcocoa.dylib 0x000000010ddc4b30 0x10dd8f000 + 219952
30 libqcocoa.dylib 0x000000010ddc5298 0x10dd8f000 + 221848
31 com.apple.CoreFoundation 0x00007fff31a81b21 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
32 com.apple.CoreFoundation 0x00007fff31a81ac0 __CFRunLoopDoSource0 + 103
33 com.apple.CoreFoundation 0x00007fff31a818d4 __CFRunLoopDoSources0 + 209
34 com.apple.CoreFoundation 0x00007fff31a80740 __CFRunLoopRun + 1272
35 com.apple.CoreFoundation 0x00007fff31a7fbd3 CFRunLoopRunSpecific + 499
36 com.apple.HIToolbox 0x00007fff305d665d RunCurrentEventLoopInMode + 292
37 com.apple.HIToolbox 0x00007fff305d62a9 ReceiveNextEventCommon + 356
38 com.apple.HIToolbox 0x00007fff305d6127 _BlockUntilNextEventMatchingListInModeWithFilter + 64
39 com.apple.AppKit 0x00007fff2ec47eb4 _DPSNextEvent + 990
40 com.apple.AppKit 0x00007fff2ec46690 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1352
41 com.apple.AppKit 0x00007fff2ec383ae -[NSApplication run] + 658
42 libqcocoa.dylib 0x000000010ddc4013 0x10dd8f000 + 217107
43 org.qt-project.QtCore 0x000000010b785b8f QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 431
44 org.qt-project.QtCore 0x000000010b78ab82 QCoreApplication::exec() + 130
45 org.wireshark.Wireshark 0x00000001097ae4c7 main + 4423
46 libdyld.dylib 0x00007fff690dc7fd start + 1
Thread 1:
0 libsystem_pthread.dylib 0x00007fff692dc818 start_wqthread + 0
Thread 2:
Thread 3:: Thread (pooled)
0 libsystem_kernel.dylib 0x00007fff6921fce6 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff692e1185 _pthread_cond_wait + 701
2 org.qt-project.QtCore 0x000000010b5cad2f 0x10b5a0000 + 175407
3 org.qt-project.QtCore 0x000000010b5caa1e 0x10b5a0000 + 174622
4 org.qt-project.QtCore 0x000000010b5ca95c QWaitCondition::wait(QMutex*, QDeadlineTimer) + 108
5 org.qt-project.QtCore 0x000000010b5ca8be QWaitCondition::wait(QMutex*, unsigned long) + 62
6 org.qt-project.QtCore 0x000000010b5c7387 0x10b5a0000 + 160647
7 org.qt-project.QtCore 0x000000010b5c2203 0x10b5a0000 + 139779
8 libsystem_pthread.dylib 0x00007fff692e0e65 _pthread_start + 148
9 libsystem_pthread.dylib 0x00007fff692dc83b thread_start + 15
Thread 4:: Thread (pooled)
Thread 5:: QThread
2 org.qt-project.QtCore 0x000000010b5ca9fb 0x10b5a0000 + 174587
3 org.qt-project.QtCore 0x000000010b5ca95c QWaitCondition::wait(QMutex*, QDeadlineTimer) + 108
4 org.wireshark.Wireshark 0x00000001096dd45b CaptureFilterSyntaxWorker::start() + 155
5 org.qt-project.QtCore 0x000000010b7bb53b QMetaObject::activate(QObject*, int, int, void**) + 2219
6 org.qt-project.QtCore 0x000000010b5c19f8 QThread::started(QThread::QPrivateSignal) + 56
7 org.qt-project.QtCore 0x000000010b5c21e9 0x10b5a0000 + 139753
Thread 6:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff6921d25a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff6921d5d0 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff31a81d0b __CFRunLoopServiceMachPort + 322
3 com.apple.CoreFoundation 0x00007fff31a808e7 __CFRunLoopRun + 1695
4 com.apple.CoreFoundation 0x00007fff31a7fbd3 CFRunLoopRunSpecific + 499
5 com.apple.AppKit 0x00007fff2edeaa72 _NSEventThread + 132
6 libsystem_pthread.dylib 0x00007fff692e0e65 _pthread_start + 148
7 libsystem_pthread.dylib 0x00007fff692dc83b thread_start + 15
Thread 7:: Thread (pooled)
Thread 8:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff692255be __select + 10
1 com.apple.CoreFoundation 0x00007fff31aaad8a __CFSocketManager + 632
2 libsystem_pthread.dylib 0x00007fff692e0e65 _pthread_start + 148
3 libsystem_pthread.dylib 0x00007fff692dc83b thread_start + 15
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000600001e04280 rbx: 0x0400000200000005 rcx: 0x0000000000000008 rdx: 0x000000010ade0180
rdi: 0x0400000200000005 rsi: 0x0000600001e43680 rbp: 0x00007ffee656a790 rsp: 0x00007ffee656a770
r8: 0x000000000000007f r9: 0x00000000000007fb r10: 0x00007ffee656d858 r11: 0x000000010ada94c0
r12: 0x00006000025d5d00 r13: 0x0000000109da7d40 r14: 0x000000010ade0180 r15: 0x0000600001e43680
rip: 0x000000010adb5819 rfl: 0x0000000000010206 cr2: 0x0000000109d59980
Logical CPU: 4
Error Code: 0x00000000
Trap Number: 13
Binary Images:
0x109692000 - 0x109d53ff7 +org.wireshark.Wireshark (3.2.0 - 3.2.0) <0FF8B88F-2421-3985-B7E4-D4835AA9C3B2> /Applications/Wireshark.app/Contents/MacOS/Wireshark
0x10a1ea000 - 0x10a260fff +org.qt-project.QtMultimedia (5.12 - 5.12.6) <C54B4293-BD8C-3FF2-8036-0DB74DAD64C0> /Applications/Wireshark.app/Contents/Frameworks/QtMultimedia.framework/Versions/5/QtMultimedia
0x10a2b6000 - 0x10a2dfff7 +org.qt-project.QtPrintSupport (5.12 - 5.12.6) <9D1DB000-8A25-3B0D-AB64-DCDBC7D76C62> /Applications/Wireshark.app/Contents/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport
0x10a307000 - 0x10a33aff3 +org.qt-project.QtSvg (5.12 - 5.12.6) <5BED2F79-565B-3C71-BD9F-9B1B84E6248A> /Applications/Wireshark.app/Contents/Frameworks/QtSvg.framework/Versions/5/QtSvg
0x10a35d000 - 0x10a79bfff +org.qt-project.QtWidgets (5.12 - 5.12.6) <1416E75A-3EC5-316C-8692-FE0C4F886967> /Applications/Wireshark.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
0x10a90e000 - 0x10a916ffb +org.qt-project.QtMacExtras (5.12 - 5.12.6) <7D0257B5-5EDF-3E77-AF46-07A9CA584227> /Applications/Wireshark.app/Contents/Frameworks/QtMacExtras.framework/Versions/5/QtMacExtras
0x10a922000 - 0x10a973ff7 +org.sparkle-project.Sparkle (1.22.0 33-gd5222353e - 1.22.0) <1DA0A252-CD33-3E99-8A87-F67893C479C8> /Applications/Wireshark.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
0x10a9c9000 - 0x10a9d1ff7 +libminizip.1.dylib (0) <AEEFEAB2-9D6C-356E-9449-762806F5BF6B> /Applications/Wireshark.app/Contents/Frameworks/libminizip.1.dylib
0x10a9db000 - 0x10aa3fffb +libwiretap.10.dylib (0) <6EBAF01F-CDC5-3F6A-857A-199E1AFB86D1> /Applications/Wireshark.app/Contents/Frameworks/libwiretap.10.dylib
0x10aadc000 - 0x10aaf3fff +libwsutil.11.dylib (0) <FEBBBF91-72E8-3B10-B52F-106124AA32AC> /Applications/Wireshark.app/Contents/Frameworks/libwsutil.11.dylib
0x10ab0c000 - 0x10ab0dff7 +libgmodule-2.0.0.dylib (0) <9358B3B1-95B8-37BD-A6DA-952FC7BD1BA3> /Applications/Wireshark.app/Contents/Frameworks/libgmodule-2.0.0.dylib
0x10ab15000 - 0x10abc2ffb +libgcrypt.20.dylib (0) <CA82B884-B07B-3C86-A3C1-0376A49964C4> /Applications/Wireshark.app/Contents/Frameworks/libgcrypt.20.dylib
0x10ac05000 - 0x10ac12ff3 +libgpg-error.0.dylib (0) <9E2DAA8E-E573-310B-BEBB-8F440BD41B65> /Applications/Wireshark.app/Contents/Frameworks/libgpg-error.0.dylib
0x10ac23000 - 0x10ad0afe3 +libgnutls.30.dylib (0) <2EDF4494-325A-33AF-BEBF-2585B976FC70> /Applications/Wireshark.app/Contents/Frameworks/libgnutls.30.dylib
0x10ad84000 - 0x10ae8affb +libglib-2.0.0.dylib (0) <4F0FC618-07E1-3801-BC28-F295D0414DFC> /Applications/Wireshark.app/Contents/Frameworks/libglib-2.0.0.dylib
0x10aee7000 - 0x10aff1ff7 +org.qt-project.QtNetwork (5.12 - 5.12.6) <6944CDC6-04D9-3136-B0A3-55ADD0A12AC4> /Applications/Wireshark.app/Contents/Frameworks/QtNetwork.framework/Versions/5/QtNetwork
0x10b041000 - 0x10b48dfef +org.qt-project.QtGui (5.12 - 5.12.6) <B59D9CD9-F077-32AD-9AD5-335CACB61062> /Applications/Wireshark.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui
0x10b5a0000 - 0x10bad5fff +org.qt-project.QtCore (5.12 - 5.12.6) <60995246-616A-3A86-AB04-120A6756E50C> /Applications/Wireshark.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
0x10bba1000 - 0x10bbacffb +libbrotlidec.1.dylib (0) <42F1DAD1-C1BB-3EBA-8F66-EEFEDA961239> /Applications/Wireshark.app/Contents/Frameworks/libbrotlidec.1.dylib
0x10bbb5000 - 0x10bbc1ff7 +libcares.2.dylib (0) <FA1849ED-F492-37AB-BF37-D1EC1A44ADDE> /Applications/Wireshark.app/Contents/Frameworks/libcares.2.dylib
0x10bbca000 - 0x10bbcaffb +libgthread-2.0.0.dylib (0) <FE75477F-0DBE-3E33-8FBB-9E027DF3E5F8> /Applications/Wireshark.app/Contents/Frameworks/libgthread-2.0.0.dylib
0x10bbd1000 - 0x10bbebff7 +liblz4.1.dylib (0) <8C571FB6-33D4-36C6-BA28-3FE007612BB9> /Applications/Wireshark.app/Contents/Frameworks/liblz4.1.dylib
0x10bbf7000 - 0x10bc14ff3 +libnghttp2.14.dylib (0) <B8846DC1-7ECD-3F16-B7B8-AABC2D2A9036> /Applications/Wireshark.app/Contents/Frameworks/libnghttp2.14.dylib
0x10bc2d000 - 0x10bc74fff +libsmi.2.dylib (0) <1A17E3AA-36E2-3CD3-B7F9-FBAC62BD7CE0> /Applications/Wireshark.app/Contents/Frameworks/libsmi.2.dylib
0x10bc8c000 - 0x10bc90fff +libsnappy.1.dylib (0) <CD575607-E27B-3503-B2CC-9EAF639495F4> /Applications/Wireshark.app/Contents/Frameworks/libsnappy.1.dylib
0x10bc9c000 - 0x10bdcaff7 +libxml2.2.dylib (0) <16A4F10D-D808-3081-8A76-71DDDA35874C> /Applications/Wireshark.app/Contents/Frameworks/libxml2.2.dylib
0x10be38000 - 0x10bef4ff3 +libzstd.1.dylib (0) <2EE95F37-0ECA-3893-A427-EA40083BB7FE> /Applications/Wireshark.app/Contents/Frameworks/libzstd.1.dylib
0x10bf16000 - 0x10bf1eff3 +libintl.8.dylib (0) <9E7B8BE9-E20B-32E6-8D6F-21B8DE0662C8> /Applications/Wireshark.app/Contents/Frameworks/libintl.8.dylib
0x10bf2b000 - 0x10bf54ffb +libnettle.6.dylib (0) <AEFF1333-D9EB-32DC-81A7-11A88F392F88> /Applications/Wireshark.app/Contents/Frameworks/libnettle.6.dylib
0x10bf75000 - 0x10bf9dfff +libhogweed.4.dylib (0) <208E4810-F12F-3C9B-9FA3-2C0DBBA60415> /Applications/Wireshark.app/Contents/Frameworks/libhogweed.4.dylib
0x10bfb5000 - 0x10c037fdf +libgmp.10.dylib (0) <25545336-ADEC-3553-9B56-2BD6CBC2BB63> /Applications/Wireshark.app/Contents/Frameworks/libgmp.10.dylib
0x10c076000 - 0x10c095ffb +libbrotlicommon.1.dylib (0) <104C34A9-A8C6-3849-B447-68B7D506F501> /Applications/Wireshark.app/Contents/Frameworks/libbrotlicommon.1.dylib
0x10c09d000 - 0x10c0bcff7 +liblzma.5.dylib (0) <EA17B7BF-15B3-3E79-A511-777689A871D8> /Applications/Wireshark.app/Contents/Frameworks/liblzma.5.dylib
0x10dd8f000 - 0x10def6fff +libqcocoa.dylib (0) <E49F671D-85C8-3913-84BA-E4E00CD00D90> /Applications/Wireshark.app/Contents/PlugIns/platforms/libqcocoa.dylib
0x10df4b000 - 0x10dfa9fff +org.qt-project.QtDBus (5.12 - 5.12.6) <1E6A887D-D6B7-3020-B0A0-079D61B88955> /Applications/Wireshark.app/Contents/Frameworks/QtDBus.framework/Versions/5/QtDBus
0x10f199000 - 0x10f1a5fff +sbc.so (0) <3E87BA46-5DD7-31A9-A2DB-A30F878A2B07> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/codecs/sbc.so
0x10f24d000 - 0x10f2ddcb7 dyld (733.8) <EEA931D0-403E-3BC8-862A-CBA037DE4A74> /usr/lib/dyld
0x10f351000 - 0x1110ebffb +libwireshark.13.dylib (0) <3673E966-ECBA-3C3C-8FAC-CB7858374454> /Applications/Wireshark.app/Contents/Frameworks/libwireshark.13.dylib
0x1165b6000 - 0x1165dbfff +libqmacstyle.dylib (0) <C2A9B67D-3266-3AC3-A007-479E51FFB45C> /Applications/Wireshark.app/Contents/PlugIns/styles/libqmacstyle.dylib
0x1165f1000 - 0x1165f4047 libobjc-trampolines.dylib (781.2) <EB56CAD4-64BB-3EA4-B533-0E93F7DAEC45> /usr/lib/libobjc-trampolines.dylib
0x116686000 - 0x11668cff3 +libqgif.dylib (0) <6059B0E3-DF22-3CF2-AD44-FA93FA52F436> /Applications/Wireshark.app/Contents/PlugIns/imageformats/libqgif.dylib
0x116695000 - 0x11669cffb +libqicns.dylib (0) <AE21C5DC-A827-3673-9FE5-846736D1AA6C> /Applications/Wireshark.app/Contents/PlugIns/imageformats/libqicns.dylib
0x1166a5000 - 0x1166aaff3 +libqico.dylib (0) <42B21511-E28D-3F8E-BBFD-6FAB2223A837> /Applications/Wireshark.app/Contents/PlugIns/imageformats/libqico.dylib
0x1166b3000 - 0x116716ffb +libqjpeg.dylib (0) <D49B9F6B-5E6B-3C2A-AA4C-4B652A0FA3E4> /Applications/Wireshark.app/Contents/PlugIns/imageformats/libqjpeg.dylib
0x116721000 - 0x116726ff7 +libqmacheif.dylib (0) <096EF3F6-DADD-3301-9875-40B13A0A9431> /Applications/Wireshark.app/Contents/PlugIns/imageformats/libqmacheif.dylib
0x11672f000 - 0x116734ffb +libqmacjp2.dylib (0) <5649B472-D739-3C80-AA9B-F55BC6FB03D6> /Applications/Wireshark.app/Contents/PlugIns/imageformats/libqmacjp2.dylib
0x11673d000 - 0x116741fff +libqsvg.dylib (0) <39E344FE-4148-38A2-8937-8BC9584BC88C> /Applications/Wireshark.app/Contents/PlugIns/imageformats/libqsvg.dylib
0x11674a000 - 0x11674effb +libqtga.dylib (0) <E1F50446-DCA2-3AA9-8CD0-FC14E0F3BE22> /Applications/Wireshark.app/Contents/PlugIns/imageformats/libqtga.dylib
0x116757000 - 0x1167bcff3 +libqtiff.dylib (0) <F1DC54B7-23D1-3023-93C4-882DB0334939> /Applications/Wireshark.app/Contents/PlugIns/imageformats/libqtiff.dylib
0x1167ca000 - 0x1167cdff3 +libqwbmp.dylib (0) <AC3F1B1F-3942-3D21-9052-A96693CFF4BE> /Applications/Wireshark.app/Contents/PlugIns/imageformats/libqwbmp.dylib
0x1167d6000 - 0x11686aff7 +libqwebp.dylib (0) <4FEC6D57-C31C-3854-98CB-117D0C36D3C8> /Applications/Wireshark.app/Contents/PlugIns/imageformats/libqwebp.dylib
0x117601000 - 0x117604ff3 +usbdump.so (0) <71CC193C-82FD-3B64-AD65-66319F706C35> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/wiretap/usbdump.so
0x11b031000 - 0x11b042ffb +ethercat.so (0) <96F8D3BD-3DD7-35C8-B2B9-3EDC4DB74437> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/epan/ethercat.so
0x11b06f000 - 0x11b0b9ff7 +wimax.so (0) <CB0C17AF-831E-3B81-B717-B1C0C76941EE> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/epan/wimax.so
0x11b142000 - 0x11b150ff7 +wimaxasncp.so (0) <2A593C07-9815-37CD-BF03-5ADB2FB652C6> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/epan/wimaxasncp.so
0x11b15e000 - 0x11b162fff +stats_tree.so (0) <67E0E4CF-64F3-3B02-8D25-D2795EEBFFF5> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/epan/stats_tree.so
0x11b16b000 - 0x11b1acff3 +profinet.so (0) <D76904CA-41EA-3F4B-82CE-F6300442C110> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/epan/profinet.so
0x11b1fb000 - 0x11b201ff3 +transum.so (0) <6E760930-605E-39C5-9631-0A7807144659> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/epan/transum.so
0x11b20b000 - 0x11b21bff3 +gryphon.so (0) <4C6786DF-9847-35C5-94E3-F4C068EDAAEC> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/epan/gryphon.so
0x11b235000 - 0x11b245ffb +unistim.so (0) <4E548759-2E6D-3A22-846C-AE5100911B2F> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/epan/unistim.so
0x11b25f000 - 0x11b268ffb +irda.so (0) <1F66C778-B4C1-325B-B8B7-DEBD5B12FF00> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/epan/irda.so
0x11b277000 - 0x11b281ffb +wimaxmacphy.so (0) <D556858B-DD95-362B-A425-2D427DFDDF1D> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/epan/wimaxmacphy.so
0x11b297000 - 0x11b2a8ff3 +mate.so (0) <2772E8DA-CA13-3B29-9671-6108B79648CC> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/epan/mate.so
0x11b2c7000 - 0x11b2e5ff7 +opcua.so (0) <098B078F-EF73-3828-8F79-A952ED446571> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/epan/opcua.so
0x11cf84000 - 0x11cf87ff7 +g726.so (0) <FD4F0253-9AC7-3D0C-A2DF-38FD0ECD0A95> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/codecs/g726.so
0x11cf8f000 - 0x11d035ff3 +libspandsp.2.dylib (0) <9142B271-EB69-382B-BB22-3FA28089CCB0> /Applications/Wireshark.app/Contents/Frameworks/libspandsp.2.dylib
0x11d07f000 - 0x11d0cbfff +libtiff.3.dylib (0) <10C39628-DD9F-39AF-8F51-338166B8B3B8> /Applications/Wireshark.app/Contents/Frameworks/libtiff.3.dylib
0x11d0e5000 - 0x11d0e7ffb +g722.so (0) <5AB03580-AD8F-3358-AF47-AF2382091C00> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/codecs/g722.so
0x11d0ef000 - 0x11d0f1ff7 +g729.so (0) <C7F86B5A-DB5F-3C76-A221-08C11326005B> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/codecs/g729.so
0x11d0f9000 - 0x11d10dff3 +libbcg729.0.dylib (0) <20E33B9F-6A81-3F6E-82D1-3AEA85B1F1F4> /Applications/Wireshark.app/Contents/Frameworks/libbcg729.0.dylib
0x11d119000 - 0x11d11bff7 +l16mono.so (0) <C755D701-86AA-3D5B-8A92-625FCF7601BA> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/codecs/l16mono.so
0x11d123000 - 0x11d125ff3 +g711.so (0) <596038CB-E530-3757-9881-C0910CBB6B3D> /Applications/Wireshark.app/Contents/PlugIns/wireshark/3-2/codecs/g711.so
0x7fff26082000 - 0x7fff2628eff7 com.apple.RawCamera.bundle (9.00.1 - 1310.23) <5683F10A-5153-38D7-81F0-1063B5C5C1B3> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff26291000 - 0x7fff263b1ff5 com.apple.AMDMTLBronzeDriver (3.4.19 - 3.0.4) <42A2EFD5-F9A2-3A76-9D0C-A63BF800DC53> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x7fff2a6cb000 - 0x7fff2aadfff6 com.apple.driver.AppleIntelKBLGraphicsMTLDriver (14.3.9 - 14.0.3) <3E9269FA-FAB5-3ED0-9179-BA1F2AEEAAEF> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
0x7fff2d3bb000 - 0x7fff2d3bfffb com.apple.agl (3.3.3 - AGL-3.3.3) <AD706EA7-71F4-319F-B295-13F929FF1A01> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fff2d7a6000 - 0x7fff2d7a6fff com.apple.Accelerate (1.11 - Accelerate 1.11) <EEBE6680-1AAB-3192-AA7C-450537B07F27> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff2d7a7000 - 0x7fff2d7bdfff libCGInterfaces.dylib (524.2) <3DA50D4A-BE22-33FB-AE8E-4B68FE3294CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff2d7be000 - 0x7fff2de29fef com.apple.vImage (8.1 - 524.2) <2BDE5231-B5ED-313E-918A-876ACE1C0FCF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff2de2a000 - 0x7fff2e093fff libBLAS.dylib (1303.60.1) <94F6B3C0-5039-3F66-8B2E-98791287E459> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff2e094000 - 0x7fff2e383ff7 libBNNS.dylib (144.40.3) <F15D7D9E-0B9F-34FF-B144-DCA264614C54> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff2e385000 - 0x7fff2e72afff libLAPACK.dylib (1303.60.1) <DCC36295-FF39-35A1-8DF1-1E8A714E2265> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff2e72b000 - 0x7fff2e740ff8 libLinearAlgebra.dylib (1303.60.1) <E3C0CC64-906B-3B44-B8AA-3075BA20E161> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff2e741000 - 0x7fff2e746ff3 libQuadrature.dylib (7) <17EC31E3-3D77-3B5A-8ADD-6A3DBC1531E7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff2e747000 - 0x7fff2e7b7fff libSparse.dylib (103) <350DAE1C-C990-343F-A98A-1B4317EAA869> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff2e7b8000 - 0x7fff2e7cafef libSparseBLAS.dylib (1303.60.1) <8C0C7291-AC3A-3808-9D45-E359A5E03F0E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff2e7cb000 - 0x7fff2e9a4ffb libvDSP.dylib (735.40.1) <BD49856D-39CE-397F-A069-63B2F0D79529> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff2e9a5000 - 0x7fff2ea60fd7 libvMisc.dylib (735.40.1) <9C40AC77-59A4-3180-AA4F-8F13CABF02D9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff2ea61000 - 0x7fff2ea61fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A8B35A80-7217-38B1-8A20-E8B4F73124F0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff2ea62000 - 0x7fff2eac1ffc com.apple.Accounts (113 - 113) <ABA6CA9E-22B4-3EE9-8C8D-080CB863FD72> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff2ec07000 - 0x7fff2f9c2fff com.apple.AppKit (6.9 - 1894.20.140) <80D94BA8-5CEC-3D85-AEE9-364513234AC6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2fa12000 - 0x7fff2fa12fff com.apple.ApplicationServices (48 - 50) <DD9B7CF2-A6CA-3C88-804A-C15AFFEC3CD6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff2fa13000 - 0x7fff2fa7efff com.apple.ApplicationServices.ATS (377 - 493.0.2.1) <6BDB3B14-0F4E-3B10-93C8-7F0E5E4F2EFE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff2fb17000 - 0x7fff2fb55ff8 libFontRegistry.dylib (274.0.2.3) <3DD574D6-06F2-35A1-8CE0-6097BDD3DE1F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff2fbb0000 - 0x7fff2fbdfff7 com.apple.ATSUI (1.0 - 1) <FA934D50-2391-3515-95D4-35696E165C37> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff2fbe0000 - 0x7fff2fbe4ff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <C0801FB4-954F-3897-B384-276B73B062B5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff2fc7f000 - 0x7fff2fcd5ff2 com.apple.HIServices (1.22 - 674.1) <8A3BBFB0-D41E-3BF1-AF8F-4E9082A49FC6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff2fcd6000 - 0x7fff2fce4fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <BEDFF67B-5FD5-38FA-AC8F-D9458DC2EF50> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff2fce5000 - 0x7fff2fd2aff2 com.apple.print.framework.PrintCore (15 - 516) <14C48FDF-5E58-391B-873E-B96E55CDA21C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff2fd2b000 - 0x7fff2fd35fff com.apple.QD (4.0 - 413) <AD40EB5E-231E-39C5-A468-5B979374912C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff2fd36000 - 0x7fff2fd43ff0 com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <16454C5C-4029-396A-A8F4-730E50CE2024> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff2fd44000 - 0x7fff2fe24ffa com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <9F13C2FB-6042-339A-8D85-E8E499BA856B> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff2fe26000 - 0x7fff2fe26fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <22A443ED-28B0-3161-9CF6-890FD03275D3> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff3019c000 - 0x7fff30528ff6 com.apple.CFNetwork (1121.1.2 - 1121.1.2) <CD7AA80C-C73B-39C7-AE03-A36BFB936F29> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff305a2000 - 0x7fff305a2fff com.apple.Carbon (160 - 162) <27DBFB11-A568-3C45-B98D-F5F5165E939B> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff305a3000 - 0x7fff305a6ffb com.apple.CommonPanels (1.2.6 - 101) <AE22F241-E6CE-3F18-9EB5-437CF0FDE477> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff305a7000 - 0x7fff3089bffb com.apple.HIToolbox (2.1.1 - 994) <21D1507B-BFC3-33B7-88FE-64417FE9CAD5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff3089c000 - 0x7fff3089fff3 com.apple.help (1.3.8 - 68) <94E3E502-C479-3C37-8927-239FFF0205B3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff308a0000 - 0x7fff308a5ff7 com.apple.ImageCapture (9.0 - 1600.25.4.1) <89D63EAA-364C-34B4-A417-7A51BF52C4AE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff308a6000 - 0x7fff308a6fff com.apple.ink.framework (10.15 - 227) <66BD9432-DB9B-33EC-85B2-F5F21F39C4C3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff308a7000 - 0x7fff308c1ff2 com.apple.openscripting (1.7 - 185.1) <DF25310B-227E-3DB5-948C-E52F9877DEE7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff308e2000 - 0x7fff308e2fff com.apple.print.framework.Print (15 - 271) <27E1B868-53A4-3207-B36A-F08BDCBBBB3D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff308e3000 - 0x7fff308e5ff7 com.apple.securityhi (9.0 - 55008) <2C8B6D0E-3089-3964-B305-9EC3F74673A5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff308e6000 - 0x7fff308ecff7 com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <93A00BEB-FEE0-3FC6-ABCA-846EDA81818E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff30a95000 - 0x7fff30c80ff7 com.apple.ColorSync (4.13.0 - 3394.3) <2DCA9B8E-1202-36F0-8867-AF4F687E17D2> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff30f70000 - 0x7fff3147fffa com.apple.audio.CoreAudio (5.0 - 5.0) <E297B888-EC18-3333-AB26-5C80F4A2E40A> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff314d2000 - 0x7fff31509ff0 com.apple.CoreBluetooth (1.0 - 1) <C2C12610-0109-35C0-BAFF-871D41D9EDE2> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff3150a000 - 0x7fff318ecffe com.apple.CoreData (120 - 977.1) <B2656DA8-4BB1-3D54-AD5A-C02EDFD56AA3> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff318ed000 - 0x7fff319fcff6 com.apple.CoreDisplay (1.0 - 186.3.8) <33C67C14-A3D8-36D8-96E4-3F5D61F6F7B2> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff319fd000 - 0x7fff31e7dfe7 com.apple.CoreFoundation (6.9 - 1674.103) <D1F93A5F-5FB9-3088-BC16-36DBF58144C0> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff31e7f000 - 0x7fff324f8ff0 com.apple.CoreGraphics (2.0 - 1348.15) <21459707-0D60-3520-9999-49511ED16D85> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff32506000 - 0x7fff32863ff5 com.apple.CoreImage (15.0.0 - 920.9) <0A757F12-78A7-3C10-8F1D-118D855F6C65> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff32c27000 - 0x7fff32d01ff4 com.apple.CoreMedia (1.0 - 2520.9.4.1) <A53EF3A8-E192-3045-B4EA-8A05D1C5B521> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff32ded000 - 0x7fff32dedfff com.apple.CoreServices (1069.11 - 1069.11) <DD05556D-DEF3-348D-878D-CA3AB5C91D66> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff32dee000 - 0x7fff32e73fff com.apple.AE (838 - 838) <1D2A4944-20FA-372A-B8DE-01067521CF8C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff32e74000 - 0x7fff33155ff7 com.apple.CoreServices.CarbonCore (1217 - 1217) <17EE58A1-232F-3E35-AC81-C88509A1CE8F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff33156000 - 0x7fff331a3ffd com.apple.DictionaryServices (1.2 - 323.3) <631AEDD4-9328-33A7-ACE5-5FDE790FE7FD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff331a4000 - 0x7fff331acfff com.apple.CoreServices.FSEvents (1268.60.1 - 1268.60.1) <9C5A3C2D-CA76-329E-B80C-9CA1A1B1BE51> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff331ad000 - 0x7fff333e6ff0 com.apple.LaunchServices (1069.11 - 1069.11) <7D9167B7-8C60-3F42-BA15-8A85E6238FD2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff333e7000 - 0x7fff3347fff9 com.apple.Metadata (10.7.0 - 2075.4) <E57FA2CF-3BD5-3947-84CC-976F192C07C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff33480000 - 0x7fff334adff7 com.apple.CoreServices.OSServices (1069.11 - 1069.11) <C7F894DA-EA68-3467-B004-1D6C7D58703A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff334ae000 - 0x7fff33515fff com.apple.SearchKit (1.4.1 - 1.4.1) <644BE782-F3CA-3CC2-A062-5472ECC68230> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff33516000 - 0x7fff3353aff5 com.apple.coreservices.SharedFileList (131.3 - 131.3) <3B586025-C347-38CF-B89F-9942CB88AA79> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff33863000 - 0x7fff33a17ffe com.apple.CoreText (643.1.2.3 - 643.1.2.3) <97DA20DE-64C9-3589-92EB-BEC07B81EF19> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff33a18000 - 0x7fff33a5cfff com.apple.CoreVideo (1.8 - 334.0) <63E19193-0864-373F-AC59-DC97514B02A5> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff33a5d000 - 0x7fff33aeaff9 com.apple.framework.CoreWLAN (13.0 - 1455.3) <DC360D58-99EE-3760-9D79-5712B2872497> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff33d8a000 - 0x7fff33d90fff com.apple.DiskArbitration (2.7 - 2.7) <8B55B221-DB4E-3CCD-B104-FC52A4127A66> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff33f84000 - 0x7fff340aaff6 com.apple.FileProvider (265 - 265) <5A6F54E2-6B39-318D-A4BD-83E6FA2679D3> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff340c2000 - 0x7fff3448aff4 com.apple.Foundation (6.9 - 1674.103) <9D7DB588-6BDC-3D7B-B267-761D4ECC88A9> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff344f7000 - 0x7fff34547ff7 com.apple.GSS (4.0 - 2.0) <03016123-6D22-33EA-B9A7-EB60DD458FAB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff34682000 - 0x7fff3479aff8 com.apple.Bluetooth (7.0.2 - 7.0.2f4) <33538BF2-D6D3-3BF2-844D-A11C118E479E> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff34801000 - 0x7fff348a4ffb com.apple.framework.IOKit (2.0.2 - 1726.60.2) <65BD2F00-4BC5-3EF6-BF4D-DA1F0513E2B9> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff348a6000 - 0x7fff348b6ffc com.apple.IOSurface (269.6 - 269.6) <D90653D3-7E7F-3CFF-8F00-931B0AA725B1> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff3492c000 - 0x7fff34a89ffe com.apple.ImageIO.framework (3.3.0 - 1972.15) <EB8B6FA3-46BF-3358-848C-49A8BC86E277> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff34a8a000 - 0x7fff34a8dfff libGIF.dylib (1972.15) <2455E308-AF71-31A8-909B-35FC74A12CCD> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff34a8e000 - 0x7fff34b48fe7 libJP2.dylib (1972.15) <B83242E3-6504-3AA6-84F4-916A264C9660> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff34b49000 - 0x7fff34b6dfef libJPEG.dylib (1972.15) <7358172D-7732-3ECA-ABA3-725787905AC9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff34deb000 - 0x7fff34e05fef libPng.dylib (1972.15) <FC12703E-0CFA-3C06-9748-4AF1121C28BA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff34e06000 - 0x7fff34e07fff libRadiance.dylib (1972.15) <7CA6773D-F597-3DEB-8DBE-33B8CD3A1B3D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff34e08000 - 0x7fff34e51feb libTIFF.dylib (1972.15) <32E24562-BA64-388E-8AD5-864C184C77BC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff352ca000 - 0x7fff3625fff1 com.apple.JavaScriptCore (15608 - 15608.4.9.1.3) <64A51AB1-7CE5-3047-8E1C-ECDC49B97A5E> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff36277000 - 0x7fff36289ff3 com.apple.Kerberos (3.0 - 1) <A7787101-9525-3C28-BDD5-77B3C73ED8B0> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff3628a000 - 0x7fff3628afff libHeimdalProxy.dylib (77) <CB20F0B8-EDC1-3592-8B2D-6AEF80BE080B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff3661d000 - 0x7fff36627ff3 com.apple.MediaAccessibility (1.0 - 125) <A2CC9230-534D-3D1E-96E7-33EB54EBB8CF> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff366f3000 - 0x7fff36e38ff7 com.apple.MediaToolbox (1.0 - 2520.9.4.1) <C11D9AAA-0B53-3FE5-A9B8-8E3EB34F7B87> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff36e3a000 - 0x7fff36efdff1 com.apple.Metal (212.2.4 - 212.2.4) <EC7C6127-B280-3EF0-AA80-5FB505148EED> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff36f1a000 - 0x7fff36f56ff3 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <7B7AF6B3-CD50-320A-85CA-45958CDF850A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff36f57000 - 0x7fff36fddfe6 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <3D396C87-5CA4-3A8F-8EEF-FFE3883AD75A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff36fde000 - 0x7fff37002ff8 com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <D7E077C7-9332-30F9-8AFE-F02520EDF96B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff37003000 - 0x7fff37018fff com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <EE87BFE1-5811-3A0C-BC68-6966D7FEDAE5> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff37019000 - 0x7fff37178ff4 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <08A6AF10-E23F-3F1D-AA26-E79E7FC09B07> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff37179000 - 0x7fff371c7fff com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <6FA84C3F-72F0-3234-9406-8F9EB922D3A2> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff371c8000 - 0x7fff371c9ff5 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <4DB9192E-5464-3A78-A9D3-35153717A21F> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff3810f000 - 0x7fff3811bffe com.apple.NetFS (6.0 - 4.0) <C803F10A-5C01-365B-A988-64B021DCDDD5> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff3811c000 - 0x7fff3825fff6 com.apple.Network (1.0 - 1) <B87BEA5C-05CF-3284-BB74-33F9297225F8> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff3ac88000 - 0x7fff3ace0ff7 com.apple.opencl (3.5 - 3.5) <987CE84F-AC14-3CD4-9233-51CA828DA927> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff3ace1000 - 0x7fff3acfdfff com.apple.CFOpenDirectory (10.15 - 220.40.1) <BD6064BC-F588-3A34-A70C-CF8B62CA04E0> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff3acfe000 - 0x7fff3ad09ff7 com.apple.OpenDirectory (10.15 - 220.40.1) <17B8A217-97DE-3DCA-B91B-6FB68451B94B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff3b664000 - 0x7fff3b666fff libCVMSPluginSupport.dylib (17.10.22) <F040B206-0834-3D3C-8941-B89F74D1F054> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff3b667000 - 0x7fff3b66cfff libCoreFSCache.dylib (176.10) <72D4F770-DB3F-3242-B3DB-8488D910BD47> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff3b66d000 - 0x7fff3b671fff libCoreVMClient.dylib (176.10) <05AF05BB-AE62-39F9-BDEA-1BB1EE643301> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff3b672000 - 0x7fff3b67aff7 libGFXShared.dylib (17.10.22) <6F327728-FC25-3428-B734-824B48EFC20B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff3b67b000 - 0x7fff3b685fff libGL.dylib (17.10.22) <EA373BF1-0720-31A6-A5EF-8F1E67787264> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff3b686000 - 0x7fff3b6bbfff libGLImage.dylib (17.10.22) <6B0D6644-CEB0-3821-BAD4-05A56369A4F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff3b84f000 - 0x7fff3b88bfff libGLU.dylib (17.10.22) <3516B087-6286-3831-9706-87634DB3AF07> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff3c2bb000 - 0x7fff3c2caff7 com.apple.opengl (17.10.22 - 17.10.22) <43B981BE-B730-345F-9AA4-49D075EBE0DB> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff3d285000 - 0x7fff3d503ff0 com.apple.QuartzCore (1.11 - 815.26) <D0953F98-5F8A-3346-8438-DBD870E9088B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff3e053000 - 0x7fff3e3a5ffa com.apple.security (7.0 - 59306.61.1) <8B67829D-DDEB-3208-A4CE-FD5A57B1A0BB> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff3e3a6000 - 0x7fff3e42fff7 com.apple.securityfoundation (6.0 - 55236.60.1) <D4B6FD66-8DB2-3373-B192-00CB9DFF9AA7> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff3e430000 - 0x7fff3e45dfff com.apple.securityinterface (10.0 - 55139.0.1) <07F256E9-7920-3463-9D69-CC3D90C9748A> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff3e45e000 - 0x7fff3e462ff0 com.apple.xpc.ServiceManagement (1.0 - 1) <AC719A11-8152-3BA1-9A01-62AD8A8F4022> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff3f1f3000 - 0x7fff3f25dfff com.apple.SystemConfiguration (1.19 - 1.19) <96A25B9C-51EA-33B2-B681-B92365686CDB> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff3f4d9000 - 0x7fff3f833ffc com.apple.VideoToolbox (1.0 - 2520.9.4.1) <DF0BB3D7-2F3E-3BDA-ACE5-C1E0AA17CA6B> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff3fad6000 - 0x7fff401deff6 libwebrtc.dylib (7608.4.9.1.3) <F9BB64FB-A0CA-3424-ABBD-460489CC4904> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff401df000 - 0x7fff42384ff8 com.apple.WebCore (15608 - 15608.4.9.1.3) <7A597B98-6D52-3353-B1D6-7EE11A8E85B9> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff42385000 - 0x7fff4257eff3 com.apple.WebKitLegacy (15608 - 15608.4.9.1.3) <C0CCBCB3-22D9-3091-B0A0-53407C16CCC0> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff4257f000 - 0x7fff42c2bff1 com.apple.WebKit (15608 - 15608.4.9.1.3) <DC0681CC-769C-3E6C-938F-2EEAB83CA059> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff42fcc000 - 0x7fff43090fe7 com.apple.APFS (1412.61.1 - 1412.61.1) <AB316478-3C6D-33C1-A060-47D836CD01E1> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff436c3000 - 0x7fff436ceffd com.apple.accessibility.AXCoreUtilities (1.0 - 1) <1FE481DC-6BA1-3733-BF7A-84CD22EC7D50> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
0x7fff4383f000 - 0x7fff43847ff6 com.apple.AccessibilityBundles (1.0 - 131.1) <F6B5B01F-FE3B-31C2-8DC2-D31E52AD5602> /System/Library/PrivateFrameworks/AccessibilityBundles.framework/Versions/A/AccessibilityBundles
0x7fff44183000 - 0x7fff44184ff1 com.apple.AggregateDictionary (1.0 - 1) <29A10B7A-673A-3930-AB40-F1A57CE2D41E> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff44694000 - 0x7fff446b1ffc com.apple.AppContainer (4.0 - 448.60.2) <EDF36C00-E6DD-399C-A096-E837956D396C> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff44706000 - 0x7fff44714ff7 com.apple.AppSandbox (4.0 - 448.60.2) <FE493C66-50EB-3B23-A88A-5886D1C1543E> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff44ba3000 - 0x7fff44bc7ff3 com.apple.framework.Apple80211 (13.0 - 1460.1) <4358EB87-7120-30C3-9517-A99F2B31E8ED> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff44cfd000 - 0x7fff44d0cfef com.apple.AppleFSCompression (119 - 1.0) <48D076F0-D93E-3EFE-8400-9A7615D34F9F> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff44e0b000 - 0x7fff44e16ff7 com.apple.AppleIDAuthSupport (1.0 - 1) <1C27C132-6261-33D8-A2E2-2AC85AAA7494> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff44e58000 - 0x7fff44ea0fff com.apple.AppleJPEG (1.0 - 1) <E24CA921-96D1-356A-9E24-F5BB15BA123A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff45280000 - 0x7fff452a2fff com.apple.applesauce (1.0 - 16.22) <FB2BE134-D950-39FC-9912-C53B1CCFC38F> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff45362000 - 0x7fff45365ffb com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <1374869E-E504-3C4F-999E-DF08DCF2643B> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff45366000 - 0x7fff453b6ff7 com.apple.AppleVAFramework (6.1.2 - 6.1.2) <583AA51D-9755-3558-AAE0-8141D05810B1> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff453ff000 - 0x7fff4540eff9 com.apple.AssertionServices (1.0 - 223.60.4) <2C4FB378-B226-3134-A39E-ECB46B6FA5FA> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff4594d000 - 0x7fff45d4bff4 com.apple.audio.AudioResourceArbitration (1.0 - 1) <88BB4F0D-F9DD-3F63-B11D-21DB1365C7C8> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff45fa2000 - 0x7fff461dfff7 com.apple.audio.AudioToolboxCore (1.0 - 1104.30) <20C1EA64-71AD-326A-A552-E37DC0D907BE> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff461e0000 - 0x7fff462f9ff4 com.apple.AuthKit (1.0 - 1) <1AE3B67D-F772-3711-9D9B-3B0AF9C31680> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff464b4000 - 0x7fff464bdff3 com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <C12221CF-CA5D-333F-B384-201235F2AB92> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff464be000 - 0x7fff4655fff8 com.apple.backup.framework (1.11.2 - 1298.2.10) <29722310-281C-3DD8-A096-A3D4ECCD6176> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff46560000 - 0x7fff465e1ffd com.apple.BaseBoard (464.1 - 464.1) <9D9C02DD-412F-3678-8618-E11632006139> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff466e3000 - 0x7fff4671ffff com.apple.bom (14.0 - 219.2) <6DAE8ED0-92B1-3E4B-B54C-E30D5588E02B> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff472a5000 - 0x7fff472f4fff com.apple.ChunkingLibrary (302 - 302) <C9AFF6B0-8BBC-3FE7-BD65-0631E06DA637> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff481b4000 - 0x7fff481c5fff com.apple.CommonAuth (4.0 - 2.0) <4DB8B487-119C-3606-9F9D-A62AAB097D3D> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff481d9000 - 0x7fff481f0fff com.apple.commonutilities (8.0 - 900) <3F9742B4-C4D6-3EE8-89C2-1630F7C754CF> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff488e7000 - 0x7fff48cbcfc8 com.apple.CoreAUC (283.0.0 - 283.0.0) <54B58388-0D28-35E4-B4BD-9C1D279BD9ED> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff48cbd000 - 0x7fff48cebffb com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <E57A2D84-4A66-35F6-A888-314AB0852643> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff48d0e000 - 0x7fff48d2dff0 com.apple.analyticsd (1.0 - 1) <9AD0F7A2-37DE-3F14-A843-D573DED81646> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff49284000 - 0x7fff49294ff3 com.apple.CoreEmoji (1.0 - 107) <4BBD8552-5D0D-32F7-AB41-85A51F59B2CA> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff498e8000 - 0x7fff49952ff0 com.apple.CoreNLP (1.0 - 213) <682C4550-F662-3BD0-BD30-A4BEF5E2B74B> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff49c52000 - 0x7fff49c56fff com.apple.CoreOptimization (1.0 - 1) <03521FDF-9424-342A-8F07-6496FB63B228> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff49dc4000 - 0x7fff49dccff0 com.apple.CorePhoneNumbers (1.0 - 1) <8E2800B5-D750-340B-824C-F294A3581D51> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff49dcd000 - 0x7fff49e1f94b com.apple.CorePrediction (1.0 - 1) <014EE8D2-E93D-3D6B-9186-8C662292C0BD> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff4a519000 - 0x7fff4a53cff7 com.apple.CoreSVG (1.0 - 129) <DF071FDE-1BE6-3899-B203-29275A39AD1E> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff4a53d000 - 0x7fff4a570ff7 com.apple.CoreServicesInternal (446.6 - 446.6) <B7CEA8A6-6C94-3E88-844D-6A3169CC2BA9> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff4a571000 - 0x7fff4a59fff7 com.apple.CSStore (1069.11 - 1069.11) <C7CCB364-F4ED-3E46-90D6-1376F10F8DB3> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff4aaa2000 - 0x7fff4ab29fff com.apple.CoreSymbolication (11.0 - 64509.98.1) <38CCC6A0-E7F8-3FE0-A3E2-DF27CC6C8A58> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff4abc1000 - 0x7fff4acedff4 com.apple.coreui (2.1 - 608.3) <98D37B78-FC09-3D5B-B3F6-2B8A0E20360B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff4acee000 - 0x7fff4ae89ff6 com.apple.CoreUtils (6.1 - 610.18) <CCC7314C-57F5-3528-B6F4-C470385069AF> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff4afbe000 - 0x7fff4afd1ff1 com.apple.CrashReporterSupport (10.13 - 15011) <72E8461C-DA63-3768-84DC-FB52DCB0CC4F> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff4b23b000 - 0x7fff4b24dffc com.apple.framework.DFRFoundation (1.0 - 252) <B5747371-51E9-30C2-A80E-AB995925CEB5> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff4b24e000 - 0x7fff4b253fff com.apple.DSExternalDisplay (3.1 - 380) <58AB05D2-DA0C-376E-972B-F50A774D726D> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff4b2bc000 - 0x7fff4b337ff8 com.apple.datadetectorscore (8.0 - 659) <FA91248B-4B1A-355B-BC2D-E6531DD67863> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff4b383000 - 0x7fff4b3c1ff0 com.apple.DebugSymbols (194 - 194) <63EC0BF1-7FAC-3234-870A-0AB25921DADB> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff4b3c2000 - 0x7fff4b51effe com.apple.desktopservices (1.14.2 - 1281.2.6) <61257EE1-FBCA-3B57-84C8-6EA97BCF39CC> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff4b534000 - 0x7fff4b540ff8 com.apple.DeviceIdentity (1.0 - 1) <892CAAF3-34EB-35EC-9776-DB906A123488> /System/Library/PrivateFrameworks/DeviceIdentity.framework/Versions/A/DeviceIdentity
0x7fff4cd5f000 - 0x7fff4d17aff9 com.apple.vision.FaceCore (4.3.0 - 4.3.0) <8B2604AE-C6F8-3A53-8A94-DBA2A762EC2B> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff4d7de000 - 0x7fff4d915ffc libFontParser.dylib (277.2.1.2) <06A40213-0043-31F3-9AF5-DA513322DA20> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff4d916000 - 0x7fff4d94afff libTrueTypeScaler.dylib (277.2.1.2) <84394970-1C12-3DFB-A72F-9E80944B2191> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
0x7fff4d9af000 - 0x7fff4d9bfff6 libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <DF14F485-8D5C-3F5F-9846-7433958B752F> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff50e84000 - 0x7fff50e85fff libmetal_timestamp.dylib (902.11.1) <815B0315-2A6A-374E-A9F5-A86A8242482B> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff5252c000 - 0x7fff52532fff com.apple.GPUWrangler (4.5.21 - 4.5.21) <ACFA40E7-18A3-3A98-BCB3-0196FFD230D2> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff5284e000 - 0x7fff52874ffb com.apple.GenerationalStorage (2.0 - 313) <EF5FDA24-EE14-3EF6-BF2B-FA72FFA175C6> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff53998000 - 0x7fff539a6ffb com.apple.GraphVisualizer (1.0 - 100.1) <F59FCBF7-63DA-3C59-945E-E5BB66C4CCFF> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff539a7000 - 0x7fff539b4ff3 com.apple.GraphicsServices (1.0 - 1.0) <6F699A79-94DA-309F-921C-279FCCFE0433> /System/Library/PrivateFrameworks/GraphicsServices.framework/Versions/A/GraphicsServices
0x7fff53b39000 - 0x7fff53bf6ff4 com.apple.Heimdal (4.0 - 2.0) <DE4CE40D-4797-3793-97FE-49FC4B764E56> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff55d2b000 - 0x7fff55d34ffe com.apple.IOAccelMemoryInfo (1.0 - 1) <FAD3EC99-3809-3AC0-836E-E9377189EA69> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff55d35000 - 0x7fff55d3dffd com.apple.IOAccelerator (438.2.8 - 438.2.8) <15817F17-2AF1-32DF-8A6C-DD65B80075D7> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff55d40000 - 0x7fff55d56ff7 com.apple.IOPresentment (1.0 - 37) <F70AC027-E18E-39BC-A96E-ED15B802C832> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff560e0000 - 0x7fff5612bff4 com.apple.IconServices (438.3 - 438.3) <1F6BDF56-6C42-3C29-BD16-5C9921C64D87> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff562e9000 - 0x7fff562efffc com.apple.InternationalSupport (1.0 - 45) <5A076C86-0CA4-338E-AEC1-1C8F5E601DA3> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff56530000 - 0x7fff56550ff6 com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <665A02F2-2DC9-3BE1-8A91-DC8629495B1D> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff566a8000 - 0x7fff56776ff5 com.apple.LanguageModeling (1.0 - 215.1) <34D9FCAB-CDB6-3F3A-AAD8-A9D0A0713AE3> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff56777000 - 0x7fff567bfff7 com.apple.Lexicon-framework (1.0 - 72) <7413459B-0E19-3C4F-BB84-4E8914875C2D> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff567c6000 - 0x7fff567caff2 com.apple.LinguisticData (1.0 - 353.6) <63A3EE9B-A415-31A0-88DA-278AC277E1B1> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff57064000 - 0x7fff57067fff com.apple.Mangrove (1.0 - 25) <B7599CE8-F263-314E-BE6D-454A183C08B0> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff572d0000 - 0x7fff5735aff0 com.apple.MediaExperience (1.0 - 1) <560BBD61-82DB-33F0-8EF5-B0DF6DCAA7BB> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff57b24000 - 0x7fff57b70fff com.apple.spotlight.metadata.utilities (1.0 - 2075.4) <65B49E2A-EF09-30EB-9821-4B348E35EE0B> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff57b71000 - 0x7fff57c3fffd com.apple.gpusw.MetalTools (1.0 - 1) <0E41F3B9-EEB3-35AD-8464-75864345693A> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff57c99000 - 0x7fff57cb2ff8 com.apple.MobileAssets (1.0 - 619.60.1) <FAEEE25D-5258-3C1F-8A2E-355FFC46CC43> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff57e6f000 - 0x7fff57e8dff7 com.apple.MobileKeyBag (2.0 - 1.0) <8C650D8D-3711-32C6-AF4B-E0F165B55B5E> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff580f4000 - 0x7fff58122ff7 com.apple.MultitouchSupport.framework (3420.2 - 3420.2) <1BB8C03E-ACBA-3042-9AFA-A918B6183C01> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff58621000 - 0x7fff5862bfff com.apple.NetAuth (6.2 - 6.2) <CB6D1EE0-3397-3254-A67B-FB24ABC3CF43> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff5901c000 - 0x7fff59068ff7 com.apple.OTSVG (1.0 - 643.1.2.3) <21D6DEC5-89CF-3856-977F-FFB033605FF6> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff5a1fe000 - 0x7fff5a209ffe com.apple.PerformanceAnalysis (1.243.1 - 243.1) <3D906473-45A4-3C06-93DB-F66ACF9E217D> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff5a20a000 - 0x7fff5a232ffb com.apple.persistentconnection (1.0 - 1.0) <FDBC8DE5-1C73-3D5C-A9BA-3C391B10A7BD> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff5cb7f000 - 0x7fff5cb98fff com.apple.ProtocolBuffer (1 - 274.20.7.15.1) <7CE69139-FFAC-3C48-A491-39604B93CA37> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff5cf81000 - 0x7fff5cf8dff5 com.apple.xpc.RemoteServiceDiscovery (1.0 - 1738.61.1) <A7D53BC4-CB1C-307D-BA72-C228469954DB> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff5cfa1000 - 0x7fff5cfcaff9 com.apple.RemoteViewServices (2.0 - 148) <590871B7-47F6-3936-AA17-B0AA0DC177D4> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff5cfcb000 - 0x7fff5cfe0ff2 com.apple.xpc.RemoteXPC (1.0 - 1738.61.1) <1B032699-44C4-359D-AF1B-E75957080699> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff5d130000 - 0x7fff5d16bff4 com.apple.RunningBoardServices (1.0 - 223.60.4) <2DF794E5-4008-3D86-9856-F28C49142FE3> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff5df13000 - 0x7fff5df5dff7 com.apple.Safari.SafeBrowsing (15608 - 15608.4.9.1.3) <C712EFB2-841C-3B20-B393-3002FA33DA43> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
0x7fff5eab1000 - 0x7fff5eab4ff9 com.apple.SecCodeWrapper (4.0 - 448.60.2) <4EED91B7-2B87-3EDF-9E92-311F55247B3C> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff5ec27000 - 0x7fff5ed4bff4 com.apple.Sharing (1506.6 - 1506.6) <6E65B170-45C1-354E-8D55-22BF5DFF9C90> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff5fd63000 - 0x7fff6005bffa com.apple.SkyLight (1.600.0 - 450.1) <65653F86-25AD-3283-9F81-DA56A8D01F69> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff608a3000 - 0x7fff608b1fff com.apple.SpeechRecognitionCore (6.0.91 - 6.0.91) <0D6C7167-ECA8-3D6E-BC08-CCE8B4115F8E> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff60f82000 - 0x7fff60fc3ff9 com.apple.StreamingZip (1.0 - 1) <EE12C4F6-D0AB-30E3-975D-4FBC599CB608> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff610d4000 - 0x7fff610ddff7 com.apple.SymptomDiagnosticReporter (1.0 - 1238.60.1) <06787E03-CFFE-3240-B95A-8D2763ED550B> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff61393000 - 0x7fff613a3ff3 com.apple.TCC (1.0 - 1) <5DDF1103-C7EE-3588-A532-F33AC526B288> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff61898000 - 0x7fff6195fff4 com.apple.TextureIO (3.10.9 - 3.10.9) <360BB4A8-E37F-30DB-B798-2DAD29DEA9D3> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff627b6000 - 0x7fff62a10ff2 com.apple.UIFoundation (1.0 - 660) <5BAA592B-3B1B-367F-8A26-3AFFB4C355D0> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff62aa3000 - 0x7fff62aa9ffe com.apple.URLFormatting (119 - 119.15) <6AB7A1A4-B00E-3EAD-99F5-DFFD7BD5E3D0> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
0x7fff63604000 - 0x7fff63624fff com.apple.UserManagement (1.0 - 1) <EDB62A60-2BCA-3022-A07F-83E9E0431C48> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x7fff643d8000 - 0x7fff644c2ffe com.apple.ViewBridge (462 - 462) <AD0573C5-5C5A-3BE3-AD29-FEE92A78B169> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff64668000 - 0x7fff64669fff com.apple.WatchdogClient.framework (1.0 - 67.60.1) <DE42FAF9-24CB-34DA-9AD0-76FE0F3C1C5E> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
0x7fff64832000 - 0x7fff64832fff com.apple.WebInspectorUI (15608 - 15608.4.9.1.3) <9E6379D7-B328-3272-8AD9-155F154A6075> /System/Library/PrivateFrameworks/WebInspectorUI.framework/Versions/A/WebInspectorUI
0x7fff649e2000 - 0x7fff64a1eff3 libAWDSupport.dylib (949) <4327700E-9E74-35F3-8C79-B5A3D6178566> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupport.dylib
0x7fff64a1f000 - 0x7fff64cc4ff2 libAWDSupportFramework.dylib (3316) <3C299E10-89EA-37BF-9B5F-C740B4501E78> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
0x7fff64cc5000 - 0x7fff64cd6ff7 libprotobuf-lite.dylib (3316) <173F37ED-367B-35B8-9541-7BFDC5C94321> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
0x7fff64cd7000 - 0x7fff64d31ff3 libprotobuf.dylib (3316) <3B681C35-A20F-3B92-8C1F-D1FEB5B4F3E2> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
0x7fff64d32000 - 0x7fff64d76ff6 com.apple.awd (1.0 - 949) <D1CB2A40-D0B4-3D64-98DD-655327CC2FA7> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
0x7fff65246000 - 0x7fff65249ffa com.apple.dt.XCTTargetBootstrap (1.0 - 15700) <E7FE2B68-51FA-3863-AB49-BEE9D862DBAB> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff652c2000 - 0x7fff652d0ff5 com.apple.audio.caulk (1.0 - 32.3) <400717FB-3552-3F61-BCBE-53F89F33DDAE> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7fff65611000 - 0x7fff65613ff3 com.apple.loginsupport (1.0 - 1) <1E3EFDAA-97FB-352A-8802-005343FE60F9> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff65614000 - 0x7fff65627ffd com.apple.login (3.0 - 3.0) <40531B9D-B0F1-371F-A5E8-0FC91D7AD175> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fff65864000 - 0x7fff65879ffa libAccessibility.dylib (2771.39) <3A362D64-E600-359D-B9BF-B3385F805236> /usr/lib/libAccessibility.dylib
0x7fff65937000 - 0x7fff6596dffa libAudioToolboxUtility.dylib (1104.30) <5688DDAC-8A24-3061-B431-43AFCA320EF5> /usr/lib/libAudioToolboxUtility.dylib
0x7fff65974000 - 0x7fff659a9ff7 libCRFSuite.dylib (48) <7E22F62C-3EEA-3880-9CCD-0EA93FB953DC> /usr/lib/libCRFSuite.dylib
0x7fff659ac000 - 0x7fff659b6ff3 libChineseTokenizer.dylib (34) <3023F415-2B77-38DA-ABDD-16BFD18CED69> /usr/lib/libChineseTokenizer.dylib
0x7fff65a43000 - 0x7fff65a45ff7 libDiagnosticMessagesClient.dylib (112) <D84AA565-8B5C-39EB-AB5E-61DC38B8493C> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff65a8a000 - 0x7fff65c41ff3 libFosl_dynamic.dylib (100.4) <84A5F946-01EE-3740-BD2F-4C2A6B1FE82B> /usr/lib/libFosl_dynamic.dylib
0x7fff65c68000 - 0x7fff65c6eff3 libIOReport.dylib (54) <B68B8787-1D0A-3E06-8E6A-0E59771F796C> /usr/lib/libIOReport.dylib
0x7fff65d4e000 - 0x7fff65d55fff libMatch.1.dylib (36) <F161E5B5-59CB-3C46-BA6D-0E5DE36DF7FC> /usr/lib/libMatch.1.dylib
0x7fff65d85000 - 0x7fff65da4fff libMobileGestalt.dylib (826.60.1) <7FA72434-FD46-300D-A6BD-D47A4FEF03C5> /usr/lib/libMobileGestalt.dylib
0x7fff65f0b000 - 0x7fff65f0cff3 libSystem.B.dylib (1281) <2F6BCFD9-A5F9-30FE-BF5A-5C53D3CBAB4D> /usr/lib/libSystem.B.dylib
0x7fff65f0d000 - 0x7fff65f9aff7 libTelephonyUtilDynamic.dylib (3852) <1EB18EA2-EF1E-355A-9F6F-B2D9E662FE09> /usr/lib/libTelephonyUtilDynamic.dylib
0x7fff65f9b000 - 0x7fff65f9cfff libThaiTokenizer.dylib (3) <DDCB09BD-CBDF-3628-B44F-C5328037A929> /usr/lib/libThaiTokenizer.dylib
0x7fff65fb4000 - 0x7fff65fcafff libapple_nghttp2.dylib (1.39.2) <0685C38F-7A9F-34CB-B3FF-92601483A0FF> /usr/lib/libapple_nghttp2.dylib
0x7fff65fff000 - 0x7fff66071ff7 libarchive.2.dylib (72.40.2) <88E010D7-060F-333E-B5B4-0249154B9868> /usr/lib/libarchive.2.dylib
0x7fff66072000 - 0x7fff66108fc5 libate.dylib (2.0.9) <63A28B5E-0AAA-3893-91DD-1A64A03FE8A2> /usr/lib/libate.dylib
0x7fff6610c000 - 0x7fff6610cff3 libauto.dylib (187) <724B1E92-64DC-30CD-A90B-DA90B5794A94> /usr/lib/libauto.dylib
0x7fff661d3000 - 0x7fff661e3ff3 libbsm.0.dylib (60) <2E6E444F-7BF3-32E0-AF3A-DE9BF9D9DAAB> /usr/lib/libbsm.0.dylib
0x7fff661e4000 - 0x7fff661f0fff libbz2.1.0.dylib (44) <8FCE28A3-D250-37F5-93B6-866E8494DCAA> /usr/lib/libbz2.1.0.dylib
0x7fff661f1000 - 0x7fff66244ff7 libc++.1.dylib (800.7) <6018A70E-5CD3-32AF-BA60-E7A0B7E7CEB2> /usr/lib/libc++.1.dylib
0x7fff66245000 - 0x7fff66259fff libc++abi.dylib (800.7) <BC1E5821-4540-3226-ABB0-BC35E4DDF0B9> /usr/lib/libc++abi.dylib
0x7fff6625a000 - 0x7fff6625affb libcharset.1.dylib (59) <1B71DC8A-FBF2-37F8-92C0-34AE72B7CED3> /usr/lib/libcharset.1.dylib
0x7fff6625b000 - 0x7fff6626cffb libcmph.dylib (8) <55F5F96B-F93C-3A1A-80F7-61B9ED2C2F6C> /usr/lib/libcmph.dylib
0x7fff6626d000 - 0x7fff66284fe7 libcompression.dylib (87) <35A0C0B0-6545-3E18-AEA7-F8C70E0FB095> /usr/lib/libcompression.dylib
0x7fff66554000 - 0x7fff6656aff7 libcoretls.dylib (167) <EFA4D470-4840-3D55-A287-32E82EC0EC58> /usr/lib/libcoretls.dylib
0x7fff6656b000 - 0x7fff6656cfff libcoretls_cfhelpers.dylib (167) <F0EAEB10-7C1F-3CB1-B04E-D7B96665C749> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff66b2a000 - 0x7fff66b89fff libcups.2.dylib (483.2) <2C8BF301-578F-3148-9A52-C1CA90402D9B> /usr/lib/libcups.2.dylib
0x7fff66c95000 - 0x7fff66c95fff libenergytrace.dylib (21) <38819A80-4A1A-32D7-99D3-B675808F30CF> /usr/lib/libenergytrace.dylib
0x7fff66c96000 - 0x7fff66cafff7 libexpat.1.dylib (19.60.2) <81E75AD6-C332-3DC6-804F-A71FC64EC6A1> /usr/lib/libexpat.1.dylib
0x7fff66cbd000 - 0x7fff66cbffff libfakelink.dylib (149) <AAA5BBB4-F6FA-3B36-9245-B6999A95C63C> /usr/lib/libfakelink.dylib
0x7fff66cce000 - 0x7fff66cd3fff libgermantok.dylib (24) <6D3925E0-8A6F-3BE1-8729-ABEDE2264AF1> /usr/lib/libgermantok.dylib
0x7fff66cd4000 - 0x7fff66cddff7 libheimdal-asn1.dylib (564.60.2) <69184137-9EFE-366C-BE2D-7027A1677F76> /usr/lib/libheimdal-asn1.dylib
0x7fff66cde000 - 0x7fff66dceff7 libiconv.2.dylib (59) <54B90704-F9C8-31B4-AE04-FE496B3725A3> /usr/lib/libiconv.2.dylib
0x7fff66dcf000 - 0x7fff67027ff7 libicucore.A.dylib (64252.0.1) <AD2FDFC2-F9D9-3D64-950A-6CF6FC114B95> /usr/lib/libicucore.A.dylib
0x7fff67041000 - 0x7fff67042fff liblangid.dylib (133) <7E36BF2A-6E88-3A32-8412-4FD5D850D44A> /usr/lib/liblangid.dylib
0x7fff67043000 - 0x7fff6705bff3 liblzma.5.dylib (16) <A4980A1E-CA23-31F2-8CAD-3BA62F802FE7> /usr/lib/liblzma.5.dylib
0x7fff67073000 - 0x7fff6711afff libmecab.dylib (883.1.1) <790EBEF5-E677-363E-848F-C5E378F35C98> /usr/lib/libmecab.dylib
0x7fff6711b000 - 0x7fff6737dfe1 libmecabra.dylib (883.1.1) <B59546A4-D7B2-365E-ADB3-13BC524E3407> /usr/lib/libmecabra.dylib
0x7fff676e9000 - 0x7fff67718ff7 libncurses.5.4.dylib (57) <D781E97A-8970-329C-ADB8-F3CEA0343F8E> /usr/lib/libncurses.5.4.dylib
0x7fff67847000 - 0x7fff67cbdff7 libnetwork.dylib (1880.60.5) <0B1AF784-11A0-31EE-AC24-2E0BAB975CC7> /usr/lib/libnetwork.dylib
0x7fff67d5c000 - 0x7fff67d8dfc6 libobjc.A.dylib (781.2) <17241F77-6A7A-39D7-8836-63E2725AA3C9> /usr/lib/libobjc.A.dylib
0x7fff67da0000 - 0x7fff67da4fff libpam.2.dylib (25) <C6BFA445-E6A2-3A18-89F3-2E1D85405E69> /usr/lib/libpam.2.dylib
0x7fff67da7000 - 0x7fff67dddff7 libpcap.A.dylib (89.60.2) <882835C6-7DA0-3465-A646-EBA215EF9DAD> /usr/lib/libpcap.A.dylib
0x7fff67e5f000 - 0x7fff67e77ff7 libresolv.9.dylib (67.40.1) <2DEF6C56-0CF8-3469-B21C-D8994D048807> /usr/lib/libresolv.9.dylib
0x7fff67e79000 - 0x7fff67ebdfff libsandbox.1.dylib (1217.61.1) <5D1AC9FE-A068-3883-AEB6-5F0D2F8B93A5> /usr/lib/libsandbox.1.dylib
0x7fff67ed1000 - 0x7fff67ed2ff7 libspindump.dylib (281.2) <8541CC86-40AB-3118-BD79-6B15F5871188> /usr/lib/libspindump.dylib
0x7fff67ed3000 - 0x7fff680c0ff7 libsqlite3.dylib (308.4) <5FAC89DA-EC45-3F38-8D00-FE638D6FD4D5> /usr/lib/libsqlite3.dylib
0x7fff68312000 - 0x7fff68315ffb libutil.dylib (57) <86C9C769-0523-38C6-940E-900C8CAB780A> /usr/lib/libutil.dylib
0x7fff68316000 - 0x7fff68323fff libxar.1.dylib (420) <03679705-EDE0-361D-B0B2-1A69170A6FF1> /usr/lib/libxar.1.dylib
0x7fff68329000 - 0x7fff6840bff7 libxml2.2.dylib (32.13) <DDA76502-B9D9-3459-97DB-C8B85D9310A9> /usr/lib/libxml2.2.dylib
0x7fff6840f000 - 0x7fff68437fff libxslt.1.dylib (16.7) <0BBEC00F-116C-3AF8-B751-970482388AED> /usr/lib/libxslt.1.dylib
0x7fff68438000 - 0x7fff6844affb libz.1.dylib (76) <1005ADEB-04A2-3E42-B915-AB4B40A7AB3A> /usr/lib/libz.1.dylib
0x7fff68eae000 - 0x7fff68eb3ff3 libcache.dylib (83) <AD7479C0-73FA-3B2E-9544-D566DFFAB4C6> /usr/lib/system/libcache.dylib
0x7fff68eb4000 - 0x7fff68ebffff libcommonCrypto.dylib (60165) <F7B65873-FAC8-3EB5-8912-34109EFC74B5> /usr/lib/system/libcommonCrypto.dylib
0x7fff68ec0000 - 0x7fff68ec7fff libcompiler_rt.dylib (101.2) <51107CAA-0727-370D-8287-940D40D09AC1> /usr/lib/system/libcompiler_rt.dylib
0x7fff68ec8000 - 0x7fff68ed1fff libcopyfile.dylib (166.40.1) <6454A046-88E5-32D6-898C-FB0D30D28637> /usr/lib/system/libcopyfile.dylib
0x7fff68ed2000 - 0x7fff68f69fe7 libcorecrypto.dylib (866.60.3) <8090C446-35C8-31B4-8B1E-AF6D0EF3524B> /usr/lib/system/libcorecrypto.dylib
0x7fff69080000 - 0x7fff690c1ff0 libdispatch.dylib (1173.60.1) <A9EDFE95-31BA-3BEF-89CA-60DE153237FA> /usr/lib/system/libdispatch.dylib
0x7fff690c2000 - 0x7fff690f7ff7 libdyld.dylib (733.8) <8E2D3DED-0756-37A0-9D55-B9264CA020B4> /usr/lib/system/libdyld.dylib
0x7fff690f8000 - 0x7fff690f8ffb libkeymgr.dylib (30) <0B9A3AF7-086E-3E7A-A52E-3DAF2E52CF86> /usr/lib/system/libkeymgr.dylib
0x7fff690f9000 - 0x7fff69105ff7 libkxld.dylib (6153.61.1) <E4A12D21-999B-34CE-ACEC-7C7972B3BAED> /usr/lib/system/libkxld.dylib
0x7fff69106000 - 0x7fff69106ff7 liblaunch.dylib (1738.61.1) <A061D971-A337-3528-8B78-FFAD2B0B5CC6> /usr/lib/system/liblaunch.dylib
0x7fff69107000 - 0x7fff6910cff7 libmacho.dylib (949.0.1) <9831715F-ED86-3A9D-88CD-152C888B784B> /usr/lib/system/libmacho.dylib
0x7fff6910d000 - 0x7fff6910fff7 libquarantine.dylib (110.40.3) <58CE8913-EC7B-376B-BC80-69763993A1E4> /usr/lib/system/libquarantine.dylib
0x7fff69110000 - 0x7fff69111ff7 libremovefile.dylib (48) <4E1AD797-3993-3E05-BB9B-B4E3038CE09C> /usr/lib/system/libremovefile.dylib
0x7fff69112000 - 0x7fff69129fff libsystem_asl.dylib (377.60.2) <2CD6CABE-F8D7-3CCA-A930-08F8AC356D30> /usr/lib/system/libsystem_asl.dylib
0x7fff6912a000 - 0x7fff6912afff libsystem_blocks.dylib (74) <71A75F21-83AD-382F-95E4-4D6B77B4B9FE> /usr/lib/system/libsystem_blocks.dylib
0x7fff6912b000 - 0x7fff691b2ff7 libsystem_c.dylib (1353.60.8) <ECA8CD0D-0B55-3151-B389-8109DAEC85B1> /usr/lib/system/libsystem_c.dylib
0x7fff691b3000 - 0x7fff691b6ffb libsystem_configuration.dylib (1061.40.2) <CE186284-4923-35DE-9141-7B6B89523668> /usr/lib/system/libsystem_configuration.dylib
0x7fff691b7000 - 0x7fff691baff7 libsystem_coreservices.dylib (114) <FBE4483A-7B6E-30CF-AECE-828AFFACDC15> /usr/lib/system/libsystem_coreservices.dylib
0x7fff691bb000 - 0x7fff691c3fff libsystem_darwin.dylib (1353.60.8) <9AC37996-630C-3B1E-8285-CFC77B684359> /usr/lib/system/libsystem_darwin.dylib
0x7fff691c4000 - 0x7fff691cbffb libsystem_dnssd.dylib (1096.60.2) <7F0DF910-F4AC-3CED-9494-295B5E45549C> /usr/lib/system/libsystem_dnssd.dylib
0x7fff691cc000 - 0x7fff691cdffb libsystem_featureflags.dylib (17) <985005B7-C0B3-3DCA-B064-6D34A0687212> /usr/lib/system/libsystem_featureflags.dylib
0x7fff691ce000 - 0x7fff6921bfff libsystem_info.dylib (538) <D9805FBC-1BBD-3825-AB62-83C3ABB4191F> /usr/lib/system/libsystem_info.dylib
0x7fff6921c000 - 0x7fff69248ff7 libsystem_kernel.dylib (6153.61.1) <90F8650F-D3A9-38B3-BB8C-B5D3686393BC> /usr/lib/system/libsystem_kernel.dylib
0x7fff69249000 - 0x7fff69290fcf libsystem_m.dylib (3178) <92F1FF45-BD1C-32FE-A9A9-D12AF02C8212> /usr/lib/system/libsystem_m.dylib
0x7fff69291000 - 0x7fff692b8fff libsystem_malloc.dylib (283.60.1) <51472F42-71BE-348F-B42E-4EDD3040B690> /usr/lib/system/libsystem_malloc.dylib
0x7fff692b9000 - 0x7fff692c6ffb libsystem_networkextension.dylib (1095.60.2) <846C06C0-A705-38AE-8A29-3FA4153252B3> /usr/lib/system/libsystem_networkextension.dylib
0x7fff692c7000 - 0x7fff692d0ff3 libsystem_notify.dylib (241) <7CB7DE46-5877-3CAD-8526-CACEA22F3AD5> /usr/lib/system/libsystem_notify.dylib
0x7fff692d1000 - 0x7fff692dafef libsystem_platform.dylib (220) <AC9560A9-CCE8-3158-BCC8-8FF47929397A> /usr/lib/system/libsystem_platform.dylib
0x7fff692db000 - 0x7fff692e5fff libsystem_pthread.dylib (416.60.2) <9D14694F-F3FE-385D-9B23-6A87844D5CBF> /usr/lib/system/libsystem_pthread.dylib
0x7fff692e6000 - 0x7fff692eafff libsystem_sandbox.dylib (1217.61.1) <AA2E4441-A517-3921-AF0E-AA8158D2A6D9> /usr/lib/system/libsystem_sandbox.dylib
0x7fff692eb000 - 0x7fff692edfff libsystem_secinit.dylib (62.60.1) <129C187A-E580-3F00-A0C3-E96A633364F1> /usr/lib/system/libsystem_secinit.dylib
0x7fff692ee000 - 0x7fff692f5ffb libsystem_symptoms.dylib (1238.60.1) <5540DEA3-9C3A-3991-8C3A-7B375A5410C7> /usr/lib/system/libsystem_symptoms.dylib
0x7fff692f6000 - 0x7fff6930cff2 libsystem_trace.dylib (1147.60.3) <EF6BD746-85CD-3490-92E6-7C7EDA0B703B> /usr/lib/system/libsystem_trace.dylib
0x7fff6930e000 - 0x7fff69313ffb libunwind.dylib (35.4) <769F4C16-2746-3182-85C1-45CC98D119C8> /usr/lib/system/libunwind.dylib
0x7fff69314000 - 0x7fff69348ffe libxpc.dylib (1738.61.1) <AC9AD00D-BAA9-3ABC-B557-77E604CF9955> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 1
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 1773
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=727.3M resident=0K(0%) swapped_out_or_unallocated=727.3M(100%)
Writable regions: Total=1.5G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.5G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 384K 3
Activity Tracing 256K 1
CG backing stores 2920K 4
CG image 688K 6
CoreAnimation 220K 9
CoreGraphics 8K 1
CoreImage 24K 2
CoreUI image data 2292K 19
Foundation 4K 1
Kernel Alloc Once 8K 1
MALLOC 404.3M 71
MALLOC guard page 48K 10
MALLOC_MEDIUM (reserved) 744.0M 7 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
Memory Tag 242 12K 1
STACK GUARD 56.0M 13
Stack 14.1M 13
VM_ALLOCATE 360K 16
__DATA 61.7M 397
__DATA_CONST 41K 3
__FONT_DATA 4K 1
__LINKEDIT 405.9M 73
__OBJC_RO 32.0M 1
__OBJC_RW 1780K 2
__TEXT 321.5M 377
__UNICODE 564K 1
mapped file 67.5M 31
shared memory 644K 16
TOTAL 2.4G 1081
TOTAL, minus reserved VM space 1.3G 1081
Model: MacBookPro15,1, BootROM 1037.60.58.0.0 (iBridge: 17.16.12551.0.0,0), 6 processors, 6-Core Intel Core i7, 2.6 GHz, 32 GB, SMC
Graphics: kHW_IntelUHDGraphics630Item, Intel UHD Graphics 630, spdisplays_builtin
Graphics: kHW_AMDRadeonPro555XItem, Radeon Pro 555X, spdisplays_pcie_device, 4 GB
Memory Module: BANK 0/ChannelA-DIMM0, 16 GB, DDR4, 2400 MHz, Micron, 16ATS2G64HZ-2G6B1
Memory Module: BANK 2/ChannelB-DIMM0, 16 GB, DDR4, 2400 MHz, Micron, 16ATS2G64HZ-2G6B1
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Oct 26 2019 10:18:37 version 9.112.2.0.32.5.40 FWID 01-66dd2dcb
Bluetooth: Version 7.0.2f4, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
PCI Card: pci1b73,1100, sppci_usbxhci, Thunderbolt@196,0,0
USB Device: USB 3.1 Bus
USB Device: USB 3.0 Bus
USB Device: USB3.1 Hub
USB Device: USB3.0 Hub
USB Device: Hub
USB Device: LG UltraFine Display Camera
USB Device: USB2.1 Hub
USB Device: USB2.0 Hub
USB Device: USB 2.0 Hub
USB Device: J-Link
USB Device: Hub
USB Device: USB Controls
USB Device: USB Audio
USB Device: Apple T2 Bus
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 47.3
Thunderbolt Device: UltraFine 5K, LG Electronics, 1, 9.4
    I was able to replicate the crash with Wireshark v3.2.0, but not after I downgraded to v3.0.7. So it would be nice if you can try to downgrade on your side as well.  Still, the interface did not show unless I opened Wireshark from the terminal, as you explained. So that appears to be a separate issue. I have reported both issues internally.
    Vidar
  • I tried to downgrade it to v3.0.7. It behaves exactly the same like you described. FYI.
  • Thanks for confirming. One of the developers here also confirmed that it is indeed a bug introduced in Wireshark v3.2.0 that will be fixed in the upcoming 3.2.1 release. So the recommendation is to use 3.0.7 for now.
    With regards to the issue with the interface not displaying: it appears to have been caused by the fact that I had 2 installations of Python3 on my system - one was installed to /usr/bin/ while the other was installed to  /usr/local/bin (installed through brew), but the pyserial dependency was only installed to the latter ( I think). Running "/usr/bin/python3 -m pip install --user pyserial" fixed it for me. Please let me know if you are encountering a different issue. We need to update the installation guide for MacOS.
