I am using nRF52840, SDK_16.0.0, S140 SoftDevice and Segger 4.16 for flashing the image.
I am new to DTM. I have related queries.
1) In nAN34 note, what does “Untested” and “Tested” mean as part of DTM test setup ? Whether it says Untested device and after performing tests (DUT), then the device is marked as Tested.
- (Or) Will there be any Golden sample in DTM test setup. If Yes, how to get Golden sample for first time.
2) For UART LE_Test_Setup command there is no corresponding HCI command. Then in that case how to set PHY layer.
3) For UART LE_Transmitter_Test there is a Packet Type 11 for Vendor specific. But the same I am not able to find in HCI HCI_LE_Transmitter_Test packet. Whether we cannot do Vendor specific in HCI test packets.
4) As per Bluetooth SIG, LE_Test_Setup command is sent to configure PHY layer. But in below link I am not seeing LE_Test_Setup command under “State machine overview of the DTM”.
- If LE_Reset is same as LE_Test_Setup then why it is sent last after LE_Test_End. Should not LE_Reset be first command before sending any LE_Receiver_Test or LE_Transmitter_Test so that PHY is configured to required and then do required test.
Thanks & Regards
Vishnu Beema
