Reduce time between SPI transfers
Dear all,
I am using a DK with the NRF52832 to drive a 32-bit DAC through SPI @ 8 MHz. I use a solution based on the peripheral/spi example using the SDK15.
My goal is to change the DAC value every (say) 5 us. This is theoretically possible since 32-bit/ 8 MHz = 4 us. The application also uses the SoftDevice, as well as Timer2 (for pulse diuration purposes)
Using the "nrf_drv_spi_transfer()" function in an infinite loop, it yields a delay between transfers of around 60 us. That is, I measure the 32 clock pulses of an SPI transfer in a row, but until the next call of "nrf_drv_spi_transfer()" there is a delay of 60 us.
1) I would firstly like to ask for reference of the origin of this delay. I know it has to do with the SoftDevice mainly, and of course the rest of the executing code, but I could not find a reference guide about it.
2) I would need to minimize the inter-transfer delay to ideally 0. Any strategies on how to do this, and which would be roughly the theoretical minimum of this delay? Is any continuous-transfer (zero inter-delay) implementation possible?
Thank you for your kindness,
Fran89
    I think we will need some more details in order to answer your questions. How have you configured the SPI driver? (non-blocking/blocking mode, SS signal being used, etc).
    Do you need to update the data that is being transferred every time you call the nrf_drv_spi_transfer? If this is static, you can use the "advanced usage" features of the driver to setup a transfer and start it through PPI directly from a TIMER. This will minimize the time between transfers.
    If you need to change the content of the buffer, and are running BLE activity simultaneously, there is no way to guarantee the completion of the transfer in this short time, since the softdevice will always have the highest priority and will preempt the SPI transfer.
    Jørgen
  • Thank you very much for the prompt answer. I will test it out as soon as possible and let you know the results.
    For now I add a picture for future reference and clarification of what my problem is:
    The code is the one for the SPI example, with the delays removed. This doesn't use SoftDevice or any other interrupts, and yet there is a delay of around 30 us. The idea would be to minimize this delay.
    #define SPI_INSTANCE  0 /**< SPI instance index. */
    static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
    static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
    #define TEST_STRING "Nordic"
    static uint8_t       m_tx_buf[] = TEST_STRING;           /**< TX buffer. */
    static uint8_t       m_rx_buf[sizeof(TEST_STRING) + 1];    /**< RX buffer. */
    static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
     * @brief SPI user event handler.
     * @param event
    void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                           void *                    p_context)
        spi_xfer_done = true;
        NRF_LOG_INFO("Transfer completed.");
        if (m_rx_buf[0] != 0)
            NRF_LOG_INFO(" Received:");
            NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
        //bsp_board_init(BSP_INIT_LEDS);
        //APP_ERROR_CHECK(NRF_LOG_INIT(NULL));
        //NRF_LOG_DEFAULT_BACKENDS_INIT();
        nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
        spi_config.ss_pin   = SPI_SS_PIN;
        spi_config.miso_pin = SPI_MISO_PIN;
        spi_config.mosi_pin = SPI_MOSI_PIN;
        spi_config.sck_pin  = SPI_SCK_PIN;
        APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
        NRF_LOG_INFO("SPI example started.");
        while (1)
            // Reset rx buffer and transfer done flag
            memset(m_rx_buf, 0, m_length);
            spi_xfer_done = false;
            APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
            while (!spi_xfer_done)
                __WFE();
            //NRF_LOG_FLUSH();
            //bsp_board_led_invert(BSP_BOARD_LED_0);
            //nrf_delay_ms(200);
    Thanks again, and I will report back asap.
    Fran89
    I did a quick test with the SPI driver in advanced mode. I setup a repeated transfer and connected the SPI END event to the START task, which means that the next transfer will start as soon as the previous is completed. As you can see from the image, I get a delay of 1.372 us between each 4 byte transfer. This is the lowest delay you can get, as everything happens in HW.
    I have also attached the main.c for your reference:
     * Copyright (c) 2015 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    #include "nrf_drv_spi.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "boards.h"
    #include "app_error.h"
    #include <string.h>
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_drv_ppi.h"
    #define TEST_STRING "Nord"
    static uint8_t       m_tx_buf[4] = TEST_STRING;           /**< TX buffer. */
    static uint8_t       m_rx_buf[4];    /**< RX buffer. */
    static const uint8_t m_length = 4;        /**< Transfer length. */
    static nrf_ppi_channel_t     m_ppi_channel;
     * @param event
                           void *                    p_context)
        nrf_drv_spi_xfer_desc_t xfer = NRF_DRV_SPI_XFER_TRX(m_tx_buf, m_length, m_rx_buf, m_length);
        ret_code_t ret = nrf_drv_spi_xfer(&spi, &xfer, NRF_DRV_SPI_FLAG_HOLD_XFER | NRF_DRV_SPI_FLAG_REPEATED_XFER | NRF_DRV_SPI_FLAG_NO_XFER_EVT_HANDLER);
        // SPIM is now configured and ready to be started.
        if (ret == NRF_SUCCESS)
            uint32_t start_tsk_addr = nrf_drv_spi_start_task_get(&spi);
            // Set up PPI to trigger the transfer.
            uint32_t end_evt_addr = nrf_drv_spi_end_event_get(&spi);
            // Set up PPI to count the number of transfers.
            ret_code_t err_code = nrf_drv_ppi_channel_alloc(&m_ppi_channel);
                                                  end_evt_addr,
                                                  start_tsk_addr);
            err_code = nrf_drv_ppi_channel_enable(m_ppi_channel);
        NRF_SPIM0->TASKS_START = 1;
        while (1)
            NRF_LOG_FLUSH();
    Jørgen
  • Hi again.
    This looks exactly like what I am looking for.  Also it is awesome to have the absolute minimum latency value, thanks.
    I do need to change the content of the buffer in every transfer of course. I will try to implement this solution throught the week and get back with a question or mark the problem as solved.
    Thank you very much in advance.
  • For the time being I decided to use the standard spi transfer api.
    I tried linking PPI channels to the timer and the spi, but I could not successfully manage to do so. However, I believe that is the way to go when I become more time-constrained.
    I will open a new topic when I have doubts about that, and I think my question has been answered here.
    Best regards
