Strange behavior during position acquisition
We are testing  GPS capabilities for our hardware, using mfw 1.1.0 in the field. We have the following test conditions
  • The unit is ackquiring position every 5 min
  • the unit is outdoors, in an open field in a rural area
  • the operating temperature is around 0 (measured by a temp sensor on the pcb)
  • The unit had a battery change
We see the following:
  • After battery change, the unit did not send position on 73 tries,
  • After a restart, the unit started to send positions with almost 0 ackquisition time, and it sent 15 positions with hot fix
  • It then seemed to loose the hot-fix capability, and after that, the hot fix capability seems to go on and off with an interval of around 15-20 acquisitions.
  • This periodic behavior seems to be present also prior to the battery change, but the data is not analyzed that thoroughly.
Yours,
Tron
