Aim: Smart Home Trainer developpment ( Zwift connexion)
Hardware: Bluefruit The feater (nRF52832)
Library : Nordic sdk + Bluefruit
Problem: Difficulties with the implementation of the Fitness Machine Control Point (0x2AD9)
I have many questions about the understanding of control points in GATT specification
Q1: Properties of the control point : Read is excluded. How can the client read the control point after a write of the server?
When a write is detected by the server (callbak), the server receive the goog Opcode to initialise the transaction.
In my software, the server answer with a write ((0X01= SUCCESS) into the control point characteristic.
But it doesn't work.
How should the server write the response to a write request to Fitness Machine control point?
(sequence diagram of specification FTMS p74/78)
Q2: Explanations about the Procedure executed by the server (FTMS specification §4.16.2.22 p 64/78)
" The server must answer with the Response Code (0xx80)" :
How can the server send the Response Code? Which command? Which characteristic? Which API ?
" The Request op Code field shall be set to the correct value":
I understand that the server write the opcode in the control point. Is it correct?
Which command should it use to update the control point with the opcode : write, notify, indicate???
Thank you
Vincent
