Document regarding DFUMaster_UART to do a serial firmware upgrade.
To do a serial DFU I have followed the steps provided in the DFUMaster_UART link.
1) Generated the key using the NrfUtil.
2) Added the private.key and generated a DFU package using the NrfUtil tool.
3) Added the public.key to the secure_bootloader_uart example and build it.
4) Flashed the Softdevice and the above-builded bootloader to one nrf52840 DK.
5) Extracted the DFU package generated in step 2, got three files:
    - app_xyz .bat
    - app_xyz .bin
    - manifest.json
6) Tried building in the DFUMaster_UART with the SDK v15.2 as it was giving some errors, tried building it with the SDKv14.2 it was successful.
7) Flashed DFUMaster_UART in one nrf52832 DK as the example available was for the PCA10040.
8) Flashed the extracted app_xyz.bat to 0x9000 location as in the DFUMaster code it was reading this location for the init packet.
9) Flashed the extracted app_xyz.bin to 0x30000 location as in the DFUMaster code it was reading this location for the image to be sent to DFU_Target(nrf52840).
10) Now Bootloader code was successfully able to parse the init package and validated it. But, as the DFUMaster Starts sending the FW Image the bootloader code resets after receiving the two packets and writing in to flash.
Debugged that by putting the breakpoint, got to know that as the bootloader tries to write the third packet in the flash it stuck in the wait_for_flash_ready().
Please correct me if any of the above steps are incorrect, so that I can successfully complete the DFU.
  • I have attached the LOG files as below:
    1) DFUMaster LOG.
    2) DFU Target LOGS :
         a) pca10056_uart_LOG: This project is from (nRF5_SDK_15.2.0_9412b96\examples\dfu\secure_bootloader\pca10056_uart\ses) location.
         b) pca10056_uart_debug_LOG: This project is from (nRF5_SDK_15.2.0_9412b96\examples\dfu\secure_bootloader
        \pca10056_uart_debug) location.
    SENDING PING PACKATE of LENGTH = 3
    <info> app: Init data size: 141
    <info> app: Data : 12 8A 62
    <info> app: Data : 79 536936376 62
    <info> app: Data : 17 536936376 62
    <info> app: Data : 0 536936376 62
    <info> app: Image size: 25012
    <info> app: Data : 4034 536936376 62
    <info> app: Data : 3972 536936376 62
    Inside main
    ACTIVATION NONE = 1
    Initializing transports (found: 1)
    Enter main loop
    Handle NRF_DFU_OP_OBJECT_WRITE (command)
    nrf_dfu_validation_init_cmd_append ---->ret_val = 1
    Size of Binary = 25012
    Address where to flash binary = 200014fc
    m_firmware_start_addr = 00026000
    Writing settings...
    Flash erase success
    Dr
     nrf_fstorage_write called with dst = 1040384 psrc = 536877144 len = 348------
    Flash write success
    nrf_fstorage_write() failed with error 0
    Writing valid init command to flash.
    Flash erase success
    Handle NRF_DFU_OP_OBJECT_WRITE (data)
     WRITE_ADDR = 155648
     nrf_fstorage_write called with dst = 155648 psrc = 536876444 len = 62------
    Flash write success
     WRITE_ADDR = 155710
     nrf_fstorage_write called with dst = 155710 psrc = 536876312 len = 62------
    Inside main
    Writing settings...
    Flash erase success
    In settings_write dst = 000ff000
    -----nrf_fstorage_write called------
    Flash write success
    ACTIVATION NONE = 1
    Enter main loop
    <info> app: Inside main
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <warning> nrf_dfu_settings: Resetting bootloader settings since neither the settings page nor the backup are valid (CRC error).
    <debug> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <debug> app: Enter nrf_dfu_app_is_valid
    <debug> app: No valid app to boot.
    <debug> app: DFU mode because app is not valid.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: in weak nrf_dfu_init_user
    <debug> app: timer_stop (0x20000024)
    <debug> app: timer_activate (0x20000024)
    <info> app: Entering DFU mode.
    <debug> app: Initializing transports (found: 1)
    <debug> nrf_dfu_serial_uart: serial_dfu_transport_init()
    <debug> nrf_dfu_serial_uart: serial_dfu_transport_init() completed
    <debug> app: Shutting down transports (found: 1)
    <debug> nrf_dfu_serial: Received ping 1
    <info> nrf_dfu_serial_uart: Allocated buffer 2000378C
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_PING
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_serial: Sending Response: [0x9, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
    <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
    <info> nrf_dfu_serial_uart: Allocated buffer 20003810
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
    <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    Address where to flash binary = 20003774
    Writing settings...
    Flash erase success
    Flash write success
    Writing settings...
    Flash erase success
    In settings_write dst = 000fe000
    Flash write success
    Flash erase success
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    <debug> nrf_dfu_validation: PB: Init packet data len: 64
    <info> nrf_dfu_validation: Signature required. Checking signature.
    <info> nrf_dfu_validation: Calculating init packet hash (init packet len: 64)
    <info> nrf_dfu_validation: Verify signature
    <info> nrf_dfu_validation: Image verified
    <debug> app: Enter nrf_dfu_cache_prepare()
    <debug> app: required_size: 0x61B4.
    <debug> app: single_bank: false.
    <debug> app: keep_app: false.
    <debug> app: keep_softdevice: true.
    <debug> app: SD_PRESENT: true.
    <debug> app: Bank contents:
    <debug> app: Bank 0 code: 0x00: Size: 0x0
    <debug> app: Bank 1 code: 0x00: Size: 0x0
    <debug> app: pass: 0.
    <debug> app: cache_address: 0x26000.
    <debug> app: cache_too_small: false.
    <debug> app: keep_firmware: false.
    <debug> app: delete_more: false.
    <debug> nrf_dfu_validation: Write address set to 0x00026000
    <info> nrf_dfu_settings: Backing up settings page to address 0xFE000.
    <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00000000, CRC: 0x00000000
     WRITE_ADDR = 155648 s_dfu_settings.write_offset = 0
    ----> 142 - E:\projects\ADI_MUSKA\nRF5_SDK_15.2.0_9412b96\components\libraries\fstorage\nrf_fstorage.c
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <error> app: Received a fault! id: 0x00004002, pc: 0x00000000, info: 0x2003FF50
  • DFU-Master is running on Nrf52832.
    The bootloader is running on Nrf52840.
    Softdevice on Nrf52840 is s140_nrf52_6.1.0_softdevice.hex
    Flowcontrol is disabled.
    Please reply, it's a bit urgent.
    I just want to confirm something. The bootloader is the same in both cases, when it works and not? Is the bootloader always from SDK15.2.0\examples\dfu\secure_bootloader\pca10056_uart[_debug]?
    It looks like it is the (_WEAK) assert_nrf_callback() from nrf_assert.c that has triggered, as that is the only function in the bootloader that calls app_error_fault_handler()¨.
    Can you please try to set a breakpoint in this function, and see what line_num and file_name the assertion was triggered from? That would be a breakpoint on line 51 in nrf_assert.c, and add assert_info to watch to monitor the two variables.
    Edvin
  • Hi Edvin,
    Thanks for the reply.
    In both the case it is not working in both the cases:
    Currently, let us look into the pca10056_uart_debug secure bootloader example.
    It is failing with the below param checking in nrf_fstorage_write:
    /* Length must be a multiple of the program unit. */
    NRF_FSTORAGE_PARAM_CHECK(!(len % p_fs->p_flash_info->program_unit), NRF_ERROR_INVALID_LENGTH);
    So I changed the Length Param in DFUMaster Code as the DFUMaster was not sending the length in multiple of programming unit. Now that issue is resolved.
    But the new issue is that the DFUMaster is not waiting for the response after sending each packet and the bootloader fails to receive all the packets leading to the DFU Failure.
    So I put the DFUMaster in debug mode and sent the packet one by one with the breakpoint. Now the DFU is Completed successfully. I have attached the logs of successful completion.
    But can you provide me a proper DFUMaster_UART Code, so that I can use it without modifications and complete the DFU successfully?
     WRITE_ADDR = 178228 s_dfu_settings.write_offset = 22580
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2B834, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 178288 s_dfu_settings.write_offset = 22640
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2B870, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 178348 s_dfu_settings.write_offset = 22700
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2B8AC, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 178408 s_dfu_settings.write_offset = 22760
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2B8E8, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 178468 s_dfu_settings.write_offset = 22820
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2B924, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 178528 s_dfu_settings.write_offset = 22880
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2B960, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 178588 s_dfu_settings.write_offset = 22940
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2B99C, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 178648 s_dfu_settings.write_offset = 23000
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2B9D8, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 178708 s_dfu_settings.write_offset = 23060
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BA14, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 178768 s_dfu_settings.write_offset = 23120
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BA50, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 178828 s_dfu_settings.write_offset = 23180
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BA8C, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 178888 s_dfu_settings.write_offset = 23240
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BAC8, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 178948 s_dfu_settings.write_offset = 23300
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BB04, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179008 s_dfu_settings.write_offset = 23360
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BB40, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179068 s_dfu_settings.write_offset = 23420
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BB7C, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179128 s_dfu_settings.write_offset = 23480
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BBB8, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179188 s_dfu_settings.write_offset = 23540
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BBF4, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179248 s_dfu_settings.write_offset = 23600
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BC30, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179308 s_dfu_settings.write_offset = 23660
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BC6C, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179368 s_dfu_settings.write_offset = 23720
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BCA8, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179428 s_dfu_settings.write_offset = 23780
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BCE4, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179488 s_dfu_settings.write_offset = 23840
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BD20, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179548 s_dfu_settings.write_offset = 23900
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BD5C, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179608 s_dfu_settings.write_offset = 23960
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BD98, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179668 s_dfu_settings.write_offset = 24020
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BDD4, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179728 s_dfu_settings.write_offset = 24080
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BE10, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179788 s_dfu_settings.write_offset = 24140
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BE4C, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179848 s_dfu_settings.write_offset = 24200
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BE88, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179908 s_dfu_settings.write_offset = 24260
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BEC4, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 179968 s_dfu_settings.write_offset = 24320
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BF00, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 180028 s_dfu_settings.write_offset = 24380
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BF3C, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 180088 s_dfu_settings.write_offset = 24440
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BF78, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 180148 s_dfu_settings.write_offset = 24500
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BFB4, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 180208 s_dfu_settings.write_offset = 24560
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2BFF0, src=0x20003790, len=16 bytes), queue usage: 1
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:24576, CRC:0x0254690F
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    Flash erase success
    <debug> nrf_dfu_req_handler: Creating object with size: 436. Offset: 0x00006000, CRC: 0x0254690F
     WRITE_ADDR = 180224 s_dfu_settings.write_offset = 24576
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2C000, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 180284 s_dfu_settings.write_offset = 24636
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2C03C, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 180344 s_dfu_settings.write_offset = 24696
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2C078, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 180404 s_dfu_settings.write_offset = 24756
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2C0B4, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 180464 s_dfu_settings.write_offset = 24816
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2C0F0, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 180524 s_dfu_settings.write_offset = 24876
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2C12C, src=0x20003790, len=60 bytes), queue usage: 1
     WRITE_ADDR = 180584 s_dfu_settings.write_offset = 24936
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2C168, src=0x20003814, len=60 bytes), queue usage: 1
     WRITE_ADDR = 180644 s_dfu_settings.write_offset = 24996
    Flash write success
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x2C1A4, src=0x20003790, len=16 bytes), queue usage: 1
    <debug> nrf_dfu_req_handler: Offset:25012, CRC:0xE15F6689
    Writing settings...
    Flash erase success
    Flash write success
    Writing settings...
    Flash erase success
    Flash write success
    <debug> nrf_dfu_req_handler: Whole firmware image received. Postvalidating.
    <debug> nrf_dfu_validation: Hash verification. Firmware start address: 0x26000, size: 0x61B4
    <debug> nrf_dfu_validation: Invalidating old application in bank 0.
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0xFF000, src=0x20003974, len=348 bytes), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0xFE000, src=0x20003AD0, len=348 bytes), queue usage: 1
    <debug> nrf_dfu_req_handler: All flash operations have completed. DFU completed.
    <debug> app: Resetting bootloader.
    <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    Inside main
    Valid App
    In image copy
    No copy needed src_addr: 0x26000, dst_addr: 0x26000
    Writing settings...
    Flash erase success
    Flash write success
    Writing settings...
    Flash erase success
    Flash write success
    ACTIVATION_SUCCESS
    <debug> nrf_dfu_settings: Settings OK
    <debug> app: Valid App
    <debug> app: Enter nrf_dfu_app_continue
    <debug> app: No copy needed src_addr: 0x26000, dst_addr: 0x26000
    <debug> app: Setting app as valid
    Inside main
    ACTIVATION NONE = 0
  • I am sorry, I wasn't clear.
     Is the bootloader always from SDK15.2.0? Because you mention SDK14.2.0 as well.
    Well, if you are not using HWFC (Flow Control) on the UART connection, and you are sending the packets too fast, then you need to send the packets slow enough for the flash writes to have time to finish.
    Edvin
