Try to separate the sample of hid_keyboard into ble function and hid service, then found it could be connected at first but show pair immediately
As the subject description, I just remove the part of hid function from main.c then make the personal source file.
Before I removed, the project could work as usual.
And after I create the source file for hid function into the project, the project could be built without error.
Somehow, it could not work properly.
Compare the log
As you could see from the picture above, the left show fatal error compare to the right(Normal).
Not sure why it could be connected but show pair immediately without function.
Do you have any idea or instruction could share with me?
Thanks.
  • A random guess based off your description is that you are referencing memory that is no longer in scope / belonged to a returned functions stack frame.
    Could you provide some code?
  • Hi Smackenzie,
    Actually, I could not understand "referencing memory", what does it mean?
    Anyway, below is the header I make
    #ifndef HID_FUNCTION_H__
    #define HID_FUNCTION_H__
    #include <stdint.h>
    #include <stdbool.h>
    #include "ble.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "nrf_ble_gatt.h"
    #include "ble_hids.h"
    #ifdef __cplusplus
    extern "C" {
    #define MAX_BUFFER_ENTRIES                  5                                          /**< Number of elements that can be enqueued */
    /**Buffer queue access macros
    /** Initialization of buffer list */
    #define BUFFER_LIST_INIT()     \
        do                         \
            buffer_list.rp    = 0; \
            buffer_list.wp    = 0; \
            buffer_list.count = 0; \
        } while (0)
    /** Provide status of data list is full or not */
    #define BUFFER_LIST_FULL() \
        ((MAX_BUFFER_ENTRIES == buffer_list.count - 1) ? true : false)
    /** Provides status of buffer list is empty or not */
    #define BUFFER_LIST_EMPTY() \
        ((0 == buffer_list.count) ? true : false)
    #define BUFFER_ELEMENT_INIT(i)                 \
        do                                         \
            buffer_list.buffer[(i)].p_data = NULL; \
        } while (0)
    /** Abstracts buffer element */
    typedef struct hid_key_buffer
        uint8_t      data_offset; /**< Max Data that can be buffered for all entries */
        uint8_t      data_len;    /**< Total length of data */
        uint8_t    * p_data;      /**< Scanned key pattern */
        ble_hids_t * p_instance;  /**< Identifies peer and service instance */
    } buffer_entry_t;
    STATIC_ASSERT(sizeof(buffer_entry_t) % 4 == 0);
    /** Circular buffer list */
    typedef struct
        buffer_entry_t buffer[MAX_BUFFER_ENTRIES]; /**< Maximum number of entries that can enqueued in the list */
        uint8_t        rp;                         /**< Index to the read location */
        uint8_t        wp;                         /**< Index to write location */
        uint8_t        count;                      /**< Number of elements in the list */
    } buffer_list_t;
    STATIC_ASSERT(sizeof(buffer_list_t) % 4 == 0);
    static bool              m_in_boot_mode = false;                    /**< Current protocol mode. */
    static buffer_list_t     buffer_list;                               /**< List to enqueue not just data to be sent, but also related information like the handle, connection handle etc */
    uint32_t buffer_dequeue(bool tx_flag);
    void buffer_init(void);
    void hids_init(void);
    #ifdef __cplusplus
    #endif //HID_FUNCTION_H
    And here is the source code:
    #include "sdk_common.h"
    #include <string.h>
    #include "app_error.h"
    #include "ble_srv_common.h"
    #include "hid_function.h"
    #include "nrf_delay.h"
    #define OUTPUT_REPORT_INDEX                 0                                          /**< Index of Output Report. */
    #define OUTPUT_REPORT_MAX_LEN               1                                          /**< Maximum length of Output Report. */
    #define INPUT_REPORT_KEYS_INDEX             0                                          /**< Index of Input Report. */
    #define INPUT_REP_REF_ID                    0                                          /**< Id of reference to Keyboard Input Report. */
    #define OUTPUT_REP_REF_ID                   0                                          /**< Id of reference to Keyboard Output Report. */
    #define FEATURE_REP_REF_ID                  0                                          /**< ID of reference to Keyboard Feature Report. */
    #define FEATURE_REPORT_MAX_LEN              2                                          /**< Maximum length of Feature Report. */
    #define FEATURE_REPORT_INDEX                0                                          /**< Index of Feature Report. */
    #define BASE_USB_HID_SPEC_VERSION           0x0101                                     /**< Version number of base USB HID Specification implemented by this application. */
    #define INPUT_REPORT_KEYS_MAX_LEN           8                                          /**< Maximum length of the Input Report characteristic. */
    #define MODIFIER_KEY_POS                    0                                          /**< Position of the modifier byte in the Input Report. */
    #define SCAN_CODE_POS                       2                                          /**< The start position of the key scan code in a HID Report. */
    #define MAX_KEYS_IN_ONE_REPORT              (INPUT_REPORT_KEYS_MAX_LEN - SCAN_CODE_POS)/**< Maximum number of key presses that can be sent in one Input Report. */
    BLE_HIDS_DEF(m_hids,                                                /**< Structure used to identify the HID service. */
                 NRF_SDH_BLE_TOTAL_LINK_COUNT,
                 INPUT_REPORT_KEYS_MAX_LEN,
                 OUTPUT_REPORT_MAX_LEN,
                 FEATURE_REPORT_MAX_LEN);
    static uint16_t          m_conn_handle  = BLE_CONN_HANDLE_INVALID;  /**< Handle of the current connection. */
    static void on_hids_evt(ble_hids_t * p_hids, ble_hids_evt_t * p_evt);
    /**@brief Function for handling Service errors.
    static void service_error_handler(uint32_t nrf_error)
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for initializing HID Service.
        ret_code_t                    err_code;
        ble_hids_init_t               hids_init_obj;
        ble_hids_inp_rep_init_t     * p_input_report;
        ble_hids_outp_rep_init_t    * p_output_report;
        ble_hids_feature_rep_init_t * p_feature_report;
        uint8_t                       hid_info_flags;
        static ble_hids_inp_rep_init_t     input_report_array[1];
        static ble_hids_outp_rep_init_t    output_report_array[1];
        static ble_hids_feature_rep_init_t feature_report_array[1];
        static uint8_t                     report_map_data[] =
            0x05, 0x01,       // Usage Page (Generic Desktop)
            0x09, 0x06,       // Usage (Keyboard)
            0xA1, 0x01,       // Collection (Application)
            0x05, 0x07,       // Usage Page (Key Codes)
            0x19, 0xe0,       // Usage Minimum (224)
            0x29, 0xe7,       // Usage Maximum (231)
            0x15, 0x00,       // Logical Minimum (0)
            0x25, 0x01,       // Logical Maximum (1)
            0x75, 0x01,       // Report Size (1)
            0x95, 0x08,       // Report Count (8)
            0x81, 0x02,       // Input (Data, Variable, Absolute)
            0x95, 0x01,       // Report Count (1)
            0x75, 0x08,       // Report Size (8)
            0x81, 0x01,       // Input (Constant) reserved byte(1)
            0x95, 0x05,       // Report Count (5)
            0x05, 0x08,       // Usage Page (Page# for LEDs)
            0x19, 0x01,       // Usage Minimum (1)
            0x29, 0x05,       // Usage Maximum (5)
            0x91, 0x02,       // Output (Data, Variable, Absolute), Led report
            0x75, 0x03,       // Report Size (3)
            0x91, 0x01,       // Output (Data, Variable, Absolute), Led report padding
            0x95, 0x06,       // Report Count (6)
            0x25, 0x65,       // Logical Maximum (101)
            0x05, 0x07,       // Usage Page (Key codes)
            0x19, 0x00,       // Usage Minimum (0)
            0x29, 0x65,       // Usage Maximum (101)
            0x81, 0x00,       // Input (Data, Array) Key array(6 bytes)
            0x09, 0x05,       // Usage (Vendor Defined)
            0x26, 0xFF, 0x00, // Logical Maximum (255)
            0x75, 0x08,       // Report Size (8 bit)
            0x95, 0x02,       // Report Count (2)
            0xB1, 0x02,       // Feature (Data, Variable, Absolute)
            0xC0              // End Collection (Application)
        memset((void *)input_report_array, 0, sizeof(ble_hids_inp_rep_init_t));
        memset((void *)output_report_array, 0, sizeof(ble_hids_outp_rep_init_t));
        memset((void *)feature_report_array, 0, sizeof(ble_hids_feature_rep_init_t));
        // Initialize HID Service
        p_input_report                      = &input_report_array[INPUT_REPORT_KEYS_INDEX];
        p_input_report->max_len             = INPUT_REPORT_KEYS_MAX_LEN;
        p_input_report->rep_ref.report_id   = INPUT_REP_REF_ID;
        p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
        p_input_report->sec.cccd_wr = SEC_JUST_WORKS;
        p_input_report->sec.wr      = SEC_JUST_WORKS;
        p_input_report->sec.rd      = SEC_JUST_WORKS;
        p_output_report                      = &output_report_array[OUTPUT_REPORT_INDEX];
        p_output_report->max_len             = OUTPUT_REPORT_MAX_LEN;
        p_output_report->rep_ref.report_id   = OUTPUT_REP_REF_ID;
        p_output_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_OUTPUT;
        p_output_report->sec.wr = SEC_JUST_WORKS;
        p_output_report->sec.rd = SEC_JUST_WORKS;
        p_feature_report                      = &feature_report_array[FEATURE_REPORT_INDEX];
        p_feature_report->max_len             = FEATURE_REPORT_MAX_LEN;
        p_feature_report->rep_ref.report_id   = FEATURE_REP_REF_ID;
        p_feature_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_FEATURE;
        p_feature_report->sec.rd              = SEC_JUST_WORKS;
        p_feature_report->sec.wr              = SEC_JUST_WORKS;
        hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
        memset(&hids_init_obj, 0, sizeof(hids_init_obj));
        hids_init_obj.evt_handler                    = on_hids_evt;
        hids_init_obj.error_handler                  = service_error_handler;
        hids_init_obj.is_kb                          = true;
        hids_init_obj.is_mouse                       = false;
        hids_init_obj.inp_rep_count                  = 1;
        hids_init_obj.p_inp_rep_array                = input_report_array;
        hids_init_obj.outp_rep_count                 = 1;
        hids_init_obj.p_outp_rep_array               = output_report_array;
        hids_init_obj.feature_rep_count              = 1;
        hids_init_obj.p_feature_rep_array            = feature_report_array;
        hids_init_obj.rep_map.data_len               = sizeof(report_map_data);
        hids_init_obj.rep_map.p_data                 = report_map_data;
        hids_init_obj.hid_information.bcd_hid        = BASE_USB_HID_SPEC_VERSION;
        hids_init_obj.hid_information.b_country_code = 0;
        hids_init_obj.hid_information.flags          = hid_info_flags;
        hids_init_obj.included_services_count        = 0;
        hids_init_obj.p_included_services_array      = NULL;
        hids_init_obj.rep_map.rd_sec         = SEC_JUST_WORKS;
        hids_init_obj.hid_information.rd_sec = SEC_JUST_WORKS;
        hids_init_obj.boot_kb_inp_rep_sec.cccd_wr = SEC_JUST_WORKS;
        hids_init_obj.boot_kb_inp_rep_sec.rd      = SEC_JUST_WORKS;
        hids_init_obj.boot_kb_outp_rep_sec.rd = SEC_JUST_WORKS;
        hids_init_obj.boot_kb_outp_rep_sec.wr = SEC_JUST_WORKS;
        hids_init_obj.protocol_mode_rd_sec = SEC_JUST_WORKS;
        hids_init_obj.protocol_mode_wr_sec = SEC_JUST_WORKS;
        hids_init_obj.ctrl_point_wr_sec    = SEC_JUST_WORKS;
        err_code = ble_hids_init(&m_hids, &hids_init_obj);
    /**@brief   Function for transmitting a key scan Press & Release Notification.
     * @warning This handler is an example only. You need to analyze how you wish to send the key
     *          release.
     * @param[in]  p_instance     Identifies the service for which Key Notifications are requested.
     * @param[in]  p_key_pattern  Pointer to key pattern.
     * @param[in]  pattern_len    Length of key pattern. 0 < pattern_len < 7.
     * @param[in]  pattern_offset Offset applied to Key Pattern for transmission.
     * @param[out] actual_len     Provides actual length of Key Pattern transmitted, making buffering of
     *                            rest possible if needed.
     * @return     NRF_SUCCESS on success, NRF_ERROR_RESOURCES in case transmission could not be
     *             completed due to lack of transmission buffer or other error codes indicating reason
     *             for failure.
    static uint32_t send_key_scan_press_release(ble_hids_t * p_hids,
                                                uint8_t    * p_key_pattern,
                                                uint16_t     pattern_len,
                                                uint16_t     pattern_offset,
                                                uint16_t   * p_actual_len)
        uint16_t offset;
        uint16_t data_len;
        uint8_t  data[INPUT_REPORT_KEYS_MAX_LEN];
        // HID Report Descriptor enumerates an array of size 6, the pattern hence shall not be any
        // longer than this.
        STATIC_ASSERT((INPUT_REPORT_KEYS_MAX_LEN - 2) == 6);
        ASSERT(pattern_len <= (INPUT_REPORT_KEYS_MAX_LEN - 2));
        offset   = pattern_offset;
        data_len = pattern_len;
        do
            // Reset the data buffer.
            memset(data, 0, sizeof(data));
            // Copy the scan code.
            memcpy(data + SCAN_CODE_POS + offset, p_key_pattern + offset, data_len - offset);
            if (!m_in_boot_mode)
                err_code = ble_hids_inp_rep_send(p_hids,
                                                 INPUT_REPORT_KEYS_INDEX,
                                                 data,
                                                 m_conn_handle);
                err_code = ble_hids_boot_kb_inp_rep_send(p_hids,
                                                         data,
                                                         m_conn_handle);
            if (err_code != NRF_SUCCESS)
            offset++;
        while (offset <= data_len);
        *p_actual_len = offset;
        return err_code;
    /**@brief   Function for initializing the buffer queue used to key events that could not be
     *          transmitted
     * @warning This handler is an example only. You need to analyze how you wish to buffer or buffer at
     *          all.
     * @note    In case of HID keyboard, a temporary buffering could be employed to handle scenarios
     *          where encryption is not yet enabled or there was a momentary link loss or there were no
     *          Transmit buffers.
        uint32_t buffer_count;
        BUFFER_LIST_INIT();
        for (buffer_count = 0; buffer_count < MAX_BUFFER_ENTRIES; buffer_count++)
            BUFFER_ELEMENT_INIT(buffer_count);
    /**@brief Function for enqueuing key scan patterns that could not be transmitted either completely
     *        or partially.
     *          release.
     * @param[in]  p_hids         Identifies the service for which Key Notifications are buffered.
     * @param[in]  offset         Offset applied to Key Pattern when requesting a transmission on
     *                            dequeue, @ref buffer_dequeue.
     * @return     NRF_SUCCESS on success, else an error code indicating reason for failure.
    static uint32_t buffer_enqueue(ble_hids_t * p_hids,
                                   uint16_t     offset)
        buffer_entry_t * element;
        uint32_t         err_code = NRF_SUCCESS;
        if (BUFFER_LIST_FULL())
            // Element cannot be buffered.
            err_code = NRF_ERROR_NO_MEM;
            // Make entry of buffer element and copy data.
            element              = &buffer_list.buffer[(buffer_list.wp)];
            element->p_instance  = p_hids;
            element->p_data      = p_key_pattern;
            element->data_offset = offset;
            element->data_len    = pattern_len;
            buffer_list.count++;
            buffer_list.wp++;
            if (buffer_list.wp == MAX_BUFFER_ENTRIES)
                buffer_list.wp = 0;
        return err_code;
    /**@brief   Function to dequeue key scan patterns that could not be transmitted either completely of
     *          partially.
     *          release.
     * @param[in]  tx_flag   Indicative of whether the dequeue should result in transmission or not.
     * @note       A typical example when all keys are dequeued with transmission is when link is
     *             disconnected.
        buffer_entry_t * p_element;
        uint16_t         actual_len;
        if (BUFFER_LIST_EMPTY())
            err_code = NRF_ERROR_NOT_FOUND;
            bool remove_element = true;
            p_element = &buffer_list.buffer[(buffer_list.rp)];
            if (tx_flag)
                err_code = send_key_scan_press_release(p_element->p_instance,
                                                       p_element->p_data,
                                                       p_element->data_len,
                                                       p_element->data_offset,
                                                       &actual_len);
                // An additional notification is needed for release of all keys, therefore check
                // is for actual_len <= element->data_len and not actual_len < element->data_len
                if ((err_code == NRF_ERROR_RESOURCES) && (actual_len <= p_element->data_len))
                    // Transmission could not be completed, do not remove the entry, adjust next data to
                    // be transmitted
                    p_element->data_offset = actual_len;
                    remove_element         = false;
            if (remove_element)
                BUFFER_ELEMENT_INIT(buffer_list.rp);
                buffer_list.rp++;
                buffer_list.count--;
                if (buffer_list.rp == MAX_BUFFER_ENTRIES)
                    buffer_list.rp = 0;
        return err_code;
    /**@brief Function for handling the HID Report Characteristic Write event.
     * @param[in]   p_evt   HID service event.
    static void on_hid_rep_char_write(ble_hids_evt_t * p_evt)
        if (p_evt->params.char_write.char_id.rep_type == BLE_HIDS_REP_TYPE_OUTPUT)
            uint8_t  report_val;
            uint8_t  report_index = p_evt->params.char_write.char_id.rep_index;
            if (report_index == OUTPUT_REPORT_INDEX)
                // This code assumes that the output report is one byte long. Hence the following
                // static assert is made.
                STATIC_ASSERT(OUTPUT_REPORT_MAX_LEN == 1);
                err_code = ble_hids_outp_rep_get(&m_hids,
                                                 report_index,
                                                 0,
                                                 m_conn_handle,
                                                 &report_val);
    /**@brief Function for handling HID events.
     * @details This function will be called for all HID events which are passed to the application.
     * @param[in]   p_hids  HID service structure.
     * @param[in]   p_evt   Event received from the HID service.
        switch (p_evt->evt_type)
            case BLE_HIDS_EVT_BOOT_MODE_ENTERED:
                m_in_boot_mode = true;
            case BLE_HIDS_EVT_REPORT_MODE_ENTERED:
            case BLE_HIDS_EVT_REP_CHAR_WRITE:
                on_hid_rep_char_write(p_evt);
            case BLE_HIDS_EVT_NOTIF_ENABLED:
                // No implementation needed.
    About the main.c, I just include them and add the function as below:
    hids_init();
    buffer_init();
    Thanks.
  • Hi Smackenzie,
    Was the information for you?
    Or you still need the main.c?
  • Hi Smackenzie,
    I just noticed that when I remove below functions from main.c to source file the issue happened.
    static void hids_init(void)
    The symptom is a little bit like force to disconnected by windows.
    However, the device could be stable connected with mobile.
    Do you have any idea or experience with that?
    Thanks.
  • The error happened in app_error_weak.c app_error_fault_handler function. Enable DEBUG define in your project and put a breakpoint here and run your code in debugger and step to see which can of error this is. You will get more info if you enable DEBUG in your preprocessor defines.
