Bootloader to applocation switching issue
Hi ,
I am working on NRF DFU firmware update. for that i am using secure bootloader code .
I tried with the of way of flasing bootloader code on my custom board and sent my application code through app(NRF CONNECT) .when want to change the bootloader its moving to bootmode and can able to update . its working fine..
then i tried to merge my applicartion and bootloader code ... ( in components file i took the softdevice hex file + application code hex file ) merged together usinng commad
mergehex.exe -m softdevice.hex application.hex -o new_app.hex
using the above command - my aplication working fine.... the with the new_app.hex file merged with my bootloader hex file using the command
mergehex.exe -m new_app.hex bootloader.hex -o final.hex
using the above command - got by final hex file .
using nrfjporg command flashed my final.hex file to my custom board ..
now my question is ....
in my custom board i flashed my merged file (which is my application + bootloader )
but at first time , it enters in bootloader mode only .. in my bootloader code i set 2 mins stand by time in bootloader mode .
after that it moves from bootloader mode to application mode.but it does not enter to application mode.
Once i sent my application code via app then its switching to application mode .. as i metioned above when i want to change to boot its switching to bootloader mode if i dont update my firmware ,its automatically moving to my appllication which is running before ...if i updates its updating ...
why my merged file only in bootloader mode at first ...
from my assumption it should switch to application after 2mins (which from the merged file )
Whats the issue of it does not enter into apllication mode at first time.??????
    The behavior that you see is expected because the bootloader can see that there is an application in flash, but since the application is flashed directly and not via DFU (nRF Connect), the bootloader never verified that the application is signed with the correct private key. This is a safety mechanism.
    Usually, when you generate a DFU image, you need to enter the private key as one of the parameters:
    nrfutil pkg generate --application app.hex --application-version 1 --hw-version 52 --sd-req 0xAF --key-file private.key
    This will create an image including the application, and a signature verifying that the person who generated this packet has access to the private key. When the bootloader receives this image, it will store the CRC of the application and the signature in something called bootloader settings. This means if someone changes the application in this image, the CRC will no longer match, and the singature is no longer valid.
    Luckily, there is a way to work around this. If you have access to the private key, you can generate the bootloader settings manually using your private key and merge it together with your application+bootloader, and flash it manually. Now, when this happens, the bootloader will see that the bootloader settings accepts the flashed application, and start the application as if you transferred the application via DFU.
    To generate bootloader settings (bl_settings) you can use the following command:
    nrfutil settings generate --family NRF52840 --application app.hex --application-version 1 --bootloader-version 1 --bl-settings-version 1 --key-file private.key bl_settings.hex
    (use "nrfutil settings generate --help" for more information)
    now merge your hex file:
    mergehex.exe -m final.hex bl_settings.hex -o final_with_bl_settings.hex
    and program it using
    nrfjprog --program final_with_bl_settings.hex --verify && nrfjprog --reset
    And it should start the application.
    Edvin
  • Hai ,
     thanks for ur reply , tried as u said now its working fine ....but sometimes from apllication , its not jumpimg to bootloader mode ..
    i am using the follwing command in my application part  to switch into bootloader mode
    #DEFINE  BOOTLOADER_DFU_START 0xB1
    NRF_POWER->GPREGRET = BOOTLOADER_DFU_START;
    NVIC_SystemReset();
     by this way i am using this as buttonless to swtich over  ... sometimes i am having this issue ...
    can you please tell me ??????
    Thanks ,
  • If you call:
    NVIC_SystemReset();
    right after one another, it may not actually get time to write to the register before the reset. Try to add a small delay between the two (you can use nrf_delay_ms(10); ). Does that work?
  • thanks , now its working fine ...
    now i am tryingto update nrf52840 from my third party (esp32)
    i am able send to init packet  and receiving response as per the dfu protocol .
    i am strucking in sending my bin file ... my question is how to send the bin file as 12 objects from my third party ??
    In  nrf connect application when send as zip file ,gets parsing first its sending init packet which is dat file and then parsing the bin file as 12 objects   ..and for each objects  calculating crc and its updating  ...
    I don't have much more to point to other than the documentation.
    I suggest that you check the documentation for the DFU Protocol, the Serial protocol, the Message Sequence Chart and the SLIP library to see how to transfer the objects.
    We have an unofficial example that acts as a DFU master. I have not tested it, but perhaps you can look at this for inspiration.
    Edvin
