How to debug NRF_ERROR_INVALID_STATE easily?
I receive NRF_ERROR_INVALID_STATE error quite a few times because my own state handling is still a little buggy. I want to find all these errors. What would be the best way to debug this. Is there any possibility to read the current state of the softdevice? I am currently calling sd_ble_gattc_characteristics_discover after I received the BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP event. This results in an invalid state and I am not quite sure why this would happen. I would be very interested in getting the current state and maybe a possibility if advertising and/or scanning are currently switched on or if a connection is in progress,etc... The more information I can get from the SoftDevice (S130 0.9-alpha), the better.
Thanks a lot, Marius
  • Hi Marius,
    It seems you have issue with the connection handle, most likely the connection handle you used for sd_ble_gattc_characteristics_discover() is not the actual connection handle you receive when the event occurs in p_db_discovery->conn_handle.
    Could you verify you have the same issue when using our device manager library ?
    here is my code that I call upon receiving the BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP event:
    void _bleServiceDiscoveryFinishedHandler(ble_evt_t* bleEvent){
    	u32 err = 0;
    	//Service has been found
    	if(bleEvent->evt.gattc_evt.params.prim_srvc_disc_rsp.count > 0){
    		if(debugPlainC) tracel("Found service");
    		//Service handle range has been found, now start discovery on characteristics
    		ble_gattc_handle_range_t handleRange;
    		handleRange.start_handle = bleEvent->evt.gattc_evt.params.prim_srvc_disc_rsp.services[0].handle_range.start_handle;
    		handleRange.end_handle = bleEvent->evt.gattc_evt.params.prim_srvc_disc_rsp.services[0].handle_range.end_handle;
    		err = sd_ble_gattc_characteristics_discover(bleEvent->evt.gap_evt.conn_handle, &handleRange);
    		APP_ERROR_CHECK(err);
    However I only received this error once while I was debugging and it has never occured again since. Maybe I have an error in that code snippet or maybe it was something else. I have just switched over from KEIL to developing with Eclipse and GCC.
  • @Marius: You should not use bleEvent->evt.gap_evt.conn_handle when in BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP event, because it's gattc_evt. You should use bleEvent->evt.gattc_evt.conn_handle
    Btw, It's better if you can add your code in your initial question or post it as a comment under my answer instead of creating an answer.
    thanks. i will update this in my code. i wanted to add it as a comment, but I did not have enough characters left, so I had to post it as an answer, sorry.
  • @Marius: Could you update the case ? If you fixed the issue you can accept the answer so that the case is closed.
