Segger Embedded Studio for RF9160 DK - solution load command failed (1)
I've used the 'Getting Started with nRF9160 DK' tutorial to setup a development environment, I have a problems with loading asset_tracker project. My output:
Loading solution asset_tracker.emProject
Executing load commands
cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=C:/My_Designs/nRF Connect SDK/V1_1_0/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/gnuarmemb -BC:/My_Designs/nRF Connect SDK/V1_1_0/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090ns -HC:/My_Designs/nRF Connect SDK/V1_1_0/ncs/nrf/applications/asset_tracker -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:/arm_segger_embedded_studio_v430c_win_x64_nordic/html/configure_nordic_project_menuconfig.py
Failed to create ConsoleBuf!
setActiveInputCodepage failed!
-- Using application from 'C:/My_Designs/nRF Connect SDK/V1_1_0/ncs/nrf/applications/asset_tracker'
Zephyr version: 2.0.99
-- Selected BOARD nrf9160_pca10090ns
-- Found west: C:/Python38/Scripts/west.exe (found suitable version "0.6.3", minimum required is "0.6.0")
-- Cache files will be written to: C:\Users\bertiew\AppData\Local/.cache/zephyr
USING OUT OF TREE BOARD
CMake Error at C:/My_Designs/nRF Connect SDK/V1_1_0/ncs/zephyr/cmake/kconfig.cmake:168 (message):
File not found: C:/My_Designs/nRF/nrf9160_pca10090ns_defconfig
C:/My_Designs/nRF Connect SDK/V1_1_0/ncs/zephyr/cmake/app/boilerplate.cmake:567 (include)
CMakeLists.txt:11 (include)
Project load failed
Reported error: solution load command failed (1)
BTW, During the installation, I verified every steps and working fine except Clone nRF Connect SDK with ERROR "update failed for project civetweb". But was fixed by downgrade git 2.24 to 2.23 and doing all again.
Bertie
  • Thanks Martin, I just changed folder name "nRF Connect SDK" to "nRFConnectSDK", and it works! see log:
    cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=C:/My_Designs/nRFConnectSDK/V1_1_0/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/gnuarmemb -BC:/My_Designs/nRFConnectSDK/V1_1_0/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090ns -HC:/My_Designs/nRFConnectSDK/V1_1_0/ncs/nrf/applications/asset_tracker -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:/arm_segger_embedded_studio_v430c_win_x64_nordic/html/configure_nordic_project_menuconfig.py
    -- Using application from 'C:/My_Designs/nRFConnectSDK/V1_1_0/ncs/nrf/applications/asset_tracker'
    -- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.6.3", minimum required is "0.6.0")
    -- Loading C:/My_Designs/nRFConnectSDK/V1_1_0/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
    -- Overlaying C:/My_Designs/nRFConnectSDK/V1_1_0/ncs/zephyr/dts/common/common.dts
    Devicetree configuration written to C:/My_Designs/nRFConnectSDK/V1_1_0/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090ns/zephyr/include/generated/generated_dts_board.conf
    Parsing Kconfig tree in C:/My_Designs/nRFConnectSDK/V1_1_0/ncs/nrf/applications/asset_tracker/Kconfig
    Loading session data from file
    SEGGER Embedded Studio is ready to use
    BTW, the message "Failed to create ConsoleBuf!" is a problem? But no problem to build solution
  • Hi Bertie,
    That is good news.
    Could you ensure that you start with a clean build directory when trying to import the project?
    Delete the build folder and then try to open up the project again.
    If you have had issues prior (with the configuration) and you re-configure in the same build folder, it may give you issues, so removing the build folder manually between each import is highly recommended.
    Martin L.
1 2
