nrfx_saadc.c Fills Buffer in Indefinite Order and Skips Samples
Hardware/Software
Device: nRF5340 PDK
Software versions:
NordicSemiconductor/nrfx v2.0.0
zephyrproject-rtos/zephyr v2.1.0
Description
I'm currently sampling 4 channels using `nrfx_saadc_simple_mode_set(...)` in blocking mode, and calling `nrfx_saadc_mode_trigger()` after calibrating the saadc in blocking mode.
The first time sampling the buffer looks like {CH0, CH1, CH3, CH2} (which is an issue of its own) and each time it is sampled afterwards it looks like {~2473, CH0, CH1, CH3}.
ch0 = 247, ch1 = 328, ch2 = 525, ch3 = 427
ch0 = 2474, ch1 = 247, ch2 = 328, ch3 = 524
ch0 = 2483, ch1 = 248, ch2 = 328, ch3 = 524
ch0 = 2473, ch1 = 247, ch2 = 328, ch3 = 524
Code
#include <zephyr.h>
#include <sys/printk.h>
#include <power/power.h>
#include <soc.h>
#include <nrfx_saadc.h>
#define DEFAULT_CHANNEL_CONFIG = {                  \
    .channel_config =                               \
        .resistor_p = NRF_SAADC_RESISTOR_DISABLED,  \
        .resistor_n = NRF_SAADC_RESISTOR_DISABLED,  \
        .gain       = NRF_SAADC_GAIN1_6,            \
        .reference  = NRF_SAADC_REFERENCE_INTERNAL, \
        .acq_time   = NRF_SAADC_ACQTIME_40US,       \
        .mode       = NRF_SAADC_MODE_SINGLE_ENDED,  \
        .burst      = NRF_SAADC_BURST_ENABLED,      \
    .pin_p          = NRF_SAADC_INPUT_AIN0,         \
    .pin_n          = NRF_SAADC_INPUT_DISABLED,     \
    .channel_index  = 0                             \
K_TIMER_DEFINE(wake_timer, NULL, NULL);
ISR_DIRECT_DECLARE(saadc_isr){
    if (NRF_SAADC_S->EVENTS_STARTED){
      NRF_SAADC_S->EVENTS_STARTED = 0;
    if (NRF_SAADC_S->EVENTS_END){
      NRF_SAADC_S->EVENTS_END = 0;
    if (NRF_SAADC_S->EVENTS_DONE){
      NRF_SAADC_S->EVENTS_DONE = 0;
    if (NRF_SAADC_S->EVENTS_RESULTDONE){
      NRF_SAADC_S->EVENTS_RESULTDONE = 0;
    if (NRF_SAADC_S->EVENTS_CALIBRATEDONE){
      NRF_SAADC_S->EVENTS_CALIBRATEDONE = 0;
    if (NRF_SAADC_S->EVENTS_STOPPED){
      NRF_SAADC_S->EVENTS_STOPPED = 0;
    ISR_DIRECT_PM();
    return 1;
int main(void){
    nrfx_err_t err_code;
    nrfx_saadc_channel_t ch0 = DEFAULT_CHANNEL_CONFIG;
    nrfx_saadc_channel_t ch1 = DEFAULT_CHANNEL_CONFIG;
    nrfx_saadc_channel_t ch2 = DEFAULT_CHANNEL_CONFIG;
    nrfx_saadc_channel_t ch3 = DEFAULT_CHANNEL_CONFIG;
    ch1.pin_p = NRF_SAADC_INPUT_AIN6;
    ch1.channel_index = 1;
    ch1.pin_p = NRF_SAADC_INPUT_AIN7;
    ch1.channel_index = 2;
    ch1.pin_p = NRF_SAADC_INPUT_AIN2;
    ch1.channel_index = 3;
            while (true){
                // Connect IRQ
                IRQ_DIRECT_CONNECT(SAADC_IRQn, 6, saadc_isr, 0);
                err_code = nrfx_saadc_init(0);
                if (err_code != NRFX_SUCCESS)
                  return err_code;
                nrfx_saadc_channel_t channels[4] = {ch0, ch1, ch2, ch3};
                err_code = nrfx_saadc_channels_config(channels, 4);
                  return err_code;
                // Calibrate SAADC
                err_code = nrfx_saadc_offset_calibrate(NULL);
                  return err_code;
                u8_t channel_mask = (1U << 0) | ( 1U << 1) | (1U << 2) | (1U << 3);
                err_code = nrfx_saadc_simple_mode_set(channel_mask,
                                              NRF_SAADC_RESOLUTION_10BIT,
                                              NRF_SAADC_OVERSAMPLE_16X,
                                              NULL);
                    return err_code;
                // Give buffer and trigger sample
                nrf_saadc_value_t buffer[4] = {0};
                err_code = nrfx_saadc_buffer_set(buffer, 4);
                    return err_code;
                err_code = nrfx_saadc_mode_trigger();
                    return err_code;
                // Note: channel order is off in buffer
                nrf_saadc_value_t ch0_counts = buffer[0]; // Forced to ~250cnts
                nrf_saadc_value_t ch1_counts = buffer[1]; // Forced to ~350cnts
                nrf_saadc_value_t ch2_counts = buffer[2]; // Forced to ~450cnts
                nrf_saadc_value_t ch3_coutns = buffer[3]; // Forced to ~550cnts
                printk("ch0 = %d, ch1 = %d, ch2 = %d, ch3 = %d\n",
                       ch0_counts, ch1_counts, ch2_counts, ch3_counts);
                // Sleep for 100ms
                nrfx_saadc_uninit();
                k_timer_start(&wake_timer, K_MSEC(100), 0);
                k_cpu_idle();
  • My first guess is that the offset calibration is not complete before you configure the buffer, and one or more of the samples taken during offset calibration has started to fill the buffer. You should wait for EVENTS_CALIBRATEDONE before you continue configuring the SAADC.
  • Thank you for your reply. My current implementation performs each operation, including calibration, in blocking mode according to the documentation. If I include an event handler, whose implementation is not yet supported on an RTOS, I have to do event handling manually with the ISR I provided above.
    This is a problem because the nrfx_saadc driver has an internal structure which relies on information passed to the nrfx_saadc_handler_t and I can not replicate those updates with my ISR. This makes the driver think that resources are still busy when they in fact are not. I can't update this internal struct with my ISR because it is declared as static.
  • I modified my code to work asynchronously with some event handling and it still didn't solve the issue. I realized a mistake I was making with my ISR, but it proved not to be causing any immediate problems.
    Changes
    [1] Calibrates before configuring channels
    [2] Waits for NRFX_SAADC_EVT_CALIBRATEDONE before configuring channels
    [3] Waits for NRFX_SAADC_EVT_DONE before unloading buffer
    [4] Uses nrfx_saadc_handler_t callback for event handling
    #include <zephyr.h>
    #include <soc.h>
        .channel_config =                               \
    static volatile bool calibrate_done = true;
    static volatile bool buf_full = true;
        nrfx_saadc_irq_handler();
        ISR_DIRECT_PM();
        return 1;
     * ADC event handler
     * This function is called when the requested number of samples has been processed
    static void saadc_handler(nrfx_saadc_evt_t const *p_event)
        //TODO fill in
        switch (p_event->type)
            case  NRFX_SAADC_EVT_DONE:  // Event generated when the buffer is filled with samples.
                buf_full = true;
            case NRFX_SAADC_EVT_LIMIT:  // Event generated after one of the limits is reached.
            case NRFX_SAADC_EVT_BUF_REQ:  // Event generated when the next buffer for continuous conversion is requested.
            case NRFX_SAADC_EVT_READY:  // Event generated when the first buffer is acquired by the peripheral and sampling can be started.
            case NRFX_SAADC_EVT_FINISHED: // Event generated when all supplied buffers are filled with results.
            case NRFX_SAADC_EVT_CALIBRATEDONE: // Event generated when the calibration is complete.
    int main(void){
        ch2.pin_p = NRF_SAADC_INPUT_AIN7;
        ch2.channel_index = 2;
        ch3.pin_p = NRF_SAADC_INPUT_AIN2;
        ch3.channel_index = 3;
                while (true){
                    // Connect IRQ
                    IRQ_DIRECT_CONNECT(SAADC_IRQn, 0, saadc_isr, 0);
                      return err_code;
                    // Calibrate SAADC
                    calibrate_done = false;
                    err_code = nrfx_saadc_offset_calibrate(saadc_handler);
                      return err_code;
                    while(!calibrate_done){
                      k_sleep(K_MSEC(1));
                      return err_code;
                                                  saadc_handler);
                        return err_code;
                        return err_code;
                    buf_full = false;
                        return err_code;
                    while(!buf_full){
                      k_sleep(K_MSEC(1));
                    // Sleep for 100ms
                    k_cpu_idle();
  • I see a typo when you assign the input pins to your SAADC channels, it should be:
  • Oh thanks! It is not like that in my actual code. I renamed a lot of things to make it easier for support.
