nRF52 I2S Datahandler to buffer save.
hello Everyone
i Need help to Use nRF52840 DK - I2S
Now i can play music use I2S "realtime"
it means when i was Play music front of mic and then i can hear that music to speaker.
so in this time i want to record the sound and play it after some trigger accrued
but i don't know how to save mic input data to Ram Buffer.
here is my part of code - almost same "SDK14.0 I2S Example Data_handler"
when i use that data handler code.. i can play sound real-time
static void data_handler(nrf_drv_i2s_buffers_t const * p_released, uint32_t status)
      ASSERT(p_released);
      if (!(status & NRFX_I2S_STATUS_NEXT_BUFFERS_NEEDED))
            return;
      if (!p_released->p_rx_buffer)
            nrf_drv_i2s_buffers_t const next_buffers =
                  .p_rx_buffer = m_buffer_rx[1],
                  .p_tx_buffer = m_buffer_tx[1],
            APP_ERROR_CHECK(nrf_drv_i2s_next_buffers_set(&next_buffers));
            mp_block_to_check = m_buffer_rx[1];
            mp_block_to_fill = m_buffer_tx[1];
            Count = 0;
            mp_block_to_check = p_released->p_rx_buffer;
            APP_ERROR_CHECK(nrf_drv_i2s_next_buffers_set(p_released));
            mp_block_to_fill = (uint32_t *)p_released->p_tx_buffer;
            NRF_I2S->RXD.PTR = (uint32_t)&pcm_samples[Count];
            NRF_LOG_INFO("Rx - Index:%d, Rx - Vel:0x%08x ", Count, pcm_samples[Count]); //Count, mp_block_to_check);//Count, pcm_samples[Count]);
            NRF_I2S->TXD.PTR = (uint32_t)&pcm_samples[Count - 300];
            NRF_LOG_INFO("Tx - Index:%d, Tx - Vel:0x%08x ", Count, pcm_samples[Count]);
but i want do record and play that sound after so change some part of code...
if (Count >= 300)
Count  ++;
i was do like that to try to play that sound delay
but after few second i can hear only "bzzzzzzzzzzzzzzz" sound
i don't know what is wrong...
help me to solve this problem
thanks for read..
i will wait reply
Thanks again .
