send NRF_LOG to external eeprom
Hello everyone,
I work with a custom board with the nRF52840 chip on it. We have  pressure, humidity and temperature sensor and accelerometer sensor on the board. We need to read the sensor's values and logged it on an eeprom.
Our application is a BLE app with SoftDevice s140 and SDK 15.2.0.
My question is: It is possible to redirect NRF_LOG to the eeprom?
In the low level is there a weak function that could be implement to take another method of log transmission?
Thank you for your response.
Etienne
    Yes, I don't think it should be a problem to make a new custom backend that stores log messages to EEPROM memory. You may start by taking a look at the  "Logger backend interface" section of the Logger module documentation as well as going through the existing backend implementations. I believe that should give a sufficient overview interfacing part. But note that the log messages are not stored in cleartext, so it might make things a bit more difficult as I noted in this other forum thread: https://devzone.nordicsemi.com/f/nordic-q-a/56200/nrf_log-to-external-flash. Maybe it would become more straightforward without the Logger module.
  • Thanks, I achieved to make a new custom backend to store log messages to the EEPROM.
    Etienne
  • Hi Etienne,
    Could you give more insight into how you got this working?  I would like to log to external flash but like Vidar pointed out this is not usually done in cleartext, so can you provide more details about how you got around this?
    I has written a function who write on the EEPROM and define macro who link to the function.
    like this :
    #define MAX_LOG_LENGTH      50
    #define MAX_LOG_MODEM_DATA      (MAX_LOG_LENGTH - 5)
    #define MAX_LOG_DIAG_DATA       (MAX_LOG_LENGTH - 6)
    #define LOG_INFO_MASK       (uint8_t)0x00
    #define LOG_ERROR_MASK      (uint8_t)0x01
    #define LOG_WARNING_MASK    (uint8_t)0x02
    #define LOG_DEBUG_MASK      (uint8_t)0x03
    #define LOG_DEBUG_MODEM     (uint8_t)0x04
    #define LOG_EEPROM_INFO(log) log_eeprom(LOG_DIAG, LOG_INFO_MASK, log, MAX_LOG_DIAG_DATA)
    #define LOG_EEPROM_ERROR(log) log_eeprom(LOG_DIAG, LOG_ERROR_MASK, log, MAX_LOG_DIAG_DATA)
    #define LOG_EEPROM_WARNING(log) log_eeprom(LOG_DIAG, LOG_WARNING_MASK, log, MAX_LOG_DIAG_DATA)
    #define LOG_EEPROM_DEBUG(log) log_eeprom(LOG_DIAG, LOG_DEBUG_MASK, log, MAX_LOG_DIAG_DATA)
    #define LOG_EEPROM_MODEM(log) log_eeprom(LOG_MODEM, LOG_DEBUG_MODEM, log, MAX_LOG_MODEM_DATA)
    ret_code_t log_eeprom(uint8_t partitionId, uint8_t levelId, char const * const logText, uint8_t maxLength);
    Etienne
