SPI BLE receive wrong values via UART and BLE
Hey guys,
I'm working with a Laird BL652-DVK (nrF 52832 - chip), Nordic SDK v.14.2.0 and SES (Segger Embedded Studio v.4.30). My goal is to send datas from sensor (accelerometer LIS3DH) via bluetooth to my phone. I get via spi the datas from sensor.
At first I tested the examples spim, uart and ble_app_uart separatly and all examples worked. But now I try to combine my modified example spim with unmodified example ble_app_uart and get the wrong "WHO_AM_I" values both via UART (Termite v3.4) and via BLE (to my phone, app: nRF Connect). (My modified spim code is working too.)
Via UART I get instead of 0x33 (default value for WHO_AM_I) another value. Via Bluetooth I get instead of 0x33 the value 0x3. I think there is something wrong with my code...
Here is my code:
 * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_spi.h"  //spi header
#include "nrf_delay.h"  //delay header
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus);        /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
//spi
#define SPI_INSTANCE  0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
uint8_t read_data[2]; //2-byte receive array, 2nd byte will contain id
//accel input register
uint8_t LIS3DH_CTRL_REG1[] = {0x20, 0x47}; //all axes, normal, 50Hz
uint8_t LIS3DH_CTRL_REG2[] = {0x21, 0x00}; //no highpass filter
uint8_t LIS3DH_CTRL_REG3[] = {0x22, 0x00}; //no interrupts
uint8_t LIS3DH_CTRL_REG4[] = {0x23, 0x00}; //all defaults
uint8_t LIS3DH_CTRL_REG5[] = {0x24, 0x00}; //all defaults
uint8_t LIS3DH_CTRL_REG6[] = {0x25, 0x00}; //all defaults
//accel output register
uint8_t LIS3DH_WHO_AM_I_REG[] = {0x80 | 0x0F};  // Set ms bit to perform a read
uint8_t LIS3DH_OUT_X_H[] = {0x80 | 0x29};
uint8_t LIS3DH_OUT_X_L[] = {0x80 | 0x28};
uint8_t LIS3DH_OUT_Y_H[] = {0x80 | 0x2B};
uint8_t LIS3DH_OUT_Y_L[] = {0x80 | 0x2A};
uint8_t LIS3DH_OUT_Z_H[] = {0x80 | 0x2D};
uint8_t LIS3DH_OUT_Z_L[] = {0x80 | 0x2C};
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
 *          the device. It also sets the permissions and appearance.
 *          Es beschreibt, welche Funktion das Bluetooth-Modul auf der untersten Ebene eruellen muss,
 *          z.B. Verbindungsaufbau, Authentifizierung, Betriebsarten... .
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_nus    Nordic UART Service structure.
 * @param[in] p_data   Data to be send to UART module.
 * @param[in] length   Length of the data.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length-1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t       err_code;
    ble_nus_init_t nus_init;
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    APP_ERROR_HANDLER(nrf_error);
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
#ifndef S140
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
#if !defined (S112)
         case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST:
            ble_gap_data_length_params_t dl_params;
            // Clearing the struct will effectivly set members to @ref BLE_GAP_DATA_LENGTH_AUTO
            memset(&dl_params, 0, sizeof(ble_gap_data_length_params_t));
            err_code = sd_ble_gap_data_length_update(p_ble_evt->evt.gap_evt.conn_handle, &dl_params, NULL);
        } break;
#endif //!defined (S112)
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
        case BLE_EVT_USER_MEM_REQUEST:
            err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
        case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
            ble_gatts_evt_rw_authorize_request_t  req;
            ble_gatts_rw_authorize_reply_params_t auth_reply;
            req = p_ble_evt->evt.gatts_evt.params.authorize_request;
            if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                    if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                        auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                        auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                    auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                    err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                               &auth_reply);
        } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, 64);
/**@brief Function for handling events from the BSP module. //BSP: Board Support Package to control hardware peripherals interface
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
/**@brief   Function for handling spi events.
/**@snippet [Handling the data received over SPI] */
void spi_event_handler(nrf_drv_spi_evt_t const * p_event, void * p_context)
    spi_xfer_done = true;
/**@brief  Function for initializing the spi.
/**@snippet [SPI Initialization] */
void spi_init()
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;  //SPI master driver instance configuration
    spi_config.ss_pin   = 22;
    spi_config.miso_pin = 24;
    spi_config.mosi_pin = 23;
    spi_config.sck_pin  = 25;
    spi_config.frequency = NRF_DRV_SPI_FREQ_8M; // data rate: 8 Mbps
    spi_config.mode     = NRF_DRV_SPI_MODE_0;	// SPI mode: SCK active high, sample on leading edge of clock.
    nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL); //Function for initializing the SPI master driver instance
/**@brief  Function for initializing the LIS3DH.
/**@snippet [LIS3DH Initialization] */
void lis_init()
      nrf_drv_spi_transfer(&spi, LIS3DH_CTRL_REG1, sizeof(LIS3DH_CTRL_REG1), NULL, 0);
      nrf_drv_spi_transfer(&spi, LIS3DH_CTRL_REG2, sizeof(LIS3DH_CTRL_REG2), NULL, 0);
      nrf_drv_spi_transfer(&spi, LIS3DH_CTRL_REG3, sizeof(LIS3DH_CTRL_REG3), NULL, 0);
      nrf_drv_spi_transfer(&spi, LIS3DH_CTRL_REG4, sizeof(LIS3DH_CTRL_REG4), NULL, 0);
      nrf_drv_spi_transfer(&spi, LIS3DH_CTRL_REG5, sizeof(LIS3DH_CTRL_REG5), NULL, 0);
      nrf_drv_spi_transfer(&spi, LIS3DH_CTRL_REG6, sizeof(LIS3DH_CTRL_REG6), NULL, 0);
/**@brief  Function for boosting drive levels to the outputs (for long wires).
/**@snippet [Boosting drive levels to the outputs] */
void boost_drive_levels()
    nrf_gpio_cfg(22,  NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
    nrf_gpio_cfg(23,  NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
    nrf_gpio_cfg(25,  NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                do
                    err_code = ble_nus_string_send(&m_nus, data_array, &length);
                    if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) )
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.config.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
/**@brief Function for placing the application in low power state while waiting for events.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
/**@brief Application main function.
    uint32_t err_code;
    bool     erase_bonds;
    // Initialize.
    err_code = app_timer_init();
    uart_init();
    log_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    printf("\r\nUART Start!\r\n");
    //NRF_LOG_INFO("UART Start!");
    spi_init();
    printf("\r\nSPI init done!\r\n");
    //NRF_LOG_INFO("spi init done!");
    nrf_drv_spi_transfer(&spi, LIS3DH_WHO_AM_I_REG, sizeof(LIS3DH_WHO_AM_I_REG), read_data, sizeof(read_data));
    nrf_delay_ms(500);
    printf("WHOAMI: %x\r\n", read_data[1]);   //print 0x33 on Termite (pc terminal) /2nd returned byte is Id); ; 1st returned byte is register address
    uint16_t length = sizeof(read_data);
    ble_nus_string_send(&m_nus, read_data, &length);  //send 0x33 via ble to phone (nRF Connect)
    lis_init();
    boost_drive_levels();
    err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    while(1)
        nrf_delay_ms(500);
        printf("WHOAMI: %d\r\n", read_data[1]);           //print 2nd returned byte, which will be Id (0x33); 1st returned byte is register address
Here are the received datas via UART:
I don't understand why I get firstly "0x24" and after it constantly "0x51"..? Because while debugging the first value is 0x24 (same like picture above) and after it constantly 0x33...
Here is the received data via BLE:
I hope, you can help me.
Christoph
  • Could you elaborate on this? Is it the phone that should not send any thing to the nRF before the nRF has sent the sensor data?
  • Hey bjorn-spockeli,
    I want something similar to the uart example (../examples/peripheral/uart). Here we see that we close the connection when we send 'q' or 'Q' via uart. (code below)
    while (true)
            uint8_t cr;
            while (app_uart_get(&cr) != NRF_SUCCESS);
            while (app_uart_put(cr) != NRF_SUCCESS);
            if (cr == 'q' || cr == 'Q')
                printf(" \r\nExit!\r\n");
                while (true)
                    // Do nothing.
    I want nearly the same for my modified ble_app_uart. But I don't want to send the quit command 'q' or 'Q' via UART, but via ble. When I press on my phone (nRF Connect) 's' (for start), the nRF sends the sensor data to my phone via ble. When I press 'q' the nRF should stop sending sensor data. And when I press 's' again the nRF send datas again. (pseudocode and photos below)
    //initializing
    uint8_t start_stop_command;
    start_stop_command = register_which_get_data_via_ble;   //which register I have to read? Or which variable?
    while(1):
        switch(start_stop_command)
            case('s' or 'S'):
                //read WHO_AM_I register from lis3dh (example)
                while(!spi_xfer_done);
                //send WHO_AM_I value (data) via ble to my phone
                ble_nus_string_send(&m_nus, DecArrAxis, &length);
                //if pressed 'q' or 'Q': break
                if(register_which_get_data_via_ble == 'q' or register_which_get_data_via_ble == 'Q')
            case('q' or 'Q'):
                //do nothing
                if(register_which_get_data_via_ble == 's' or register_which_get_data_via_ble == 'S')
    start command: (app: nRF Connect on my phone)
    RX Characteristics --> Value: s
    stop command:(app: nRF Connect on my phone)
    RX Characteristics --> Value: q
    I hope I could explain clearly and precisely.
  • Hi Christoph,
    If you have are using a modified ble_app_uart example then you're using notifications to send the sensor data to the phone. Notifications can be enabled or disabled by the central device(phone) writing to the CCCD of the characteristic on the slave device. When the CCCD is written to you will get enter the on_write handler in the NUS code. Here the is_notification_enabled flag set to true, see below.
    static void on_write(ble_nus_t * p_nus, ble_evt_t const * p_ble_evt)
        ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
        ble_nus_evt_t evt;
        evt.p_nus = p_nus;
        if (   (p_evt_write->handle == p_nus->tx_handles.cccd_handle)
            && (p_evt_write->len == 2))
            if (ble_srv_is_notification_enabled(p_evt_write->data))
                p_nus->is_notification_enabled = true;
                evt.type = BLE_NUS_EVT_COMM_STARTED;
                p_nus->is_notification_enabled = false;
                evt.type = BLE_NUS_EVT_COMM_STOPPED;
            p_nus->data_handler(&evt);
        else if (   (p_evt_write->handle == p_nus->rx_handles.value_handle)
                 && (p_nus->data_handler != NULL))
            evt.params.rx_data.p_data = p_evt_write->data;
            evt.params.rx_data.length = p_evt_write->len;
            evt.type = BLE_NUS_EVT_RX_DATA;
            // Do Nothing. This event is not relevant for this service.
    This flag is checked in ble_nus_string_send, which I assume that you use to send the sensor data.
    uint32_t ble_nus_string_send(ble_nus_t * p_nus, uint8_t * p_string, uint16_t * p_length)
        ble_gatts_hvx_params_t hvx_params;
        VERIFY_PARAM_NOT_NULL(p_nus);
        if ((p_nus->conn_handle == BLE_CONN_HANDLE_INVALID) || (!p_nus->is_notification_enabled))
        if (*p_length > BLE_NUS_MAX_DATA_LEN)
            return NRF_ERROR_INVALID_PARAM;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_nus->tx_handles.value_handle;
        hvx_params.p_data = p_string;
        hvx_params.p_len  = p_length;
        hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
        return sd_ble_gatts_hvx(p_nus->conn_handle, &hvx_params);
    As you can see ble_nus_string_send will return NRF_ERROR_INVALID_STATE if is_notification_enabled is false. So you could simply set is_notification_enabled to false when you receive the stop command from nRF Connect on your phone. Alternativly, you can use a timer to trigger the sensor data transmission and use the start/stop signals to start/stop this timer that will call ble_nus_string_send in its timeout handler.
    Best regards
    Bjørn
