nRF9160 LwM2M sample app: cannot update DTLS keys dynamically
I have extended the nRF9160 sample app to use Leshan bootstrap server. Using a boostrap server means getting DTLS PSK crypto keys from the bootstrap server. Hence the device must be able to update the keys while connecting. However, it seems this is not supported by the system:
1) The IP stack is offloaded in the sample app (CONFIG_NET_SOCKETS_OFFLOAD=y), meaning it is deployed on the modem to my understanding!?
2) The sample app writes keys at startup (before connecting to the network) thru function nrf_inbuilt_key_write(). The documentation of this function states: "Run this function only when LTE link is inactive. If used during active link, NRF_EACCES will be returned and the key material will not be written."
3) Since it is not possible to write/update keys when connected it is not possible to implement the bootstrap server scenario efficiently!
Please advice regarding the above limitations! How do you envision that the bootstrap server scenario shall be implemented?
I am using the nRF Connect SDK version 1.1.0.
BR / Björn
  • Hi.
     That is correct.
     You would have to disconnect from the network after receiving the keys, store them, and then reconnect to the network.
    That is the only way I can think  of at the moment.
    Didrik
  • Hi Didrik,
    Thanks for your response. I have been at a biz trip so I have not been able to respond.
    Regarding your implementation advice: it is not possible to disconnect, store key and connect again due to the way the LwM2M client is working in your platform. When I reconnect the LwM2M client will always go to the bootstrap server meaning I can get a new key...so I am stuck in an infinite loop. To fix this I need to patch your LwM2M client which I want to avoid.
    Questions:
    1) Why is it not possible to change keys when connected? Security?
    2) Do you have any plans to open for key change when connected?
    BR / Björn
     I have not used the LwM2M client a lot, but can you not write a function that disconnects, write the PSK and connect, then provide a pointer to that function in the load_credentials field in the lwm2m_ctx struct?
     This is because of timing restrictions in the modem. As a certificate can be quite large, it is not guaranteed that the modem is able to write it to flash (which takes time) while simultaneously upholding the timing demands of the cellular network.
  • Hi Didrik,
    To my understanding it is not possible. If I disconnect on low level then the DTLS session will be invalidated, meaning that we need to reconnect to "coaps://<url>:<port>". The only way to that with the LwM2M client is to "restart". Doing what you propose would require a change of the LwM2M client API .
    Ok, I know that problem :-) so the reason is understood. However, I have a proposal. The bootstrap server use cases gives a session key by design. A session key is volatile while the modem only stores non-volatile keys. I propose to add the possibility to store volatile keys in the modem. This would support the LwM2M boostrap server use case out of the box.
    BR / Björn
  • Hi.
    I have asked the NCS team if they know of any way around the LwM2M client's limitations.
    I'll come back to you when I get a reply.
    Didrik
1 2
