Include error - SES
I am new with the NRF52 SDK and I want to modify an NFC example (writable_ndef_msg). I am trying to add a NDEF parser but I have issues with the includes.
I have add the header path inside of : Preprocessor>Include Directories.
I have also add the .c file in the folder nRF_Librairies.
But I always have this error :
I think the problem is simple, but I haven’t been able to solve it.
Thanks in advance for your help.
writable_ndef_msg_modified.zip
  • Nordic SDK modules are conditionally compiled, there's something like
    #if NRF_MODULE_ENABLED(NDEF_MSG_PARSER
    You'll need to set
    #define NDEF_MSG_PARSER_ENABLED 1
    in sdk_config.h to actually compile the function. [edit] I'm not sure if it's exactly NDEF_MSG_PARSER_ENABLED, check the .c file top to find out the right parameter.
  • Thanks for your explanation.
    I've had some difficulties to understand which paramaters I need, finally I have found this :
    // <e> NFC_NDEF_MSG_PARSER_ENABLED - nfc_ndef_msg_parser - NFC NDEF message parser module
    #ifndef NFC_NDEF_MSG_PARSER_ENABLED
    #define NFC_NDEF_MSG_PARSER_ENABLED 1
    // <e> NFC_NDEF_MSG_PARSER_LOG_ENABLED - Enables logging in the module.
    #ifndef NFC_NDEF_MSG_PARSER_LOG_ENABLED
    #define NFC_NDEF_MSG_PARSER_LOG_ENABLED 1
    // <o> NFC_NDEF_MSG_PARSER_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NFC_NDEF_MSG_PARSER_LOG_LEVEL
    #define NFC_NDEF_MSG_PARSER_LOG_LEVEL 3
    // <o> NFC_NDEF_MSG_PARSER_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NFC_NDEF_MSG_PARSER_INFO_COLOR
    #define NFC_NDEF_MSG_PARSER_INFO_COLOR 0
    // <q> NFC_NDEF_RECORD_ENABLED  - nfc_ndef_record - NFC NDEF Record generator module
    #ifndef NFC_NDEF_RECORD_ENABLED
    #define NFC_NDEF_RECORD_ENABLED 1
    // <e> NFC_NDEF_RECORD_PARSER_ENABLED - nfc_ndef_record_parser - NFC NDEF Record parser module
    #ifndef NFC_NDEF_RECORD_PARSER_ENABLED
    #define NFC_NDEF_RECORD_PARSER_ENABLED 1
    // <e> NFC_NDEF_RECORD_PARSER_LOG_ENABLED - Enables logging in the module.
    #ifndef NFC_NDEF_RECORD_PARSER_LOG_ENABLED
    #define NFC_NDEF_RECORD_PARSER_LOG_ENABLED 1
    // <o> NFC_NDEF_RECORD_PARSER_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NFC_NDEF_RECORD_PARSER_LOG_LEVEL
    #define NFC_NDEF_RECORD_PARSER_LOG_LEVEL 3
    // <o> NFC_NDEF_RECORD_PARSER_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NFC_NDEF_RECORD_PARSER_INFO_COLOR
    #define NFC_NDEF_RECORD_PARSER_INFO_COLOR 0
    With this, I have no more troubles with the includes. Now, I have issues with the use of the parser but i will make an other ticket if necessary.
